Model_ResultConstruction.h
20#ifndef Model_ResultConstruction_H_
21#define Model_ResultConstruction_H_
23#include "Model.h"
24#include <ModelAPI_ResultConstruction.h>
25#include <vector>
26
28class TDF_Label;
38{
39 std::shared_ptr<ModelAPI_Feature> myOwner;
40 std::shared_ptr<GeomAPI_Shape> myShape;
41 public:
43 MODEL_EXPORT virtual void colorConfigInfo(std::string& theSection, std::string& theName,
44 std::string& theDefault);
45
47 MODEL_EXPORT virtual bool isInHistory();
49 MODEL_EXPORT virtual void setShape(std::shared_ptr<GeomAPI_Shape> theShape);
51 MODEL_EXPORT virtual std::shared_ptr<GeomAPI_Shape> shape();
52
54 MODEL_EXPORT virtual void setIsInHistory(const bool myIsInHistory);
55
58 MODEL_EXPORT virtual int facesNum(const bool theUpdateNaming = true);
60 MODEL_EXPORT virtual std::shared_ptr<GeomAPI_Face> face(const int theIndex);
62 MODEL_EXPORT
63 virtual void setFacesOrder(const std::list<std::shared_ptr<GeomAPI_Face> >& theFaces);
64
66 MODEL_EXPORT virtual bool isInfinite();
68 MODEL_EXPORT virtual void setInfinite(const bool theInfinite);
70 MODEL_EXPORT virtual void setIsConcealed(const bool theValue, const bool theForced = false);
71
74 MODEL_EXPORT virtual bool updateShape();
75
76 protected:
79
81 void storeShape(std::shared_ptr<GeomAPI_Shape> theShape);
82
83 friend class Model_Objects;
84};
85
86#endif
The construction element result of a feature.
Definition: ModelAPI_ResultConstruction.h:37
Manager of objects of the document.
Definition: Model_Objects.h:46
Definition: Model_ResultConstruction.h:38
By default object is not infinite.
Definition: Model_ResultConstruction.cpp:205
virtual void colorConfigInfo(std::string &theSection, std::string &theName, std::string &theDefault)
Returns the parameters of color definition in the resources config manager.
Definition: Model_ResultConstruction.cpp:99
virtual std::shared_ptr< GeomAPI_Shape > shape()
Returns the shape-result produced by this feature.
Definition: Model_ResultConstruction.cpp:119
void storeShape(std::shared_ptr< GeomAPI_Shape > theShape)
Stores shape in the data structure to allow identification it by the naming.
Definition: Model_ResultConstruction.cpp:269
virtual void setFacesOrder(const std::list< std::shared_ptr< GeomAPI_Face > > &theFaces)
Change the order of faces.
Definition: Model_ResultConstruction.cpp:379
Sets the flag that it must be displayed in history (default is true)
Definition: Model_ResultConstruction.cpp:194
virtual std::shared_ptr< GeomAPI_Face > face(const int theIndex)
if the construction result may be used as faces, this method returns face by zero based index
Definition: Model_ResultConstruction.cpp:239
Sets the flag that it is infinite.
Definition: Model_ResultConstruction.cpp:214
virtual void setIsConcealed(const bool theValue, const bool theForced=false)
The construction element may be concealed only by "delete" feature.
Definition: Model_ResultConstruction.cpp:261
Updates the shape taking the current value from the data structure, returns true if update has been c...
Definition: Model_ResultConstruction.cpp:143
virtual void setShape(std::shared_ptr< GeomAPI_Shape > theShape)
Sets the result.
Definition: Model_ResultConstruction.cpp:107
virtual int facesNum(const bool theUpdateNaming=true)
if the construction result may be used as faces, this method returns not zero number of faces
Definition: Model_ResultConstruction.cpp:225
Model_ResultConstruction()
Makes a body on the given feature.
Definition: Model_ResultConstruction.cpp:181
By default object is displayed in the object browser.
Definition: Model_ResultConstruction.cpp:185
