Config_FeatureMessage Class Reference
Class to pass a feature entry extracted from xml file. More...
#include <Config_FeatureMessage.h>
Inheritance diagram for Config_FeatureMessage:
CONFIG_EXPORT Config_FeatureMessage (const Events_ID theId, const void *theParent=0)
 Constructs Config_FeatureMessage. More...
virtual CONFIG_EXPORT ~Config_FeatureMessage ()
 Deletes Config_FeatureMessage. More...
CONFIG_EXPORT const std::string & id () const
 Feature's Id. More...
CONFIG_EXPORT const std::string & icon () const
 Feature's Icon. More...
CONFIG_EXPORT const std::string & keysequence () const
 Feature's shortcut. More...
CONFIG_EXPORT const std::string & text () const
 Feature's text. More...
CONFIG_EXPORT const std::string & tooltip () const
 Feature's tooltip. More...
CONFIG_EXPORT const std::string & groupId () const
 Id of Feature's Group. More...
CONFIG_EXPORT const std::string & toolBarId () const
 Id of Feature's Toolbar. More...
CONFIG_EXPORT const std::string & helpFileName () const
 Returns help file name for the feature. More...
CONFIG_EXPORT const std::string & workbenchId () const
 Id of Feature's Workbench. More...
CONFIG_EXPORT const std::string & documentKind () const
 Kind of a document which contains the feature. More...
CONFIG_EXPORT const std::string & pluginLibrary () const
 Name of a library which contains the feature. More...
CONFIG_EXPORT const std::string & nestedFeatures () const
 Space separated list of nested features. More...
CONFIG_EXPORT const std::string & actionsWhenNested () const
 Space separated list of actions. More...
CONFIG_EXPORT bool isUseInput () const
 If false - feature has no Property panel representation. More...
CONFIG_EXPORT bool isInternal () const
 If true - feature will not be added into the workbench. More...
CONFIG_EXPORT bool isModal () const
 If true - the feature will be represented by modal dialog box GUI. More...
CONFIG_EXPORT bool isApplyContinue () const
 If true - the feature can have Apply/Continue button in its property panel. More...
CONFIG_EXPORT bool isAutoPreview () const
 If true - preview of the feature is done by any modification of the feature attributes. More...
CONFIG_EXPORT bool isTitleInToolbar () const
 If true - title should normally be displayed in the toolbar. More...
CONFIG_EXPORT bool isHideFacesPanel () const
 If true - then HideFaces panel has to be shown. More...
CONFIG_EXPORT bool isAbortConfirmation () const
CONFIG_EXPORT void setId (const std::string &id)
 Set feature's Id. More...
CONFIG_EXPORT void setIcon (const std::string &icon)
 Set feature's Icon. More...
CONFIG_EXPORT void setKeysequence (const std::string &keysequence)
 Set feature's shortcut. More...
CONFIG_EXPORT void setText (const std::string &text)
 Set feature's text. More...
CONFIG_EXPORT void setTooltip (const std::string &tooltip)
 Set feature's tooltip. More...
CONFIG_EXPORT void setGroupId (const std::string &groupId)
 Set id of Feature's Group. More...
CONFIG_EXPORT void setToolBarId (const std::string &aId)
CONFIG_EXPORT void setHelpFileName (const std::string &aName)
 Set help file name. More...
CONFIG_EXPORT void setWorkbenchId (const std::string &workbenchId)
 Set id of Feature's Workbench. More...
CONFIG_EXPORT void setDocumentKind (const std::string &documentKind)
 Set kind of a document which contains the feature. More...
CONFIG_EXPORT void setPluginLibrary (const std::string &thePluginLibrary)
 Set name of a library which contains the feature. More...
CONFIG_EXPORT void setNestedFeatures (const std::string &theNestedFeatures)
 Set space separated list of nested features. More...
CONFIG_EXPORT void setActionsWhenNested (const std::string &theActions)
CONFIG_EXPORT void setUseInput (bool isUseInput)
 Set use input state; If false - feature has no Property panel representation. More...
CONFIG_EXPORT void setInternal (bool isInternal)
 Set internal state; If true - feature will not be added into the workbench. More...
CONFIG_EXPORT void setAutoPreview (bool isAutoPreview)
 Set auto preview state; If true - preview of the feature is computed automatically. More...
CONFIG_EXPORT void setModal (bool isModal)
 Set modality state; If true - the feature will be represented by modal dialog box GUI. More...
CONFIG_EXPORT void setTitleInToolbar (bool theValue)
 Set flag to display title in toolbar. More...
CONFIG_EXPORT void setHideFacesPanel (bool theValue)
CONFIG_EXPORT void setAbortConfirmation (bool theValue)
CONFIG_EXPORT void setApplyContinue (bool isModal)
 Set Apply/Continue state; If true - the feature can have Apply/Continue button in its property panel. More...
const Events_ID & eventID () const
 Returns identifier of the message. More...
void * sender () const
 Returns sender of the message or NULL if it is anonymous message. More...
static const char * GUI_EVENT ()
 Event ID that feature is loaded in workbench (GUI) More...
static const char * MODEL_EVENT ()
 Event ID that feature is loaded in workbench (Model) More...
