An abstract custom widget class. More...
#include <ModuleBase_ModelWidget.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_ModelWidget (QWidget *theParent, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual | ~ModuleBase_ModelWidget () |
| Destructor. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| virtual QList< QWidget * > | getControls () const =0 |
| Returns True if data of its attribute was modified. More... | |
Protected Slots | |
| virtual bool | storeValueCustom ()=0 |
| virtual bool | restoreValueCustom ()=0 |
Protected Attributes | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
This class realization is assumed to create some controls. The controls values modification should send signal about values change.
Common interface for widgets in the property panel. Every widget are able to save/restore data from the model and/or to contain other widgets.
| ModuleBase_ModelWidget::ModuleBase_ModelWidget | ( | QWidget * | theParent, |
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theData | the widget configuration. The attribute of the model widget is obtained from a low-level API for reading xml definitions of widgets |
| bool ModuleBase_ModelWidget::reset | ( | ) |
| bool ModuleBase_ModelWidget::isInitialized | ( | ObjectPtr | theObject | ) | const |
| [out] | theSelectionFilters | selection filters |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
| void ModuleBase_ModelWidget::processValueState | ( | ) |
| Events_InfoMessage ModuleBase_ModelWidget::getValueStateError | ( | ) | const |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inline |
| bool ModuleBase_ModelWidget::restoreValue | ( | ) |
| bool ModuleBase_ModelWidget::storeValue | ( | ) |
inlinevirtual |
| void ModuleBase_ModelWidget::activate | ( | ) |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlinevirtual |
inlinevirtual |
inlinevirtual |
pure virtual |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
| QWidget * ModuleBase_ModelWidget::getControlAcceptingFocus | ( | const bool | isFirst | ) |
inline |
inline |
inlinevirtual |
inlinevirtual |
inline |
inlinevirtual |
| void ModuleBase_ModelWidget::updateObject | ( | ObjectPtr | theObj | ) |
inline |
static |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
By default does nothing
inlinevirtual |
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inline |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
protected |
inlineprotected |
protected |
| theState | a new state |
protected |
protectedvirtual |
protectedpure virtual |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ModuleBase_WidgetUndoLabel, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
inlineprotectedvirtual |
Reimplemented in ModuleBase_PagedContainer, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ParametersPlugin_WidgetParamsMgr, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, and PartSet_WidgetSketchLabel.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedslot |
protectedslot |
protected |
protected |
protected |
protected |
A feature ID.
protected |
protected |
protected |
