Base class for all libxml readers. Provides high-level API for all xml operations.
More...
#include <Config_ValidatorReader.h>
| CONFIG_EXPORT | Config_ValidatorReader (const std::string &theXmlFile, bool isXMLContent=false) |
| CONFIG_EXPORT void | setFeatureId (const std::string &theId) |
| | Set feature ID for cases when XML for validators is parsed from memory. More...
| CONFIG_EXPORT void | readAll () |
| CONFIG_EXPORT xmlNodePtr | findRoot (const std::string theDocumentPath="") |
CONFIG_EXPORT const char * | encoding () const |
| static CONFIG_EXPORT std::string | resourcesConfigFile () |
| static CONFIG_EXPORT std::string | pluginConfigFile () |
| static CONFIG_EXPORT std::string | findConfigFile (const std::string theFileName, const int theFindIndex=0) |
| | Checks all possible paths to configuration file given Uses theFindIndex if several solutions can be found (this is the number of solution to find) More...
| virtual void | processNode (xmlNodePtr aNode) |
| | Allows to customize reader's behavior for a node. Virtual. The default implementation process "source" and "validator" nodes. More...
| virtual bool | processChildren (xmlNodePtr aNode) |
| | Defines which nodes should be processed recursively. Virtual. The default impl is to read all nodes. More...
| virtual void | cleanup (xmlNodePtr theNode) |
| void | processValidator (xmlNodePtr theNode) |
| | Retrieves all the necessary info from the validator node. Sends ValidatorLoaded event. More...
| void | readRecursively (xmlNodePtr theParent) |
| xmlNodePtr | node (void *theNode) |
| | void* -> xmlNodePtr More...
| std::string | getNodeName (xmlNodePtr theNode) |
| | Gets xml node name. More...
| void | storeAttribute (xmlNodePtr theNode, const char *theNodeAttribute, bool doClean=false) |
| | Stores an attribute in internal map for later use. More...
| std::string | restoreAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| | Restores an attribute from internal map. More...
| std::string | restoreAttribute (const char *theNodeName, const char *theNodeAttribute) |
| bool | cleanupAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| | Cleanups attribute from cache. More...
| bool | cleanupAttribute (const char *theNodeName, const char *theNodeAttribute) |
◆ Config_ValidatorReader()
| Config_ValidatorReader::Config_ValidatorReader |
const std::string & |
theXmlFile, |
bool |
isXMLContent = false |
Constructor
- Parameters
| theXmlFile | - full path to the xml file which will be processed by the reader |
◆ setFeatureId()
| CONFIG_EXPORT void Config_ValidatorReader::setFeatureId |
theId | ) |
inline |
◆ processNode()
| void Config_ValidatorReader::processNode |
xmlNodePtr |
aNode | ) |
protectedvirtual |
Reimplemented from Config_XMLReader.
◆ processChildren()
| bool Config_ValidatorReader::processChildren |
xmlNodePtr |
aNode | ) |
protectedvirtual |
◆ cleanup()
| void Config_ValidatorReader::cleanup |
xmlNodePtr |
theNode | ) |
protectedvirtual |
Cleans the cached information about parent feature or attribute (widget)
◆ processValidator()
| void Config_ValidatorReader::processValidator |
xmlNodePtr |
theNode | ) |
protected |
◆ readAll()
| void Config_XMLReader::readAll |
Read all nodes in associated xml file, recursively if processChildren(xmlNode) is true for the xmlNode. For each read node the processNode will be called.
◆ resourcesConfigFile()
| std::string Config_XMLReader::resourcesConfigFile |
staticinherited |
Returns a path to resource files (created from ROOT_DIR environment variable)
- Returns
- string value
◆ pluginConfigFile()
| std::string Config_XMLReader::pluginConfigFile |
staticinherited |
Returns a path to the plugins.xml file (created from ROOT_DIR environment variable)
- Returns
- string value
◆ findRoot()
| xmlNodePtr Config_XMLReader::findRoot |
const std::string |
theDocumentPath = "" | ) |
Returns xmlNodePtr to the root of reader's document or NULL if not found. If the path to the document to read is empty, uses myDocumentPath.
◆ findConfigFile()
| std::string Config_XMLReader::findConfigFile |
const std::string |
theFileName, |
const int |
theFindIndex = 0 |
staticinherited |
◆ readRecursively()
| void Config_XMLReader::readRecursively |
xmlNodePtr |
theParent | ) |
protectedinherited |
Calls processNode() for each child (for some - recursively) of the given node.
- See also
- ReadAll()
◆ node()
| xmlNodePtr Config_XMLReader::node |
void * |
theNode | ) |
◆ getNodeName()
| std::string Config_XMLReader::getNodeName |
xmlNodePtr |
theNode | ) |
◆ storeAttribute()
| void Config_XMLReader::storeAttribute |
xmlNodePtr |
theNode, |
const char * |
theNodeAttribute, |
bool |
doClean = false |
Key is "Node_Name:Node_Attribute" and value is getProperty(theNodeAttribute)
◆ restoreAttribute() [1/2]
| std::string Config_XMLReader::restoreAttribute |
xmlNodePtr |
theNode, |
const char * |
theNodeAttribute |
◆ restoreAttribute() [2/2]
const char * |
theNodeName, |
const char * |
theNodeAttribute |
◆ cleanupAttribute() [1/2]
| bool Config_XMLReader::cleanupAttribute |
xmlNodePtr |
theNode, |
const char * |
theNodeAttribute |
◆ cleanupAttribute() [2/2]
const char * |
theNodeName, |
const char * |
theNodeAttribute |
◆ myDocumentPath
| std::string Config_XMLReader::myDocumentPath |
Path to the xml document.
◆ myXmlDoc
| xmlDocPtr Config_XMLReader::myXmlDoc |
Root of the xml document.
◆ myRootFileName
| std::string Config_XMLReader::myRootFileName |
◆ myCachedAttributes
| std::map<std::string, std::string> Config_XMLReader::myCachedAttributes |
A map to store all parent's attributes.
The key has from "Node_Name:Node_Attribute"
