ModelAPI_AttributeDocRef.h
20#ifndef ModelAPI_AttributeDocRef_H_
21#define ModelAPI_AttributeDocRef_H_
23#include "ModelAPI_Attribute.h"
24#include "ModelAPI_Document.h"
32{
33 public:
35 MODELAPI_EXPORT virtual void setValue(std::shared_ptr<ModelAPI_Document> theDoc) = 0;
36
38 MODELAPI_EXPORT virtual std::shared_ptr<ModelAPI_Document> value() = 0;
39
41 MODELAPI_EXPORT virtual int docId() = 0;
42
44 MODELAPI_EXPORT static std::string typeId()
45 {
46 return "DocRef";
47 }
48
50 MODELAPI_EXPORT virtual std::string attributeType();
51
53 MODELAPI_EXPORT virtual ~ModelAPI_AttributeDocRef();
54
55 protected:
57 MODELAPI_EXPORT ModelAPI_AttributeDocRef();
58};
59
60typedef std::shared_ptr<ModelAPI_AttributeDocRef> AttributeDocRefPtr;
61
62#endif
Attribute that contains reference to another document.
Definition: ModelAPI_AttributeDocRef.h:32
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeDocRef.cpp:22
virtual void setValue(std::shared_ptr< ModelAPI_Document > theDoc)=0
Defines the document referenced from this attribute.
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeDocRef.h:44
virtual int docId()=0
Returns the persistent ID of the document.
Definition: ModelAPI_AttributeDocRef.cpp:31
virtual std::shared_ptr< ModelAPI_Document > value()=0
Returns document referenced from this attribute.
To virtually destroy the fields of successors.
Definition: ModelAPI_AttributeDocRef.cpp:27
