Config_FeatureMessage.h
20#ifndef CONFIG_FEATUREMESSAGE_H
21#define CONFIG_FEATUREMESSAGE_H
23#include <Config_def.h>
24#include <Events_Message.h>
26#include <string>
27
39{
40 std::string myId;
41 std::string myText;
42 std::string myTooltip;
43 std::string myIcon;
44 std::string myKeysequence;
45 std::string myHelpFile;
46
47 std::string myGroupId;
48 std::string myWorkbenchId;
49 std::string myToolBarId;
50 std::string myDocumentKind;
51 std::string myPluginLibrary;
52
53 bool myUseInput;
54 bool myInternal;
55 bool myModal;
56 bool myIsAutoPreview;
57 bool myIsTitleInToolbar;
58 bool myHideFacesPanel;
59 bool myAbortConfirmation;
60
62 bool myIsApplyContinue;
63
64 std::string myNestedFeatures;
65 std::string myActionsWhenNested;
66
67 public:
69 inline static const char* GUI_EVENT()
70 {
71 static const char * MY_GUI_EVENT_ID("WorkshopFeatureLoaded");
72 return MY_GUI_EVENT_ID;
73 }
75 inline static const char* MODEL_EVENT()
76 {
77 static const char * MY_MODEL_EVENT_ID("ModelFeatureLoaded");
78 return MY_MODEL_EVENT_ID;
79 }
80
82 CONFIG_EXPORT Config_FeatureMessage(const Events_ID theId, const void* theParent = 0);
84 CONFIG_EXPORT virtual ~Config_FeatureMessage();
85
86 //Auto-generated getters/setters
88 CONFIG_EXPORT const std::string& id() const;
90 CONFIG_EXPORT const std::string& icon() const;
92 CONFIG_EXPORT const std::string& keysequence() const;
94 CONFIG_EXPORT const std::string& text() const;
96 CONFIG_EXPORT const std::string& tooltip() const;
98 CONFIG_EXPORT const std::string& groupId() const;
100 CONFIG_EXPORT const std::string& toolBarId() const;
102 CONFIG_EXPORT const std::string& helpFileName() const;
104 CONFIG_EXPORT const std::string& workbenchId() const;
106 CONFIG_EXPORT const std::string& documentKind() const;
108 CONFIG_EXPORT const std::string& pluginLibrary() const;
110 CONFIG_EXPORT const std::string& nestedFeatures() const;
112 CONFIG_EXPORT const std::string& actionsWhenNested() const;
114 CONFIG_EXPORT bool isUseInput() const;
116 CONFIG_EXPORT bool isInternal() const;
118 CONFIG_EXPORT bool isModal() const;
120 CONFIG_EXPORT bool isApplyContinue() const;
122 CONFIG_EXPORT bool isAutoPreview() const;
124 CONFIG_EXPORT bool isTitleInToolbar() const;
126 CONFIG_EXPORT bool isHideFacesPanel() const;
127 CONFIG_EXPORT bool isAbortConfirmation() const;
128
130 CONFIG_EXPORT void setId(const std::string& id);
132 CONFIG_EXPORT void setIcon(const std::string& icon);
134 CONFIG_EXPORT void setKeysequence(const std::string& keysequence);
136 CONFIG_EXPORT void setText(const std::string& text);
138 CONFIG_EXPORT void setTooltip(const std::string& tooltip);
140 CONFIG_EXPORT void setGroupId(const std::string& groupId);
142 CONFIG_EXPORT void setToolBarId(const std::string& aId);
144 CONFIG_EXPORT void setHelpFileName(const std::string& aName);
146 CONFIG_EXPORT void setWorkbenchId(const std::string& workbenchId);
148 CONFIG_EXPORT void setDocumentKind(const std::string& documentKind);
150 CONFIG_EXPORT void setPluginLibrary(const std::string& thePluginLibrary);
152 CONFIG_EXPORT void setNestedFeatures(const std::string& theNestedFeatures);
154 CONFIG_EXPORT void setActionsWhenNested(const std::string& theActions);
156 CONFIG_EXPORT void setUseInput(bool isUseInput);
158 CONFIG_EXPORT void setInternal(bool isInternal);
160 CONFIG_EXPORT void setAutoPreview(bool isAutoPreview);
162 CONFIG_EXPORT void setModal(bool isModal);
164 CONFIG_EXPORT void setTitleInToolbar(bool theValue);
166 CONFIG_EXPORT void setHideFacesPanel(bool theValue);
168 CONFIG_EXPORT void setAbortConfirmation(bool theValue);
171 CONFIG_EXPORT void setApplyContinue(bool isModal);
172};
173
174#endif // CONFIG_MESSAGE_H
Class to pass a feature entry extracted from xml file.
Definition: Config_FeatureMessage.h:39
CONFIG_EXPORT void setPluginLibrary(const std::string &thePluginLibrary)
Set name of a library which contains the feature.
Definition: Config_FeatureMessage.cpp:147
CONFIG_EXPORT const std::string & toolBarId() const
Id of Feature's Toolbar.
Definition: Config_FeatureMessage.cpp:107
If false - feature has no Property panel representation.
Definition: Config_FeatureMessage.cpp:153
Set internal state; If true - feature will not be added into the workbench.
Definition: Config_FeatureMessage.cpp:189
CONFIG_EXPORT const std::string & actionsWhenNested() const
Space separated list of actions.
