GEOMImpl_Fillet1dPoint Class Reference
GEOMImpl_Fillet1dPoint is an internal class for 1D fillet algorithm to store and compare computed solutions on edges. More...
#include <GEOMImpl_Fillet1d.hxx>
 GEOMImpl_Fillet1dPoint (Standard_Real theParam)
 Puiblic methods. More...
GEOMImpl_Fillet1dPoint * Copy ()
 Make copy of point WARNING: Copies only field values: myParam, myV, myD, myValid. More...
void SetParam (Standard_Real theParam)
 Set/Get parameter. More...
Standard_Real GetParam () const
void SetParam2 (const Standard_Real theParam2)
Standard_Real GetParam2 ()
Standard_Boolean IsValid (int theIndex)
 Returns validity. More...
Standard_Integer GetNBValues ()
 Get values. More...
Standard_Real GetValue (Standard_Integer theIndex)
Standard_Real GetDiff (Standard_Integer theIndex)
Standard_Integer GetNear (Standard_Integer theIndex)
void SetCenter (const gp_Pnt2d thePoint)
 Set/Get center point. More...
const gp_Pnt2d GetCenter ()
void AddValue (Standard_Real theValue, Standard_Boolean theIsValid)
Standard_Boolean ComputeDifference (GEOMImpl_Fillet1dPoint *)
 compute difference between this and given point More...
void FilterPoints (GEOMImpl_Fillet1dPoint *)
Standard_Integer HasSolution (Standard_Real theRadius)
 Checks if point contains solution and returns the index of it if any. More...
void RemoveSolution (Standard_Integer theIndex)
 Remove solution by index. More...
◆ GEOMImpl_Fillet1dPoint()
GEOMImpl_Fillet1dPoint::GEOMImpl_Fillet1dPoint ( Standard_Real  theParam)
Puiblic methods.
Constructor
◆ Copy()
GEOMImpl_Fillet1dPoint * GEOMImpl_Fillet1dPoint::Copy ( )
◆ SetParam()
void GEOMImpl_Fillet1dPoint::SetParam ( Standard_Real  theParam)
Set/Get parameter.
◆ IsValid()
Standard_Boolean GEOMImpl_Fillet1dPoint::IsValid ( int  theIndex)
Returns validity.
◆ GetNBValues()
Standard_Integer GEOMImpl_Fillet1dPoint::GetNBValues ( )
Get values.
◆ SetCenter()
void GEOMImpl_Fillet1dPoint::SetCenter ( const gp_Pnt2d  thePoint)
◆ ComputeDifference()
Standard_Boolean GEOMImpl_Fillet1dPoint::ComputeDifference ( GEOMImpl_Fillet1dPoint *  thePoint)
◆ HasSolution()
Standard_Integer GEOMImpl_Fillet1dPoint::HasSolution ( Standard_Real  theRadius)
◆ RemoveSolution()
void GEOMImpl_Fillet1dPoint::RemoveSolution ( Standard_Integer  theIndex)
