Config_ModuleReader.h
20#ifndef CONFIG_MODULEREADER_H_
21#define CONFIG_MODULEREADER_H_
23#include <Config_def.h>
24#include <Config_XMLReader.h>
26#include <map>
27#include <list>
28#include <set>
29#include <string>
30
37{
38 enum PluginType {
39 Binary = 0,
40 Intrenal = 1,
41 Python = 2
42 };
43
44 public:
46 CONFIG_EXPORT Config_ModuleReader(const char* theEventGenerated = 0);
48 CONFIG_EXPORT virtual ~Config_ModuleReader();
51 CONFIG_EXPORT const std::map<std::string, std::string>& featuresInFiles() const;
55 CONFIG_EXPORT const std::map<std::string, std::string>& proprietaryFeatures() const;
57 CONFIG_EXPORT const std::set<std::string>& proprietaryPlugins() const;
59 CONFIG_EXPORT const std::set<std::string>& modulePluginFiles() const;
62 CONFIG_EXPORT std::string getModuleName();
64 CONFIG_EXPORT static void loadPlugin(const std::string& thePluginName);
66 CONFIG_EXPORT static void loadLibrary(const std::string& theLibName);
70 CONFIG_EXPORT static void loadScript(const std::string& theFileName, bool theSendErr = true);
75 CONFIG_EXPORT static void addDependencyModule(const std::string& theModuleName);
76
77 protected:
79 virtual void processNode(xmlNodePtr aNode);
81 virtual bool processChildren(xmlNodePtr aNode);
83 bool hasRequiredModules(xmlNodePtr aNode) const;
85 std::list<std::string> importPlugin(const std::string& thePluginLibrary,
86 const std::string& thePluginFile,
87 const std::string& thePluginDocSection);
89 std::string addPlugin(const std::string& aPluginLibrary,
90 const std::string& aPluginScript,
91 const std::string& aPluginConf);
94 void addFeature(const std::string& theFeatureName, const std::string& thePluginConfig);
97 void addFeatureRequireLicense(const std::string& theFeatureName,
98 const std::string& thePluginConfig);
99
100 private:
101 std::map<std::string, std::string> myFeaturesInFiles;
103 std::map<std::string, std::string> myProprietaryFeatures;
104 std::set<std::string> myPluginFiles;
106 static std::map<std::string, PluginType> myPluginTypes;
107 static std::set<std::string> myDependencyModules;
108 const char* myEventGenerated;
109
110 std::set<std::string> myProprietaryPlugins;
111};
112
113#endif /* CONFIG_XMLMODULEREADER_H_ */
Class to process plugins.xml - definition of plugins (scripts, libraries).
Definition: Config_ModuleReader.h:37
CONFIG_EXPORT const std::set< std::string > & proprietaryPlugins() const
Returns proprietary plugins.
Definition: Config_ModuleReader.cpp:70
CONFIG_EXPORT const std::map< std::string, std::string > & proprietaryFeatures() const
Returns map containing features, which have licensed.
Definition: Config_ModuleReader.cpp:65
CONFIG_EXPORT const std::set< std::string > & modulePluginFiles() const
Returns list of module's xml files.
Definition: Config_ModuleReader.cpp:75
CONFIG_EXPORT Config_ModuleReader(const char *theEventGenerated=0)
Definition: Config_ModuleReader.cpp:50
void addFeature(const std::string &theFeatureName, const std::string &thePluginConfig)
Save feature in myFeaturesInFiles.
Definition: Config_ModuleReader.cpp:91
Recursively process the given xmlNode.
Definition: Config_ModuleReader.cpp:124
Returns module name: an xml attribute from the root of the plugins.xml: e.g.
Definition: Config_ModuleReader.cpp:84
static CONFIG_EXPORT void addDependencyModule(const std::string &theModuleName)
Definition: Config_ModuleReader.cpp:425
std::string addPlugin(const std::string &aPluginLibrary, const std::string &aPluginScript, const std::string &aPluginConf)
stores information about plugin in the internal cache
Definition: Config_ModuleReader.cpp:195
virtual CONFIG_EXPORT ~Config_ModuleReader()
Definition: Config_ModuleReader.cpp:56
check if dependencies of the given node are in the list of loaded modules
Definition: Config_ModuleReader.cpp:166
Defines if the reader should process children of the given node.
Definition: Config_ModuleReader.cpp:161
CONFIG_EXPORT const std::map< std::string, std::string > & featuresInFiles() const
Returns map that describes which file contains a feature (the feature is key, the file is value)
Definition: Config_ModuleReader.cpp:60
static CONFIG_EXPORT void loadScript(const std::string &theFileName, bool theSendErr=true)
loads the python module with specified name
Definition: Config_ModuleReader.cpp:369
void addFeatureRequireLicense(const std::string &theFeatureName, const std::string &thePluginConfig)
Save feature in myFeaturesRequireLicense.
Definition: Config_ModuleReader.cpp:109
static CONFIG_EXPORT void loadLibrary(const std::string &theLibName)
loads the library with specific name, appends "lib*.dll" or "*.so" depending on the platform
Definition: Config_ModuleReader.cpp:391
std::list< std::string > importPlugin(const std::string &thePluginLibrary, const std::string &thePluginFile, const std::string &thePluginDocSection)
reads info about plugin's features from plugin xml description
Definition: Config_ModuleReader.cpp:178
static CONFIG_EXPORT void loadPlugin(const std::string &thePluginName)
Detects type of the given plugin and loads it using loadLibrary or loadScript.
Definition: Config_ModuleReader.cpp:217
Base class for all libxml readers. Provides high-level API for all xml operations.
Definition: Config_XMLReader.h:48
