GeomAPI_Lin2d Class Reference
Line in 2D. More...
#include <GeomAPI_Lin2d.h>
Inheritance diagram for GeomAPI_Lin2d:
GEOMAPI_EXPORT GeomAPI_Lin2d (const double theStartX, const double theStartY, const double theEndX, const double theEndY)
 Creation of line defined by coordinates of start and end points. More...
GEOMAPI_EXPORT GeomAPI_Lin2d (const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd)
 Creation of line defined by start and end points. More...
GEOMAPI_EXPORT GeomAPI_Lin2d (const std::shared_ptr< GeomAPI_Pnt2d > &theOrigin, const std::shared_ptr< GeomAPI_Dir2d > &theDirection)
 Creation of line defined by origin and direction. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > location ()
 Returns point on the line (first point) More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir2d > direction ()
 Returns a line direction. More...
GEOMAPI_EXPORT double distance (const std::shared_ptr< GeomAPI_Pnt2d > &theOther) const
 Distance between two points. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > intersect (const std::shared_ptr< GeomAPI_Lin2d > &theLine) const
 Intersection of two lines. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > project (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const
 Project point on line. More...
GEOMAPI_EXPORT bool isRight (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const
 Computes the cross product of the line direction and a vector from the line start point to the point. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > shiftedLocation (double theShift) const
 Returns a location point shifted on theShift in perpendicular direction. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
Line in 2D.
◆ GeomAPI_Lin2d() [1/3]
GeomAPI_Lin2d::GeomAPI_Lin2d ( const double  theStartX,
◆ GeomAPI_Lin2d() [2/3]
GeomAPI_Lin2d::GeomAPI_Lin2d ( const std::shared_ptr< GeomAPI_Pnt2d > &  theStart,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEnd
◆ GeomAPI_Lin2d() [3/3]
GeomAPI_Lin2d::GeomAPI_Lin2d ( const std::shared_ptr< GeomAPI_Pnt2d > &  theOrigin,
const std::shared_ptr< GeomAPI_Dir2d > &  theDirection
◆ location()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Lin2d::location ( )
◆ direction()
std::shared_ptr< GeomAPI_Dir2d > GeomAPI_Lin2d::direction ( )
◆ distance()
double GeomAPI_Lin2d::distance ( const std::shared_ptr< GeomAPI_Pnt2d > &  theOther) const
◆ intersect()
const std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Lin2d::intersect ( const std::shared_ptr< GeomAPI_Lin2d > &  theLine) const
◆ project()
const std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Lin2d::project ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint) const
◆ isRight()
bool GeomAPI_Lin2d::isRight ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint) const
◆ shiftedLocation()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Lin2d::shiftedLocation ( double  theShift) const
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
