GEOMImpl_Fillet1d.hxx
20// File : GEOMImpl_Fillet1d.hxx
21// Module : GEOMImpl
23#ifndef _GEOMImpl_Fillet1d_HeaderFile
24#define _GEOMImpl_Fillet1d_HeaderFile
26#include <TopoDS_Edge.hxx>
27
28#include <Geom_Plane.hxx>
29#include <Geom2d_Curve.hxx>
30
31#include <gp_Pnt.hxx>
32
33#include <TColStd_ListOfReal.hxx>
34#include <TColStd_SequenceOfReal.hxx>
35#include <TColStd_SequenceOfInteger.hxx>
36
38
44{
45public:
48 Standard_EXPORT GEOMImpl_Fillet1d(const TopoDS_Edge& theEdge1,
49 const TopoDS_Edge& theEdge2,
50 const gp_Pln& thePlane);
53 Standard_EXPORT Standard_Boolean Perform(const Standard_Real theRadius);
54
56 Standard_EXPORT TopoDS_Edge Result(const gp_Pnt& thePoint, TopoDS_Edge& theEdge1, TopoDS_Edge& theEdge2);
57
58private:
60 void performInterval(const Standard_Real theStart,
61 const Standard_Real theEnd,
62 const Standard_Integer theNBSteps);
63 void fillPoint(GEOMImpl_Fillet1dPoint*);
64 void fillDiff(GEOMImpl_Fillet1dPoint*, Standard_Real, Standard_Boolean);
66 Standard_Boolean processPoint(GEOMImpl_Fillet1dPoint*, GEOMImpl_Fillet1dPoint*, Standard_Real);
67
68private:
70 TopoDS_Edge myEdge1, myEdge2;
71 Handle(Geom_Plane) myPlane;
72 Handle(Geom2d_Curve) myCurve1, myCurve2;
73 Standard_Real myStart1, myEnd1, myStart2, myEnd2, myRadius;
74 TColStd_ListOfReal myResultParams;
75 TColStd_SequenceOfInteger myResultOrientation;
76 Standard_Boolean myStartSide, myEdgesExchnged;
77 Standard_Integer myDegreeOfRecursion;
78};
79
80
87{
88public:
90
92 Standard_EXPORT GEOMImpl_Fillet1dPoint(Standard_Real theParam)
93 {myParam = theParam;}
94
97 Standard_EXPORT GEOMImpl_Fillet1dPoint* Copy(); // warning: this is not the full copy!
98
100 Standard_EXPORT inline void SetParam(Standard_Real theParam)
101 {myParam = theParam;}
102 Standard_EXPORT inline Standard_Real GetParam() const
103 {return myParam;}
104 Standard_EXPORT inline void SetParam2(const Standard_Real theParam2)
105 {myParam2 = theParam2;}
106 Standard_EXPORT inline Standard_Real GetParam2()
107 { return myParam2 ; }
108
110 Standard_EXPORT inline Standard_Boolean IsValid(int theIndex)
111 {return (Standard_Boolean)myValid.Value(theIndex);}
112
114 Standard_EXPORT inline Standard_Integer GetNBValues() {return myV.Length();}
115 Standard_EXPORT inline Standard_Real GetValue(Standard_Integer theIndex)
116 {return myV.Value(theIndex);}
117 Standard_EXPORT inline Standard_Real GetDiff(Standard_Integer theIndex)
118 {return myD.Value(theIndex);}
119 Standard_EXPORT inline Standard_Integer GetNear(Standard_Integer theIndex)
120 {return myNear.Value(theIndex);}
121
123 Standard_EXPORT inline void SetCenter(const gp_Pnt2d thePoint)
124 {myCenter = thePoint;}
125 Standard_EXPORT inline const gp_Pnt2d GetCenter()
126 {return myCenter;}
127
128 Standard_EXPORT void AddValue(Standard_Real theValue, Standard_Boolean theIsValid);
129
131 Standard_EXPORT Standard_Boolean ComputeDifference(GEOMImpl_Fillet1dPoint*);
132 Standard_EXPORT void FilterPoints(GEOMImpl_Fillet1dPoint*);
133
135 Standard_EXPORT Standard_Integer HasSolution(Standard_Real theRadius);
137 void RemoveSolution(Standard_Integer theIndex);
138
139private:
141 gp_Pnt2d myCenter;
142 Standard_Real myParam, myParam2;
143 TColStd_SequenceOfReal myV, myD;
144 TColStd_SequenceOfInteger myValid, myNear;
145};
146
147#endif
GEOMImpl_Fillet1dPoint is an internal class for 1D fillet algorithm to store and compare computed sol...
Definition: GEOMImpl_Fillet1d.hxx:87
Returns validity.
Definition: GEOMImpl_Fillet1d.hxx:110
Set/Get center point.
Definition: GEOMImpl_Fillet1d.hxx:123
Get values.
Definition: GEOMImpl_Fillet1d.hxx:114
Checks if point contains solution and returns the index of it if any.
Definition: GEOMImpl_Fillet1d.cxx:896
Set/Get parameter.
Definition: GEOMImpl_Fillet1d.hxx:100
Remove solution by index.
Definition: GEOMImpl_Fillet1d.cxx:911
Puiblic methods.
Definition: GEOMImpl_Fillet1d.hxx:92
Standard_Boolean ComputeDifference(GEOMImpl_Fillet1dPoint *)
compute difference between this and given point
Definition: GEOMImpl_Fillet1d.cxx:722
GEOMImpl_Fillet1dPoint * Copy()
Make copy of point WARNING: Copies only field values: myParam, myV, myD, myValid.
Definition: GEOMImpl_Fillet1d.cxx:879
GEOMImpl_Fillet1d is 1D fillet algorithm on two planar edges with given radius.
Definition: GEOMImpl_Fillet1d.hxx:44
Makes fillet with given radius.
Definition: GEOMImpl_Fillet1d.cxx:262
GEOMImpl_Fillet1d(const TopoDS_Edge &theEdge1, const TopoDS_Edge &theEdge2, const gp_Pln &thePlane)
Constructor The fillet 1D algorithm is initialised by two edges and plane.
Definition: GEOMImpl_Fillet1d.cxx:101
TopoDS_Edge Result(const gp_Pnt &thePoint, TopoDS_Edge &theEdge1, TopoDS_Edge &theEdge2)
Returns result fillet edge and modified edges as out parameters.
Definition: GEOMImpl_Fillet1d.cxx:570
