Model_AttributeDocRef.h
20#ifndef Model_AttributeDocRef_H_
21#define Model_AttributeDocRef_H_
23#include "Model.h"
24#include "ModelAPI_AttributeDocRef.h"
25#include <TDataStd_Integer.hxx>
26#include <TDF_Label.hxx>
27
34{
36 Handle(TDataStd_Integer) myID;
37 public:
38
40 MODEL_EXPORT virtual void setValue(std::shared_ptr<ModelAPI_Document> theDoc);
41
43 MODEL_EXPORT virtual std::shared_ptr<ModelAPI_Document> value();
44
46 MODEL_EXPORT virtual int docId();
47
48 protected:
50 Model_AttributeDocRef(TDF_Label& theLabel);
51
53 virtual void reinit();
54
55 friend class Model_Data;
56};
57
58#endif
Attribute that contains reference to another document.
Definition: ModelAPI_AttributeDocRef.h:32
Definition: Model_AttributeDocRef.h:34
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeDocRef.cpp:53
virtual void setValue(std::shared_ptr< ModelAPI_Document > theDoc)
Defines the document referenced from this attribute.
Definition: Model_AttributeDocRef.cpp:25
Model_AttributeDocRef(TDF_Label &theLabel)
Initializes attributes.
Definition: Model_AttributeDocRef.cpp:43
virtual std::shared_ptr< ModelAPI_Document > value()
Returns document referenced from this attribute.
Definition: Model_AttributeDocRef.cpp:33
virtual int docId()
Returns the persistent ID of the document.
Definition: Model_AttributeDocRef.cpp:38
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