Definition: Config_FeatureMessage.cpp:204
CONFIG_EXPORT const std::string & workbenchId() const
Id of Feature's Workbench.
Definition: Config_FeatureMessage.cpp:117
CONFIG_EXPORT const std::string & documentKind() const
Kind of a document which contains the feature.
Definition: Config_FeatureMessage.cpp:127
CONFIG_EXPORT const std::string & tooltip() const
Feature's tooltip.
Definition: Config_FeatureMessage.cpp:92
If true - the feature will be represented by modal dialog box GUI.
Definition: Config_FeatureMessage.cpp:173
CONFIG_EXPORT void setToolBarId(const std::string &aId)
Set id of Feature's Group.
Definition: Config_FeatureMessage.cpp:112
CONFIG_EXPORT const std::string & nestedFeatures() const
Space separated list of nested features.
Definition: Config_FeatureMessage.cpp:199
CONFIG_EXPORT void setText(const std::string &text)
Set feature's text.
Definition: Config_FeatureMessage.cpp:87
CONFIG_EXPORT void setId(const std::string &id)
Set feature's Id.
Definition: Config_FeatureMessage.cpp:67
CONFIG_EXPORT void setNestedFeatures(const std::string &theNestedFeatures)
Set space separated list of nested features.
Definition: Config_FeatureMessage.cpp:209
static const char * MODEL_EVENT()
Event ID that feature is loaded in workbench (Model)
Definition: Config_FeatureMessage.h:75
CONFIG_EXPORT const std::string & pluginLibrary() const
Name of a library which contains the feature.
Definition: Config_FeatureMessage.cpp:142
Set auto preview state; If true - preview of the feature is computed automatically.
Definition: Config_FeatureMessage.cpp:219
CONFIG_EXPORT const std::string & icon() const
Feature's Icon.
Definition: Config_FeatureMessage.cpp:52
virtual CONFIG_EXPORT ~Config_FeatureMessage()
Deletes Config_FeatureMessage.
Definition: Config_FeatureMessage.cpp:47
CONFIG_EXPORT void setHelpFileName(const std::string &aName)
Set help file name.
Definition: Config_FeatureMessage.cpp:234
CONFIG_EXPORT const std::string & id() const
Feature's Id.
Definition: Config_FeatureMessage.cpp:62
Set flag to display title in toolbar.
Definition: Config_FeatureMessage.cpp:250
Set modality state; If true - the feature will be represented by modal dialog box GUI.
Definition: Config_FeatureMessage.cpp:194
CONFIG_EXPORT void setWorkbenchId(const std::string &workbenchId)
Set id of Feature's Workbench.
Definition: Config_FeatureMessage.cpp:122
Definition: Config_FeatureMessage.cpp:158
Definition: Config_FeatureMessage.cpp:239
If true - title should normally be displayed in the toolbar.
Definition: Config_FeatureMessage.cpp:168
If true - preview of the feature is done by any modification of the feature attributes.
Definition: Config_FeatureMessage.cpp:163
If true - the feature can have Apply/Continue button in its property panel.
Definition: Config_FeatureMessage.cpp:178
Set use input state; If false - feature has no Property panel representation.
Definition: Config_FeatureMessage.cpp:184
CONFIG_EXPORT void setKeysequence(const std::string &keysequence)
Set feature's shortcut.
Definition: Config_FeatureMessage.cpp:77
CONFIG_EXPORT const std::string & text() const
Feature's text.
Definition: Config_FeatureMessage.cpp:82
CONFIG_EXPORT const std::string & helpFileName() const
Returns help file name for the feature.
Definition: Config_FeatureMessage.cpp:229
Set Apply/Continue state; If true - the feature can have Apply/Continue button in its property panel.
Definition: Config_FeatureMessage.cpp:224
CONFIG_EXPORT void setTooltip(const std::string &tooltip)
Set feature's tooltip.
Definition: Config_FeatureMessage.cpp:137
CONFIG_EXPORT void setDocumentKind(const std::string &documentKind)
Set kind of a document which contains the feature.
Definition: Config_FeatureMessage.cpp:132
If true - then HideFaces panel has to be shown.
Definition: Config_FeatureMessage.cpp:244
CONFIG_EXPORT const std::string & keysequence() const
Feature's shortcut.
Definition: Config_FeatureMessage.cpp:72
CONFIG_EXPORT void setGroupId(const std::string &groupId)
Definition: Config_FeatureMessage.cpp:102
CONFIG_EXPORT void setActionsWhenNested(const std::string &theActions)
Definition: Config_FeatureMessage.cpp:214
CONFIG_EXPORT Config_FeatureMessage(const Events_ID theId, const void *theParent=0)
Constructs Config_FeatureMessage.
Definition: Config_FeatureMessage.cpp:260
CONFIG_EXPORT const std::string & groupId() const
Id of Feature's Group.
Definition: Config_FeatureMessage.cpp:97
CONFIG_EXPORT void setIcon(const std::string &icon)
Set feature's Icon.
Definition: Config_FeatureMessage.cpp:57
static const char * GUI_EVENT()
Event ID that feature is loaded in workbench (GUI)
Definition: Config_FeatureMessage.h:69
Identifier of the event kind.
Definition: Events_Message.h:36
Message for communication between sender and listener of event.
Definition: Events_Message.h:65
