GeomAPI_Lin2d.h
20#ifndef GeomAPI_Lin2d_H_
21#define GeomAPI_Lin2d_H_
23#include <GeomAPI_Interface.h>
24#include <memory>
26class GeomAPI_Dir2d;
27class GeomAPI_Pnt2d;
28
35{
36 public:
38 GEOMAPI_EXPORT
39 GeomAPI_Lin2d(const double theStartX, const double theStartY, const double theEndX,
40 const double theEndY);
42 GEOMAPI_EXPORT
43 GeomAPI_Lin2d(const std::shared_ptr<GeomAPI_Pnt2d>& theStart,
44 const std::shared_ptr<GeomAPI_Pnt2d>& theEnd);
46 GEOMAPI_EXPORT
47 GeomAPI_Lin2d(const std::shared_ptr<GeomAPI_Pnt2d>& theOrigin,
48 const std::shared_ptr<GeomAPI_Dir2d>& theDirection);
49
51 GEOMAPI_EXPORT
52 std::shared_ptr<GeomAPI_Pnt2d> location();
53
55 GEOMAPI_EXPORT
56 std::shared_ptr<GeomAPI_Dir2d> direction();
57
59 GEOMAPI_EXPORT
60 double distance(const std::shared_ptr<GeomAPI_Pnt2d>& theOther) const;
62 GEOMAPI_EXPORT
63 const std::shared_ptr<GeomAPI_Pnt2d> intersect(
64 const std::shared_ptr<GeomAPI_Lin2d>& theLine) const;
66 GEOMAPI_EXPORT
67 const std::shared_ptr<GeomAPI_Pnt2d> project(
68 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint) const;
71 GEOMAPI_EXPORT
72 bool isRight(const std::shared_ptr<GeomAPI_Pnt2d>& thePoint) const;
73
75 GEOMAPI_EXPORT
76 std::shared_ptr<GeomAPI_Pnt2d> shiftedLocation(double theShift) const;
77};
78
79
81typedef std::shared_ptr<GeomAPI_Lin2d> GeomLine2dPtr;
82
83#endif
84
2D direction defined by three normalized coordinates
Definition: GeomAPI_Dir2d.h:34
Line in 2D.
Definition: GeomAPI_Lin2d.h:35
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir2d > direction()
Returns a line direction.
Definition: GeomAPI_Lin2d.cpp:68
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > location()
Returns point on the line (first point)
Definition: GeomAPI_Lin2d.cpp:62
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > project(const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const
Project point on line.
Definition: GeomAPI_Lin2d.cpp:89
GEOMAPI_EXPORT double distance(const std::shared_ptr< GeomAPI_Pnt2d > &theOther) const
Distance between two points.
Definition: GeomAPI_Lin2d.cpp:74
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > shiftedLocation(double theShift) const
Returns a location point shifted on theShift in perpendicular direction.
Definition: GeomAPI_Lin2d.cpp:111
GEOMAPI_EXPORT GeomAPI_Lin2d(const double theStartX, const double theStartY, const double theEndX, const double theEndY)
Creation of line defined by coordinates of start and end points.
Definition: GeomAPI_Lin2d.cpp:42
GEOMAPI_EXPORT bool isRight(const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const
Computes the cross product of the line direction and a vector from the line start point to the point.
Definition: GeomAPI_Lin2d.cpp:101
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > intersect(const std::shared_ptr< GeomAPI_Lin2d > &theLine) const
Intersection of two lines.
Definition: GeomAPI_Lin2d.cpp:79
