ModuleBase_IPropertyPanel Class Referenceabstract
A class for Property panel object definition. More...
#include <ModuleBase_IPropertyPanel.h>
Inheritance diagram for ModuleBase_IPropertyPanel:
Public Slots
virtual void activateNextWidget (ModuleBase_ModelWidget *theWidget)=0
 Activate the next widget in the property panel. More...
virtual void activateNextWidget ()=0
 Activate the next from current widget in the property panel. More...
virtual void activateWidget (ModuleBase_ModelWidget *theWidget, const bool theEmitSignal=true)=0
 Makes the given widget active, highlights it and removes highlighting from the previous active widget. More...
Signals
void keyReleased (QObject *theObject, QKeyEvent *theEvent)
 The signal about key release on the control, that corresponds to the attribute. More...
void beforeWidgetActivated (ModuleBase_ModelWidget *theWidget)
 The signal about the widget activation. More...
void noMoreWidgets (const std::string &thePreviousAttributeID)
 ModuleBase_IPropertyPanel (QWidget *theParent)
virtual QWidget * headerWidget () const =0
 Returns header widget. More...
virtual ModuleBase_ModelWidget * activeWidget (const bool isUseCustomWidget=false) const =0
 Returns currently active widget. More...
virtual const QList< ModuleBase_ModelWidget * > & modelWidgets () const =0
 Returns all property panel's widget created by WidgetFactory. More...
virtual ModuleBase_ModelWidget * modelWidget (const std::string &theAttributeId) const
 Returns widget, that has the given attribute index. More...
virtual void cleanContent ()=0
 Removes all widgets in the widget area of the property panel. More...
virtual void setEditingMode (bool isEditing)
 Editing mode depends on mode of current operation. More...
bool isEditingMode () const
virtual void setFocusOnOkButton ()=0
 Set focus on the Ok button. More...
virtual void setCancelEnabled (bool theEnabled)=0
 Set Enable/Disable state of Cancel button. More...
virtual bool isCancelEnabled () const =0
virtual ModuleBase_ModelWidget * preselectionWidget () const =0
 Returns widget processed by preselection. More...
virtual void setPreselectionWidget (ModuleBase_ModelWidget *theWidget)=0
 Sets widget processed by preselection. More...
ModuleBase_ModelWidget * findFirstAcceptingValueWidget ()
 Returns the first widget, where canAcceptFocus returns true. More...
virtual void onAcceptData ()=0
 The method is called on accepting of operation. More...
 Returns True if data of its feature was modified during operation. More...
static ModuleBase_ModelWidget * findFirstAcceptingValueWidget (const QList< ModuleBase_ModelWidget * > &theWidgets)
bool myIsEditing
 Flag which shows that current operation is in editing mode. More...
◆ ModuleBase_IPropertyPanel()
ModuleBase_IPropertyPanel::ModuleBase_IPropertyPanel ( QWidget *  theParent)
theParentis a parent of the property panel
◆ headerWidget()
virtual QWidget * ModuleBase_IPropertyPanel::headerWidget ( ) const
pure virtual
Implemented in XGUI_PropertyPanel.
◆ activeWidget()
virtual ModuleBase_ModelWidget * ModuleBase_IPropertyPanel::activeWidget ( const bool  isUseCustomWidget = false) const
pure virtual
This is a widget from internal container of widgets (myWidgets) activated/deactivated by focus in property panel. If parameter is true, the method finds firstly the custom widget, after the direct active widget.
isUseCustomWidgetboolean state if the custom widget might be a result
◆ modelWidgets()
virtual const QList< ModuleBase_ModelWidget * > & ModuleBase_IPropertyPanel::modelWidgets ( ) const
pure virtual
◆ modelWidget()
ModuleBase_ModelWidget * ModuleBase_IPropertyPanel::modelWidget ( const std::string &  theAttributeId) const
theAttributeIdan attribute from XML
◆ cleanContent()
virtual void ModuleBase_IPropertyPanel::cleanContent ( )
pure virtual
◆ setEditingMode()
virtual void ModuleBase_IPropertyPanel::setEditingMode ( bool  isEditing)
This value is defined by it.
isEditingstate of editing mode flag
Reimplemented in XGUI_PropertyPanel.
◆ isEditingMode()
bool ModuleBase_IPropertyPanel::isEditingMode ( ) const
State of editing mode flag
◆ setFocusOnOkButton()
virtual void ModuleBase_IPropertyPanel::setFocusOnOkButton ( )
pure virtual
◆ setCancelEnabled()
virtual void ModuleBase_IPropertyPanel::setCancelEnabled ( bool  theEnabled)
pure virtual
theEnabledEnable/Disable state of Cancel button
◆ isCancelEnabled()
virtual bool ModuleBase_IPropertyPanel::isCancelEnabled ( ) const
pure virtual
◆ preselectionWidget()
virtual ModuleBase_ModelWidget * ModuleBase_IPropertyPanel::preselectionWidget ( ) const
pure virtual
◆ setPreselectionWidget()
virtual void ModuleBase_IPropertyPanel::setPreselectionWidget ( ModuleBase_ModelWidget *  theWidget)
pure virtual
◆ findFirstAcceptingValueWidget() [1/2]
ModuleBase_ModelWidget * ModuleBase_IPropertyPanel::findFirstAcceptingValueWidget ( )
a widget or null
◆ onAcceptData()
virtual void ModuleBase_IPropertyPanel::onAcceptData ( )
pure virtual
◆ isModified()
bool ModuleBase_IPropertyPanel::isModified ( ) const
◆ findFirstAcceptingValueWidget() [2/2]
ModuleBase_ModelWidget * ModuleBase_IPropertyPanel::findFirstAcceptingValueWidget ( const QList< ModuleBase_ModelWidget * > &  theWidgets)
a widget or null
workaround for the same attributes used in different stacked widgets(attribute types)
◆ keyReleased
void ModuleBase_IPropertyPanel::keyReleased ( QObject *  theObject,
QKeyEvent *  theEvent
signal
theObjecta sender of the event
theEventkey release event
◆ beforeWidgetActivated
void ModuleBase_IPropertyPanel::beforeWidgetActivated ( ModuleBase_ModelWidget *  theWidget)
signal
theWidgetthe activated widget
◆ noMoreWidgets
void ModuleBase_IPropertyPanel::noMoreWidgets ( const std::string &  thePreviousAttributeID)
signal
theWidgetthe activated widget Emitted when there is no next widget
thePreviousAttributeIDan attribute key of the previous active widget
◆ activateNextWidget [1/2]
virtual void ModuleBase_IPropertyPanel::activateNextWidget ( ModuleBase_ModelWidget *  theWidget)
pure virtualslot
theWidgeta widget. The next widget should be activated
◆ activateNextWidget [2/2]
virtual void ModuleBase_IPropertyPanel::activateNextWidget ( )
pure virtualslot
◆ activateWidget
virtual void ModuleBase_IPropertyPanel::activateWidget ( ModuleBase_ModelWidget *  theWidget,
const bool  theEmitSignal = true
pure virtualslot
theWidgetwhich has to be activated
theEmitSignala flag to prohibit signal emit
◆ myIsEditing
bool ModuleBase_IPropertyPanel::myIsEditing
