Realization of Property panel object. More...
#include <XGUI_PropertyPanel.h>
Public Slots | |
| void | updateContentWidget (FeaturePtr theFeature) |
| Update all widgets in property panel with values from the given feature. More... | |
| void | createContentPanel (FeaturePtr theFeature) |
| If the XML definition of the feature contains information about specific content of the property panel, it creates the panel and allow filling it by the given feature. More... | |
| virtual void | activateWidget (ModuleBase_ModelWidget *theWidget, const bool theEmitSignal=true) |
| Makes the given widget active, highlights it and removes highlighting from the previous active widget. More... | |
| void | onFocusInWidget (ModuleBase_ModelWidget *theWidget) |
| Activates the parameter widget if it can accept focus. More... | |
| void | onActivateNextWidget (ModuleBase_ModelWidget *theWidget) |
| Activate next widget. More... | |
Signals | |
| void | propertyPanelDeactivated () |
| Emits on deactivating property panel (e.g. by clearContent) More... | |
| void | propertyPanelActivated () |
| Emits on widget activating. More... | |
| void | beforeWidgetActivated (ModuleBase_ModelWidget *theWidget) |
| The signal about the widget activation. More... | |
| void | noMoreWidgets (const std::string &thePreviousAttributeID) |
| XGUI_PropertyPanel (QWidget *theParent, XGUI_OperationMgr *theMgr) | |
| Constructor. More... | |
| virtual QWidget * | headerWidget () const |
| Returns header widget. More... | |
| ModuleBase_PageBase * | contentWidget () |
| Returns main widget of the property panel, which children will be created by WidgetFactory using the XML definition. More... | |
| void | setModelWidgets (const QList< ModuleBase_ModelWidget * > &theWidgets) |
| Brings back all widget created by widget factory for signal/slot connections and further processing. More... | |
| virtual const QList< ModuleBase_ModelWidget * > & | modelWidgets () const |
| Returns all property panel's widget created by WidgetFactory. More... | |
| virtual void | cleanContent () |
| Removes all widgets in the widget area of the property panel. More... | |
| virtual ModuleBase_ModelWidget * | activeWidget (const bool isUseCustomWidget=false) const |
| Returns currently active widget. More... | |
| virtual void | activateNextWidget (ModuleBase_ModelWidget *theWidget) |
| Activate the next widget in the property panel. More... | |
| virtual void | activateNextWidget () |
| Activate the next from current widget in the property panel. More... | |
| virtual void | setFocusOnOkButton () |
| Set focus on the Ok button. More... | |
| virtual void | setCancelEnabled (bool theEnabled) |
| Set Enable/Disable state of Cancel button. More... | |
| virtual bool | isCancelEnabled () const |
| Editing mode depends on mode of current operation. More... | |
| void | setupActions (XGUI_ActionsMgr *theMgr) |
| Allows to set predefined actions for the property panel fetched from the ActionsMgr. More... | |
| virtual ModuleBase_ModelWidget * | preselectionWidget () const |
| Returns widget processed by preselection. More... | |
| virtual void | setPreselectionWidget (ModuleBase_ModelWidget *theWidget) |
| Sets widget processed by preselection. More... | |
| XGUI_OperationMgr * | operationMgr () const |
| Returns operation manager. More... | |
| QToolButton * | findButton (const char *theInternalName) const |
| Find under the panel a child button with the parameter name. More... | |
| bool | setFocusNextPrevChild (bool theIsNext) |
| Possibility to process focus by method, for example when Tab or SHIFT+Tab is pressed but property panel is not active widget. More... | |
| virtual void | onAcceptData () |
| The method is called on accepting of operation. More... | |
| void | setInternalActiveWidget (ModuleBase_ModelWidget *theWidget) |
| Set internal active widget, that can be returned as active widget and participate in active selection filters/modes in application. More... | |
| void | updateApplyPlusButton (FeaturePtr theFeature) |
| virtual ModuleBase_ModelWidget * | modelWidget (const std::string &theAttributeId) const |
| Returns widget, that has the given attribute index. More... | |
