GeomAlgoAPI_Rotation.h
20#ifndef GeomAlgoAPI_Rotation_H_
21#define GeomAlgoAPI_Rotation_H_
23#include <GeomAlgoAPI.h>
24#include <GeomAlgoAPI_Transform.h>
26class GeomAPI_Ax1;
27class GeomAPI_Pnt;
28
33{
34public:
40 GEOMALGOAPI_EXPORT GeomAlgoAPI_Rotation(std::shared_ptr<GeomAPI_Shape> theSourceShape,
41 std::shared_ptr<GeomAPI_Ax1> theAxis,
42 double theAngle);
43
50 GEOMALGOAPI_EXPORT GeomAlgoAPI_Rotation(std::shared_ptr<GeomAPI_Shape> theSourceShape,
51 std::shared_ptr<GeomAPI_Pnt> theCenterPoint,
52 std::shared_ptr<GeomAPI_Pnt> theStartPoint,
53 std::shared_ptr<GeomAPI_Pnt> theEndPoint);
54};
55
56#endif
The class represents an axis in 3D space.
Definition: GeomAPI_Ax1.h:31
Definition: GeomAPI_Pnt.h:38
Creates a copy of the object by rotating it around the axis.
Definition: GeomAlgoAPI_Rotation.h:33
GEOMALGOAPI_EXPORT GeomAlgoAPI_Rotation(std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, double theAngle)
Creates an object which is obtained from current object by rotating it around the axis with the angle...
Definition: GeomAlgoAPI_Rotation.cpp:35
Creates a copy of the object by transformating it.
Definition: GeomAlgoAPI_Transform.h:33
