GeomAlgoAPI_Rotation Class Reference
Creates a copy of the object by rotating it around the axis. More...
#include <GeomAlgoAPI_Rotation.h>
Inheritance diagram for GeomAlgoAPI_Rotation:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Rotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, double theAngle)
 Creates an object which is obtained from current object by rotating it around the axis with the angle. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Rotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, std::shared_ptr< GeomAPI_Pnt > theStartPoint, std::shared_ptr< GeomAPI_Pnt > theEndPoint)
 Creates an object which is obtained from current object by rotating it around the axis with angle using the center and two points. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
void build (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Trsf > theTrsf)
 Builds resulting shape. More...
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Rotation() [1/2]
GeomAlgoAPI_Rotation::GeomAlgoAPI_Rotation ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
double  theAngle
[in]theSourceShapea shape to be rotated.
[in]theAxisrotation axis.
[in]theAnglerotation angle(in degree).
◆ GeomAlgoAPI_Rotation() [2/2]
[in]theCenterPointcenter point.
[in]theStartPointstart point.
[in]theEndPointend point.
◆ build() [1/2]
void GeomAlgoAPI_Transform::build ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
◆ build() [2/2]
inlinevirtualinherited
◆ initialize()
template<class T >
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
