ModuleBase_WidgetValidator Class Reference
Implementation of widget with validators and filters processing. More...
#include <ModuleBase_WidgetValidator.h>
 ModuleBase_WidgetValidator (ModuleBase_ModelWidget *theModelWidget, ModuleBase_IWorkshop *theWorkshop)
virtual void selectionModes (int &, QIntList &)
 Fills given container with selection modes if the widget has it. More...
virtual void selectionFilters (QIntList &theModuleSelectionFilters, SelectMgr_ListOfFilter &theSelectionFilters)
 Appends into container of workshop selection filters. More...
bool isInValidate () const
 Returns true if the validation is activated. More...
virtual bool isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
 Checks all widget validator if the owner is valid. More...
virtual void storeAttributeValue (const std::shared_ptr< ModelAPI_Attribute > &theAttribute)
 Creates a backup of the current values of the attribute. More...
virtual void restoreAttributeValue (const std::shared_ptr< ModelAPI_Attribute > &theAttribute, const bool theValid)
 Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More...
bool isValidAttribute (const std::shared_ptr< ModelAPI_Attribute > &theAttribute) const
 Checks the current attribute in all attribute validators. More...
void clearValidatedCash ()
 Clear all validated cash in the widget. More...
bool myIsInValidate
 cashed if the value is processed in validation More...
ModuleBase_ModelWidget * myModelWidget
 Reference to workshop. More...
ModuleBase_IWorkshop * myWorkshop
 the active workshop More...
ModuleBase_WidgetSelectorStore * myAttributeStore
 store/restore attribute values More...
QList< std::shared_ptr< ModuleBase_ViewerPrs > > myValidPrs
 cash of valid selection presentations More...
QList< std::shared_ptr< ModuleBase_ViewerPrs > > myInvalidPrs
 cash of invalid selection presentations More...
◆ ModuleBase_WidgetValidator()
ModuleBase_WidgetValidator::ModuleBase_WidgetValidator ( ModuleBase_ModelWidget *  theModelWidget,
ModuleBase_IWorkshop *  theWorkshop
theModelWidgetthe model widget to be validated
theWorkshopthe current workshop
◆ selectionModes()
virtual void ModuleBase_WidgetValidator::selectionModes ( int &  ,
QIntList &
[out]theModuleSelectionModesmodule additional modes, -1 means all default modes
theModes[out] a container of modes
◆ selectionFilters()
void ModuleBase_WidgetValidator::selectionFilters ( QIntList &  theModuleSelectionFilters,
SelectMgr_ListOfFilter &  theSelectionFilters
[out]theModuleSelectionFiltersmodule additional modes, -1 means all default modes
[out]selectionfilters
◆ isInValidate()
bool ModuleBase_WidgetValidator::isInValidate ( ) const
◆ isValidSelection()
bool ModuleBase_WidgetValidator::isValidSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue)
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
theValuea selected presentation in the view
a boolean value
◆ storeAttributeValue()
void ModuleBase_WidgetValidator::storeAttributeValue ( const std::shared_ptr< ModelAPI_Attribute > &  theAttribute)
theAttributean attribute to be stored
◆ restoreAttributeValue()
void ModuleBase_WidgetValidator::restoreAttributeValue ( const std::shared_ptr< ModelAPI_Attribute > &  theAttribute,
const bool  theValid
theAttributean attribute to be restored
theValida boolean flag, if restore happens for valid parameters
◆ isValidAttribute()
bool ModuleBase_WidgetValidator::isValidAttribute ( const std::shared_ptr< ModelAPI_Attribute > &  theAttribute) const
theAttributean attribute to be validated
true if all validators return that the attribute is valid
◆ clearValidatedCash()
void ModuleBase_WidgetValidator::clearValidatedCash ( )
◆ myIsInValidate
bool ModuleBase_WidgetValidator::myIsInValidate
◆ myModelWidget
ModuleBase_ModelWidget* ModuleBase_WidgetValidator::myModelWidget
the current widget to be validated
◆ myWorkshop
ModuleBase_IWorkshop* ModuleBase_WidgetValidator::myWorkshop
the active workshop
◆ myAttributeStore
ModuleBase_WidgetSelectorStore* ModuleBase_WidgetValidator::myAttributeStore
◆ myValidPrs
QList<std::shared_ptr<ModuleBase_ViewerPrs> > ModuleBase_WidgetValidator::myValidPrs
◆ myInvalidPrs
QList<std::shared_ptr<ModuleBase_ViewerPrs> > ModuleBase_WidgetValidator::myInvalidPrs
