ModelAPI_AttributeRefAttrList.h
20#ifndef ModelAPI_AttributeRefAttrList_H_
21#define ModelAPI_AttributeRefAttrList_H_
23#include "ModelAPI_Attribute.h"
24#include "ModelAPI_Feature.h"
25#include <list>
26
34{
35 public:
37 MODELAPI_EXPORT static std::string typeId()
38 {
39 return "RefAttrList";
40 }
41
43 MODELAPI_EXPORT virtual std::string attributeType();
44
46 virtual void append(ObjectPtr theObject) = 0;
48 virtual void append(AttributePtr theAttr) = 0;
49
51 virtual void remove(ObjectPtr theObject) = 0;
53 virtual void remove(AttributePtr theAttr) = 0;
54
56 virtual void clear() = 0;
57
59 virtual int size() const = 0;
60
62 virtual std::list<std::pair<ObjectPtr, AttributePtr> > list() = 0;
63
65 virtual bool isInList(const ObjectPtr& theObj) = 0;
67 virtual bool isInList(const AttributePtr& theObj) = 0;
68
70 virtual bool isAttribute(const int theIndex) const = 0;
71
74 virtual ObjectPtr object(const int theIndex) const = 0;
77 virtual AttributePtr attribute(const int theIndex) const = 0;
78
80 virtual void removeLast() = 0;
81
84 virtual void remove(const std::set<int>& theIndices) = 0;
85
86 MODELAPI_EXPORT virtual ~ModelAPI_AttributeRefAttrList();
87 protected:
89 MODELAPI_EXPORT ModelAPI_AttributeRefAttrList();
90
91};
92
93typedef std::shared_ptr<ModelAPI_AttributeRefAttrList> AttributeRefAttrListPtr;
94
95#endif
Attribute that contains list of references to features (located in the same document) or references t...
Definition: ModelAPI_AttributeRefAttrList.h:34
virtual void append(AttributePtr theAttr)=0
Appends the attribute to the end of a list.
virtual void remove(ObjectPtr theObject)=0
Erases the first meet of the feature in the list.
virtual bool isAttribute(const int theIndex) const =0
Returns true if this is reference to an attribute, not just object.
virtual void remove(AttributePtr theAttr)=0
Erases the first meet of the attribute in the list.
virtual int size() const =0
Returns number of features in the list.
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeRefAttrList.cpp:22
virtual void remove(const std::set< int > &theIndices)=0
Removes the elements from the list.
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeRefAttrList.h:37
virtual void clear()=0
Removes all references from the list.
virtual void removeLast()=0
Removes the last element in the list.
virtual void append(ObjectPtr theObject)=0
Appends the feature to the end of a list.
virtual AttributePtr attribute(const int theIndex) const =0
Returns the referenced attribute by the zero-based index.
virtual bool isInList(const ObjectPtr &theObj)=0
Returns true if the object is in list.
virtual bool isInList(const AttributePtr &theObj)=0
Returns true if the attribute is in list.
Definition: ModelAPI_AttributeRefAttrList.cpp:32
virtual std::list< std::pair< ObjectPtr, AttributePtr > > list()=0
Returns the list of features and attributes (if it is reference to the attribute)
virtual ObjectPtr object(const int theIndex) const =0
Returns the referenced object by the zero-based index.
