Class to process plugins.xml - definition of plugins (scripts, libraries). More...
#include <Config_ModuleReader.h>
| CONFIG_EXPORT | Config_ModuleReader (const char *theEventGenerated=0) |
| Constructor. More... | |
| virtual CONFIG_EXPORT | ~Config_ModuleReader () |
| Destructor. More... | |
| CONFIG_EXPORT const std::map< std::string, std::string > & | featuresInFiles () const |
| Returns map that describes which file contains a feature (the feature is key, the file is value) More... | |
| CONFIG_EXPORT const std::map< std::string, std::string > & | proprietaryFeatures () const |
| Returns map containing features, which have licensed. More... | |
| CONFIG_EXPORT const std::set< std::string > & | proprietaryPlugins () const |
| Returns proprietary plugins. More... | |
| CONFIG_EXPORT const std::set< std::string > & | modulePluginFiles () const |
| Returns list of module's xml files. More... | |
| CONFIG_EXPORT std::string | getModuleName () |
| Returns module name: an xml attribute from the root of the plugins.xml: e.g. More... | |
| CONFIG_EXPORT void | readAll () |
| CONFIG_EXPORT xmlNodePtr | findRoot (const std::string theDocumentPath="") |
| CONFIG_EXPORT const char * | encoding () const |
| static CONFIG_EXPORT void | loadPlugin (const std::string &thePluginName) |
| Detects type of the given plugin and loads it using loadLibrary or loadScript. More... | |
| static CONFIG_EXPORT void | loadLibrary (const std::string &theLibName) |
| loads the library with specific name, appends "lib*.dll" or "*.so" depending on the platform More... | |
| static CONFIG_EXPORT void | loadScript (const std::string &theFileName, bool theSendErr=true) |
| loads the python module with specified name More... | |
| static CONFIG_EXPORT void | addDependencyModule (const std::string &theModuleName) |
| static CONFIG_EXPORT std::string | resourcesConfigFile () |
| static CONFIG_EXPORT std::string | pluginConfigFile () |
| static CONFIG_EXPORT std::string | findConfigFile (const std::string theFileName, const int theFindIndex=0) |
| Checks all possible paths to configuration file given Uses theFindIndex if several solutions can be found (this is the number of solution to find) More... | |
| virtual void | processNode (xmlNodePtr aNode) |
| Recursively process the given xmlNode. More... | |
| virtual bool | processChildren (xmlNodePtr aNode) |
| Defines if the reader should process children of the given node. More... | |
| bool | hasRequiredModules (xmlNodePtr aNode) const |
| check if dependencies of the given node are in the list of loaded modules More... | |
| std::list< std::string > | importPlugin (const std::string &thePluginLibrary, const std::string &thePluginFile, const std::string &thePluginDocSection) |
| reads info about plugin's features from plugin xml description More... | |
| std::string | addPlugin (const std::string &aPluginLibrary, const std::string &aPluginScript, const std::string &aPluginConf) |
| stores information about plugin in the internal cache More... | |
| void | addFeature (const std::string &theFeatureName, const std::string &thePluginConfig) |
| Save feature in myFeaturesInFiles. More... | |
| void | addFeatureRequireLicense (const std::string &theFeatureName, const std::string &thePluginConfig) |
| Save feature in myFeaturesRequireLicense. More... | |
| virtual void | cleanup (xmlNodePtr aNode) |
| void | readRecursively (xmlNodePtr theParent) |
| xmlNodePtr | node (void *theNode) |
| void* -> xmlNodePtr More... | |
| std::string | getNodeName (xmlNodePtr theNode) |
| Gets xml node name. More... | |
| void | storeAttribute (xmlNodePtr theNode, const char *theNodeAttribute, bool doClean=false) |
| Stores an attribute in internal map for later use. More... | |
| std::string | restoreAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| Restores an attribute from internal map. More... | |
| std::string | restoreAttribute (const char *theNodeName, const char *theNodeAttribute) |
| bool | cleanupAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| Cleanups attribute from cache. More... | |
| bool | cleanupAttribute (const char *theNodeName, const char *theNodeAttribute) |
Protected Attributes | |
| std::string | myDocumentPath |
| Path to the xml document. More... | |
| xmlDocPtr | myXmlDoc |
| Root of the xml document. More... | |
| std::string | myRootFileName |
| name of the root file More... | |
| std::map< std::string, std::string > | myCachedAttributes |
| A map to store all parent's attributes. More... | |
| bool | isFromMemory |
| Config_ModuleReader::Config_ModuleReader | ( | const char * | theEventGenerated = 0 | ) |
| const std::map< std::string, std::string > & Config_ModuleReader::featuresInFiles | ( | ) | const |
| const std::map< std::string, std::string > & Config_ModuleReader::proprietaryFeatures | ( | ) | const |
The valid license should be confirmed first (the feature is key, the file is value)
| const std::set< std::string > & Config_ModuleReader::proprietaryPlugins | ( | ) | const |
| const std::set< std::string > & Config_ModuleReader::modulePluginFiles | ( | ) | const |
| std::string Config_ModuleReader::getModuleName | ( | ) |
Get module name from plugins.xml (property "module")
static |
static |
static |
| theFileName | name of the script |
| theSendErr | send error message in case of failed |
static |
Extends set of modules, used for dependency checking (if there is no required module in the set, a plugin will not be loaded)
protectedvirtual |
Reimplemented from Config_XMLReader.
protectedvirtual |
protected |
protected |
protected |
protected |
Generates an error if the feature name is already registered.
protected |
staticinherited |
Returns a path to resource files (created from ROOT_DIR environment variable)
staticinherited |
Returns a path to the plugins.xml file (created from ROOT_DIR environment variable)
Read all nodes in associated xml file, recursively if processChildren(xmlNode) is true for the xmlNode. For each read node the processNode will be called.
Returns xmlNodePtr to the root of reader's document or NULL if not found. If the path to the document to read is empty, uses myDocumentPath.
staticinherited |
protectedvirtualinherited |
This method gives an ability to finalize processing of a node, when reader is about to leave the node (node and all it's children are processed)
Reimplemented in Config_FeatureReader, and Config_ValidatorReader.
protectedinherited |
Calls processNode() for each child (for some - recursively) of the given node.
void* -> xmlNodePtr
Gets xml node name.
Key is "Node_Name:Node_Attribute" and value is getProperty(theNodeAttribute)
The key has from "Node_Name:Node_Attribute"
