ModelAPI_AttributeInteger.h
20#ifndef MODELAPI_ATTRIBUTEINTEGER_H_
21#define MODELAPI_ATTRIBUTEINTEGER_H_
23#include <ModelAPI_Attribute.h>
24
25#include <set>
26#include <string>
27
34{
35 public:
37 MODELAPI_EXPORT virtual void setValue(const int theValue) = 0;
38
40 MODELAPI_EXPORT virtual int value() = 0;
41
43 MODELAPI_EXPORT virtual void setCalculatedValue(const int theValue) = 0;
44
46 MODELAPI_EXPORT virtual void setText(const std::wstring& theText) = 0;
47
49 MODELAPI_EXPORT virtual std::wstring text() = 0;
50
52 MODELAPI_EXPORT virtual void setExpressionInvalid(const bool theFlag) = 0;
53
55 MODELAPI_EXPORT virtual bool expressionInvalid() = 0;
56
58 MODELAPI_EXPORT virtual void setExpressionError(const std::string& theError) = 0;
59
61 MODELAPI_EXPORT virtual std::string expressionError() = 0;
62
64 MODELAPI_EXPORT virtual
65 void setUsedParameters(const std::set<std::wstring>& theUsedParameters) = 0;
66
68 MODELAPI_EXPORT virtual std::set<std::wstring> usedParameters() const = 0;
69
71 MODELAPI_EXPORT static std::string typeId()
72 {
73 return "Integer";
74 }
75
77 MODELAPI_EXPORT virtual std::string attributeType();
78
80 MODELAPI_EXPORT virtual ~ModelAPI_AttributeInteger();
81
82 protected:
84 MODELAPI_EXPORT ModelAPI_AttributeInteger();
85};
86
88typedef std::shared_ptr<ModelAPI_AttributeInteger> AttributeIntegerPtr;
89
90#endif
API for the attribute that contains integer (int).
Definition: ModelAPI_AttributeInteger.h:34
virtual MODELAPI_EXPORT bool expressionInvalid()=0
Returns true if text is invalid.
virtual MODELAPI_EXPORT std::string attributeType()
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeInteger.cpp:23
virtual MODELAPI_EXPORT int value()=0
Returns the integer value.
virtual MODELAPI_EXPORT void setText(const std::wstring &theText)=0
Defines the text value.
virtual MODELAPI_EXPORT std::set< std::wstring > usedParameters() const =0
Returns the used parameters.
static MODELAPI_EXPORT std::string typeId()
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeInteger.h:71
virtual MODELAPI_EXPORT void setUsedParameters(const std::set< std::wstring > &theUsedParameters)=0
Defines the used parameters.
virtual MODELAPI_EXPORT void setCalculatedValue(const int theValue)=0
Defines the calculated value.
virtual MODELAPI_EXPORT void setValue(const int theValue)=0
Defines the integer value.
virtual MODELAPI_EXPORT void setExpressionError(const std::string &theError)=0
Allows to set expression (text) error (by the parameters listener)
virtual MODELAPI_EXPORT std::wstring text()=0
Returns the text value.
Definition: ModelAPI_AttributeInteger.cpp:33
virtual MODELAPI_EXPORT void setExpressionInvalid(const bool theFlag)=0
Allows to set expression (text) as invalid (by the parameters listener)
virtual MODELAPI_EXPORT std::string expressionError()=0
Returns an expression error.
virtual MODELAPI_EXPORT ~ModelAPI_AttributeInteger()
To virtually destroy the fields of successors.
Definition: ModelAPI_AttributeInteger.cpp:29
