ModuleBase_IWorkshop Class Referenceabstract
Class which provides access to Workshop object services. More...
#include <ModuleBase_IWorkshop.h>
Inheritance diagram for ModuleBase_IWorkshop:
Signals
void selectionChanged ()
 Signal selection changed. More...
void propertyPanelActivated ()
 Signal which is emitted after activation of property panel. More...
 ModuleBase_IWorkshop (QObject *theParent)
virtual ModuleBase_ISelection * selection () const =0
 Return current selection instance. More...
virtual ModuleBase_IModule * module () const =0
 Returns instance of loaded module. More...
virtual ModuleBase_IViewer * viewer () const =0
 Returns current viewer. More...
virtual ModuleBase_IPropertyPanel * propertyPanel () const =0
 Returns property panel. More...
virtual ModuleBase_IErrorMgr * errorMgr () const =0
 Returns error manager. More...
Handle validatorFilter ()
 A filter to process an attribute validators. More...
virtual ModuleBase_ISelectionActivate * selectionActivate () const =0
 A selection activate in 3D View handler. More...
virtual ModuleBase_Operation * currentOperation () const =0
 Returns currently active operation. More...
virtual bool canStartOperation (QString theId, bool &isCommitted)=0
 Returns true if the operation with id theId can be started. More...
virtual void processLaunchOperation (ModuleBase_Operation *theOperation)=0
 Performs the operation launch. More...
virtual ModuleBase_Operation * findStartedOperation (const QString &theId)=0
 Returns started operation by the operation identifier. More...
virtual bool canStopOperation (ModuleBase_Operation *theOperation)=0
 Returns true if the operation with id theId can be stopped. More...
virtual void stopOperation (ModuleBase_Operation *theOperation, bool &isCommitted)=0
 Commits if possible or aborts the given operation. More...
virtual AISObjectPtr findPresentation (const ObjectPtr &theObject) const =0
 Returns AIS object by data object. More...
virtual ObjectPtr findPresentedObject (const AISObjectPtr &theAIS) const =0
 Returns data object by AIS. More...
virtual bool isVisible (const ObjectPtr &theObject) const =0
 Returns true if the object is displayed. More...
virtual QObjectPtrList displayedObjects () const =0
 Returns list of currently displayed objects. More...
virtual void setSelected (const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)=0
 Select features clearing previous selection. More...
virtual void setStatusBarMessage (const QString &theMessage)=0
 Shows the message in the status bar. More...
virtual void updateCommandStatus ()=0
 Update of commands status. More...
virtual std::shared_ptr< Config_FeatureMessage > featureInfo (const QString &theId) const =0
 Returns feature info according to given feature ID. More...
virtual QMainWindow * desktop () const =0
 Returns main window of the application. More...
virtual bool hasSHIFTPressed () const =0
 Returns true if SHIFT is pressed. More...
virtual void deactivateCurrentSelector ()=0
virtual bool enableUpdateViewer (bool isEnabled)=0
 Temporary enable or disable viewer update. More...
virtual void applyCurrentSelectionModes (const AISObjectPtr &theAIS)=0
 The methods applies current defined selection modes to given AIS presentation. More...
virtual void undo ()=0
 Undo last command. More...
virtual void setCancelEnabled (bool toEnable)=0
 Set enabled state of cancel button in property panel. More...
virtual bool isCancelEnabled () const =0
 Returns current state of cancel button. More...
virtual void showHelpPage (const QString &thePage) const =0
 Show help of a current operation. More...
Handle myValidatorFilter
◆ ModuleBase_IWorkshop()
ModuleBase_IWorkshop::ModuleBase_IWorkshop ( QObject *  theParent)
theParentparent object
◆ selection()
virtual ModuleBase_ISelection * ModuleBase_IWorkshop::selection ( ) const
pure virtual
Implemented in XGUI_ModuleConnector.