Example of the feature entry:
<feature id="Part" text="New part" tooltip="Creates a new part" icon=":pictures/part_ico.png"/>
CONFIG_EXPORT const std::string & tooltip() const
Feature's tooltip.
Definition: Config_FeatureMessage.cpp:92
CONFIG_EXPORT const std::string & icon() const
Feature's Icon.
Definition: Config_FeatureMessage.cpp:52
CONFIG_EXPORT const std::string & text() const
Feature's text.
Definition: Config_FeatureMessage.cpp:82
◆ Config_FeatureMessage()
Config_FeatureMessage::Config_FeatureMessage ( const Events_ID  theId,
const void *  theParent = 0
◆ ~Config_FeatureMessage()
Config_FeatureMessage::~Config_FeatureMessage ( )
◆ GUI_EVENT()
static const char * Config_FeatureMessage::GUI_EVENT ( )
inlinestatic
◆ MODEL_EVENT()
static const char * Config_FeatureMessage::MODEL_EVENT ( )
inlinestatic
◆ id()
const std::string & Config_FeatureMessage::id ( ) const
Feature's Id.
◆ icon()
const std::string & Config_FeatureMessage::icon ( ) const
Feature's Icon.
◆ keysequence()
const std::string & Config_FeatureMessage::keysequence ( ) const
Feature's shortcut.
◆ text()
const std::string & Config_FeatureMessage::text ( ) const
Feature's text.
◆ tooltip()
const std::string & Config_FeatureMessage::tooltip ( ) const
Feature's tooltip.
◆ groupId()
const std::string & Config_FeatureMessage::groupId ( ) const
◆ toolBarId()
const std::string & Config_FeatureMessage::toolBarId ( ) const
◆ helpFileName()
const std::string & Config_FeatureMessage::helpFileName ( ) const
◆ workbenchId()
const std::string & Config_FeatureMessage::workbenchId ( ) const
◆ documentKind()
const std::string & Config_FeatureMessage::documentKind ( ) const
◆ pluginLibrary()
const std::string & Config_FeatureMessage::pluginLibrary ( ) const
◆ nestedFeatures()
const std::string & Config_FeatureMessage::nestedFeatures ( ) const
◆ actionsWhenNested()
const std::string & Config_FeatureMessage::actionsWhenNested ( ) const
◆ isUseInput()
bool Config_FeatureMessage::isUseInput ( ) const
◆ isInternal()
bool Config_FeatureMessage::isInternal ( ) const
◆ isModal()
bool Config_FeatureMessage::isModal ( ) const
◆ isApplyContinue()
bool Config_FeatureMessage::isApplyContinue ( ) const
◆ isAutoPreview()
bool Config_FeatureMessage::isAutoPreview ( ) const
◆ isTitleInToolbar()
bool Config_FeatureMessage::isTitleInToolbar ( ) const
◆ isHideFacesPanel()
bool Config_FeatureMessage::isHideFacesPanel ( ) const
◆ setId()
void Config_FeatureMessage::setId ( const std::string &  id)
Set feature's Id.
◆ setIcon()
void Config_FeatureMessage::setIcon ( const std::string &  icon)
Set feature's Icon.
◆ setKeysequence()
void Config_FeatureMessage::setKeysequence ( const std::string &  keysequence)
◆ setText()
void Config_FeatureMessage::setText ( const std::string &  text)
Set feature's text.
◆ setTooltip()
void Config_FeatureMessage::setTooltip ( const std::string &  tooltip)
◆ setGroupId()
void Config_FeatureMessage::setGroupId ( const std::string &  groupId)
◆ setToolBarId()
void Config_FeatureMessage::setToolBarId ( const std::string &  aId)
◆ setHelpFileName()
void Config_FeatureMessage::setHelpFileName ( const std::string &  aName)
Set help file name.
◆ setWorkbenchId()
void Config_FeatureMessage::setWorkbenchId ( const std::string &  workbenchId)
◆ setDocumentKind()
void Config_FeatureMessage::setDocumentKind ( const std::string &  documentKind)
◆ setPluginLibrary()
void Config_FeatureMessage::setPluginLibrary ( const std::string &  thePluginLibrary)
◆ setNestedFeatures()
void Config_FeatureMessage::setNestedFeatures ( const std::string &  theNestedFeatures)
◆ setActionsWhenNested()
void Config_FeatureMessage::setActionsWhenNested ( const std::string &  theActions)
◆ setUseInput()
void Config_FeatureMessage::setUseInput ( bool  isUseInput)
◆ setInternal()
void Config_FeatureMessage::setInternal ( bool  isInternal)
◆ setAutoPreview()
void Config_FeatureMessage::setAutoPreview ( bool  isAutoPreview)
◆ setModal()
void Config_FeatureMessage::setModal ( bool  isModal)
◆ setTitleInToolbar()
void Config_FeatureMessage::setTitleInToolbar ( bool  theValue)
◆ setHideFacesPanel()
void Config_FeatureMessage::setHideFacesPanel ( bool  theValue)
◆ setAbortConfirmation()
void Config_FeatureMessage::setAbortConfirmation ( bool  theValue)
◆ setApplyContinue()
void Config_FeatureMessage::setApplyContinue ( bool  isModal)
◆ eventID()
const Events_ID & Events_Message::eventID ( ) const
◆ sender()
void * Events_Message::sender ( ) const
