FeaturesPlugin_Symmetry.h
20#ifndef FEATURESPLUGIN_SYMMETRY_H_
21#define FEATURESPLUGIN_SYMMETRY_H_
23#include <FeaturesPlugin.h>
24
26#include <ModelAPI_Result.h>
27
28class GeomAPI_Trsf;
30
36{
37 public:
39 inline static const std::string& ID()
40 {
41 static const std::string MY_SYMMETRY_ID("Symmetry");
42 return MY_SYMMETRY_ID;
43 }
44
46 inline static const std::string& CREATION_METHOD()
47 {
48 static const std::string MY_CREATION_METHOD_ID("CreationMethod");
49 return MY_CREATION_METHOD_ID;
50 }
51
53 inline static const std::string& CREATION_METHOD_BY_POINT()
54 {
55 static const std::string MY_CREATION_METHOD_ID("ByPoint");
56 return MY_CREATION_METHOD_ID;
57 }
58
60 inline static const std::string& CREATION_METHOD_BY_AXIS()
61 {
62 static const std::string MY_CREATION_METHOD_ID("ByAxis");
63 return MY_CREATION_METHOD_ID;
64 }
65
67 inline static const std::string& CREATION_METHOD_BY_PLANE()
68 {
69 static const std::string MY_CREATION_METHOD_ID("ByPlane");
70 return MY_CREATION_METHOD_ID;
71 }
72
74 inline static const std::string& OBJECTS_LIST_ID()
75 {
76 static const std::string MY_OBJECTS_LIST_ID("main_objects");
77 return MY_OBJECTS_LIST_ID;
78 }
79
81 inline static const std::string& POINT_OBJECT_ID()
82 {
83 static const std::string MY_POINT_OBJECT_ID("point_object");
84 return MY_POINT_OBJECT_ID;
85 }
86
88 inline static const std::string& AXIS_OBJECT_ID()
89 {
90 static const std::string MY_AXIS_OBJECT_ID("axis_object");
91 return MY_AXIS_OBJECT_ID;
92 }
93
95 inline static const std::string& PLANE_OBJECT_ID()
96 {
97 static const std::string MY_PLANE_OBJECT_ID("plane_object");
98 return MY_PLANE_OBJECT_ID;
99 }
100
102 inline static const std::string& KEEP_ORIGINAL_RESULT()
103 {
104 static const std::string MY_KEEP_ORIGINAL_RESULT_ID("keep_original");
105 return MY_KEEP_ORIGINAL_RESULT_ID;
106 }
107
109 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
110 {
111 static std::string MY_KIND = FeaturesPlugin_Symmetry::ID();
112 return MY_KIND;
113 }
114
116 FEATURESPLUGIN_EXPORT virtual void execute();
117
119 FEATURESPLUGIN_EXPORT virtual void initAttributes();
120
123
124private:
126 std::shared_ptr<GeomAPI_Trsf> symmetryByPoint();
127
129 std::shared_ptr<GeomAPI_Trsf> symmetryByAxis();
130
132 std::shared_ptr<GeomAPI_Trsf> symmetryByPlane();
133
135 void performSymmetry(std::shared_ptr<GeomAPI_Trsf> theTrsf);
136
138 void buildResult(const std::shared_ptr<GeomAlgoAPI_MakeShapeList>& theAlgo,
139 const std::list<std::shared_ptr<GeomAPI_Shape> >& theOriginalShapes,
140 std::shared_ptr<GeomAPI_Shape> theTargetShape,
141 int& theResultIndex,
142 const ResultPtr& theTextureSource);
143
145 void buildResult(std::shared_ptr<ModelAPI_ResultPart> theOriginal,
146 std::shared_ptr<GeomAPI_Trsf> theTrsf,
147 int& theResultIndex);
148};
149
150#endif // FEATURESPLUGIN_SYMMETRY_H_
Feature that performs reflection with respect to a point, axis, or plane.
Definition: FeaturesPlugin_Symmetry.h:36
virtual FEATURESPLUGIN_EXPORT void execute()
Definition: FeaturesPlugin_Symmetry.cpp:84
virtual FEATURESPLUGIN_EXPORT const std::string & getKind()
Definition: FeaturesPlugin_Symmetry.h:109
static const std::string & CREATION_METHOD_BY_POINT()
Attribute name for creation method "ByPoint".
Definition: FeaturesPlugin_Symmetry.h:53
FeaturesPlugin_Symmetry()
Definition: FeaturesPlugin_Symmetry.cpp:51
virtual FEATURESPLUGIN_EXPORT void initAttributes()
Definition: FeaturesPlugin_Symmetry.cpp:56
static const std::string & PLANE_OBJECT_ID()
Attribute name of a plane.
Definition: FeaturesPlugin_Symmetry.h:95
static const std::string & CREATION_METHOD_BY_AXIS()
Attribute name for creation method "ByAxis".
Definition: FeaturesPlugin_Symmetry.h:60
Definition: FeaturesPlugin_Symmetry.h:46
static const std::string & AXIS_OBJECT_ID()
Attribute name of an axis.
Definition: FeaturesPlugin_Symmetry.h:88
static const std::string & KEEP_ORIGINAL_RESULT()
Attribute name of keeping original shape.
Definition: FeaturesPlugin_Symmetry.h:102
Symmetry kind.
Definition: FeaturesPlugin_Symmetry.h:39
static const std::string & POINT_OBJECT_ID()
Attribute name of a point.
Definition: FeaturesPlugin_Symmetry.h:81
static const std::string & CREATION_METHOD_BY_PLANE()
Attribute name for creation method "ByPlane".
Definition: FeaturesPlugin_Symmetry.h:67
Attribute name of referenced objects.
Definition: FeaturesPlugin_Symmetry.h:74
Keep the transformation matrix coefficients.
Definition: GeomAPI_Trsf.h:36
List of topological shapes constructions.
Definition: GeomAlgoAPI_MakeShapeList.h:33