◆ module()
virtual ModuleBase_IModule * ModuleBase_IWorkshop::module ( ) const
pure virtual
◆ viewer()
virtual ModuleBase_IViewer * ModuleBase_IWorkshop::viewer ( ) const
pure virtual
◆ propertyPanel()
virtual ModuleBase_IPropertyPanel * ModuleBase_IWorkshop::propertyPanel ( ) const
pure virtual
◆ errorMgr()
virtual ModuleBase_IErrorMgr * ModuleBase_IWorkshop::errorMgr ( ) const
pure virtual
◆ validatorFilter()
Handle ModuleBase_IWorkshop::validatorFilter ( )
a filter
◆ selectionActivate()
virtual ModuleBase_ISelectionActivate * ModuleBase_IWorkshop::selectionActivate ( ) const
pure virtual
◆ currentOperation()
virtual ModuleBase_Operation * ModuleBase_IWorkshop::currentOperation ( ) const
pure virtual
◆ canStartOperation()
virtual bool ModuleBase_IWorkshop::canStartOperation ( QString  theId,
bool &  isCommitted
pure virtual
◆ processLaunchOperation()
virtual void ModuleBase_IWorkshop::processLaunchOperation ( ModuleBase_Operation *  theOperation)
pure virtual
theOperationan operation to be launched
◆ findStartedOperation()
virtual ModuleBase_Operation * ModuleBase_IWorkshop::findStartedOperation ( const QString &  theId)
pure virtual
theIdan operation id
an operation instance or NULL
◆ canStopOperation()
virtual bool ModuleBase_IWorkshop::canStopOperation ( ModuleBase_Operation *  theOperation)
pure virtual
theOperationa stopped operation
boolean result
◆ stopOperation()
virtual void ModuleBase_IWorkshop::stopOperation ( ModuleBase_Operation *  theOperation,
bool &  isCommitted
pure virtual
theOperationan aborted operation
isCommittedboolean value if the operation was committed otherwise it was aborted
◆ findPresentation()
virtual AISObjectPtr ModuleBase_IWorkshop::findPresentation ( const ObjectPtr &  theObject) const
pure virtual
theObjecta data object
◆ findPresentedObject()
virtual ObjectPtr ModuleBase_IWorkshop::findPresentedObject ( const AISObjectPtr &  theAIS) const
pure virtual
theAISa presentation
◆ isVisible()
virtual bool ModuleBase_IWorkshop::isVisible ( const ObjectPtr &  theObject) const
pure virtual
◆ displayedObjects()
virtual QObjectPtrList ModuleBase_IWorkshop::displayedObjects ( ) const
pure virtual
◆ setSelected()
virtual void ModuleBase_IWorkshop::setSelected ( const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
pure virtual
If the list is empty then selection will be cleared
◆ setStatusBarMessage()
virtual void ModuleBase_IWorkshop::setStatusBarMessage ( const QString &  theMessage)
pure virtual
theMessagea message
◆ updateCommandStatus()
virtual void ModuleBase_IWorkshop::updateCommandStatus ( )
pure virtual
◆ featureInfo()
virtual std::shared_ptr< Config_FeatureMessage > ModuleBase_IWorkshop::featureInfo ( const QString &  theId) const
pure virtual
theIda feature Id
◆ desktop()
virtual QMainWindow * ModuleBase_IWorkshop::desktop ( ) const
pure virtual
◆ hasSHIFTPressed()
virtual bool ModuleBase_IWorkshop::hasSHIFTPressed ( ) const
pure virtual
boolean value
◆ enableUpdateViewer()
virtual bool ModuleBase_IWorkshop::enableUpdateViewer ( bool  isEnabled)
pure virtual
Returns previous state of updating
isEnablednew state of the viewer update
◆ applyCurrentSelectionModes()
virtual void ModuleBase_IWorkshop::applyCurrentSelectionModes ( const AISObjectPtr &  theAIS)
pure virtual
The AIS presentation has to be already displayed. After activation viewer has to be updated
theAISthe object which has to be activated
◆ undo()
virtual void ModuleBase_IWorkshop::undo ( )
pure virtual
Undo last command.
◆ setCancelEnabled()
virtual void ModuleBase_IWorkshop::setCancelEnabled ( bool  toEnable)
pure virtual
◆ isCancelEnabled()
virtual bool ModuleBase_IWorkshop::isCancelEnabled ( ) const
pure virtual
◆ showHelpPage()
virtual void ModuleBase_IWorkshop::showHelpPage ( const QString &  thePage) const
pure virtual
◆ selectionChanged
void ModuleBase_IWorkshop::selectionChanged ( )
signal
◆ propertyPanelActivated
void ModuleBase_IWorkshop::propertyPanelActivated ( )
signal
◆ myValidatorFilter
Handle ModuleBase_IWorkshop::myValidatorFilter