| ModuleBase_ModelWidget * | findFirstAcceptingValueWidget () |
| Returns the first widget, where canAcceptFocus returns true. More... | |
| Returns True if data of its feature was modified during operation. More... | |
| static ModuleBase_ModelWidget * | findFirstAcceptingValueWidget (const QList< ModuleBase_ModelWidget * > &theWidgets) |
| bool | setActiveWidget (ModuleBase_ModelWidget *theWidget, const bool isEmitSignal) |
| Makes the widget active, deactivate the previous, activate and highlight the given one. More... | |
| virtual bool | focusNextPrevChild (bool theIsNext) |
| The parent method that processes the "Tab"/"SHIFT + Tab" keyboard events Emits a signal about focus change If theIsNext is true, this function searches forward, if next is false, it searches backward. More... | |
| void | activateNextWidget (ModuleBase_ModelWidget *theWidget, const bool isCheckVisibility) |
| void | closeEvent (QCloseEvent *theEvent) |
| A method called on the property panel closed. More... | |
Protected Attributes | |
| bool | myIsEditing |
| Flag which shows that current operation is in editing mode. More... | |
| XGUI_PropertyPanel::XGUI_PropertyPanel | ( | QWidget * | theParent, |
| XGUI_OperationMgr * | theMgr | ||
| theParent | is a parent of the property panel |
| theMgr | operation manager |
inlinevirtual |
Implements ModuleBase_IPropertyPanel.
| ModuleBase_PageBase * XGUI_PropertyPanel::contentWidget | ( | ) |
| void XGUI_PropertyPanel::setModelWidgets | ( | const QList< ModuleBase_ModelWidget * > & | theWidgets | ) |
as the widgets are deleted later, it is important that the signals of these widgets are not processed. An example of the error is issue 986. In the given case, the property panel is firstly filled by new widgets of restarted operation and after that the mouse release signal come from the widget of the previous operation (Point2d widget about mouse is released and focus is out of this widget)
by default it is hidden
This is a widget from internal container of widgets (myWidgets) activated/deactivated by focus in property panel. If parameter is true, the method finds firstly the custom widget, after the direct active widget.
| isUseCustomWidget | boolean state if the custom widget might be a result |
| theWidget | a widget. The next widget should be activated |
| theEnabled | Enable/Disable state of Cancel button |
This value is defined by it.
| isEditing | state of editing mode flag |
Reimplemented from ModuleBase_IPropertyPanel.
| void XGUI_PropertyPanel::setupActions | ( | XGUI_ActionsMgr * | theMgr | ) |
inline |
| QToolButton * XGUI_PropertyPanel::findButton | ( | const char * | theInternalName | ) | const |
| theInternalName | a button object name |
| bool XGUI_PropertyPanel::setFocusNextPrevChild | ( | bool | theIsNext | ) |
| theIsNext | true, if Tab(to the next widget) or false(moving to the previous) |
| void XGUI_PropertyPanel::setInternalActiveWidget | ( | ModuleBase_ModelWidget * | theWidget | ) |
It emits signal about property panel activation or deactivation and updates selection filters/modes accordingly.
| theWidget | a widget control to store as internal active widget |
slot |
| theFeature | a Feature to update values in widgets |
slot |
| theFeature | a Feature to fill property panel |
virtualslot |
| theWidget | which has to be activated |
| theEmitSignal | a flag to prohibit signal emit |
slot |
| theWidget | a widget where focus in event happened |
slot |
| theWidget | the current widget |
signal |
signal |
signal |
protected |
| theWidget | a widget |
| isEmitSignal | flag whether panel signals should be emitted |
protectedvirtual |
protected |
| isCheckVisibility | flag whether the next widget visibility is checked |
protected |
| theEvent | a close event |
| theAttributeId | an attribute from XML |
inlineinherited |
staticinherited |
workaround for the same attributes used in different stacked widgets(attribute types)
signalinherited |
signalinherited |
| theWidget | the activated widget |
signalinherited |
| theWidget | the activated widget Emitted when there is no next widget |
| thePreviousAttributeID | an attribute key of the previous active widget |
protectedinherited |
