ModelAPI_AttributeImage.h
20#ifndef ModelAPI_AttributeImage_H_
21#define ModelAPI_AttributeImage_H_
23#include <ModelAPI.h>
24#include <ModelAPI_Attribute.h>
26#include <string>
27#include <list>
28
37{
38 public:
40 MODELAPI_EXPORT virtual void setTexture(const int theWidth,
41 const int theHeight,
42 const std::list<unsigned char>& theByteArray,
43 const std::string& theFormat,
44 const bool sendUpdated = true) = 0;
45
47 MODELAPI_EXPORT virtual bool hasTexture() = 0;
48
50 MODELAPI_EXPORT virtual bool texture(int& theWidth,
51 int& theHeight,
52 std::list<unsigned char>& theByteArray,
53 std::string& theFormat) = 0;
54
56 virtual void copyTo(std::shared_ptr<ModelAPI_AttributeImage> theTarget) const = 0;
57
59 MODELAPI_EXPORT static std::string typeId()
60 {
61 return "Image";
62 }
63
65 MODELAPI_EXPORT virtual std::string attributeType();
66
68 MODELAPI_EXPORT virtual ~ModelAPI_AttributeImage();
69
70 protected:
72 MODELAPI_EXPORT ModelAPI_AttributeImage();
73};
74
76typedef std::shared_ptr<ModelAPI_AttributeImage> AttributeImagePtr;
77
78#endif
API for the attribute that contains binary data.
Definition: ModelAPI_AttributeImage.h:37
virtual MODELAPI_EXPORT ~ModelAPI_AttributeImage()
To virtually destroy the fields of successors.
Definition: ModelAPI_AttributeImage.cpp:29
virtual MODELAPI_EXPORT void setTexture(const int theWidth, const int theHeight, const std::list< unsigned char > &theByteArray, const std::string &theFormat, const bool sendUpdated=true)=0
Defines the value of the image attribute.
virtual MODELAPI_EXPORT std::string attributeType()
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeImage.cpp:23
virtual MODELAPI_EXPORT bool texture(int &theWidth, int &theHeight, std::list< unsigned char > &theByteArray, std::string &theFormat)=0
Returns the value of the image attribute.
virtual MODELAPI_EXPORT bool hasTexture()=0
Returns true, if texture width and height are non-zero.
Definition: ModelAPI_AttributeImage.cpp:33
virtual void copyTo(std::shared_ptr< ModelAPI_AttributeImage > theTarget) const =0
Copy the image data to the destination attribute.
static MODELAPI_EXPORT std::string typeId()
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeImage.h:59
