ModuleBase_WidgetChoice.h
20#ifndef ModuleBase_WidgetChoice_H
21#define ModuleBase_WidgetChoice_H
23#include "ModuleBase.h"
24#include "ModuleBase_ModelWidget.h"
26class QWidget;
28
47class MODULEBASE_EXPORT ModuleBase_WidgetChoice : public ModuleBase_ModelWidget
48{
49Q_OBJECT
50 public:
54 ModuleBase_WidgetChoice(QWidget* theParent, const Config_WidgetAPI* theData);
55
57
60 virtual bool canAcceptFocus() const { return false; };
61
62 virtual bool focusTo();
63
66 virtual QList<QWidget*> getControls() const;
67
71 QString getPropertyPanelTitle(int theIndex);
72
74 virtual void onFeatureAccepted();
75
76signals:
80 void itemSelected(ModuleBase_ModelWidget* theWidget, int theIndex);
81
82protected:
85 virtual bool storeValueCustom();
86
87 virtual bool restoreValueCustom();
88
89private slots:
91 void onCurrentIndexChanged(int theIndex);
92
93private:
94 ModuleBase_ChoiceCtrl* myChoiceCtrl;
95
96 // XML definition of titles
97 QStringList myButtonTitles;
98 std::string myStringListAttribute;
99
100 bool myIsFirst;
101 int myDefValue;
102 bool myHasValue;
103};
104
105#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
A Choice control.
Definition: ModuleBase_ChoiceCtrl.h:42
An abstract custom widget class.
Definition: ModuleBase_ModelWidget.h:60
virtual QList< QWidget * > getControls() const =0
Returns list of widget controls.
virtual bool storeValueCustom()=0
Saves the internal parameters to the given feature.
virtual bool restoreValueCustom()=0
Restore value from attribute data to the widget's control.
It is called when user press Ok or OkPlus buttons in the parent property panel By default this slot d...
Definition: ModuleBase_ModelWidget.h:315
Set focus to the first control of the current widget.
Definition: ModuleBase_ModelWidget.cpp:267
Implementation of model widget for choice widget definition (combo box) It can be defined as followin...
Definition: ModuleBase_WidgetChoice.h:48
Defines if it is supported to set the value in this widget It returns false because this is an info w...
Definition: ModuleBase_WidgetChoice.h:60
void itemSelected(ModuleBase_ModelWidget *theWidget, int theIndex)
Segnal about selected item.
