XGUI_ActionsMgr Class Reference
class XGUI_ActionsMgrA class for management of actions (features) activation/deactivation More...
#include <XGUI_ActionsMgr.h>
Inheritance diagram for XGUI_ActionsMgr:
enum  OperationStateActionId {
  Abort = 0 , Accept = 1 , AcceptPlus = 2 , Help = 3 ,
  AbortAll = 4 , AcceptAll = 5 , Preview = 6
 Actions on operations. More...
 XGUI_ActionsMgr (XGUI_Workshop *theWorkshop)
void addCommand (QAction *theCmd)
 Add a command in the manager. More...
void addNestedCommands (const QString &theId, const QStringList &theCommands)
 Sets relation between the command (with given Id) and it's nested actions. More...
QStringList nestedCommands (const QString &theId) const
 Returns list of nested commands by parent command Id. More...
bool isNested (const QString &theId) const
 Returns True if the given Id is an Id of nested command. More...
QKeySequence registerShortcut (const QKeySequence &theKeySequence)
 Registers shortcut (key sequence) for the command triggering. More...
QKeySequence registerShortcut (const QString &theKeySequence)
 This is an overloaded function. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Redefinition of Events_Listener method. More...
QAction * operationStateAction (OperationStateActionId theId)
 Return property panel's action like ok, cancel, help. More...
QAction * action (const QString &theId)
 Return an action by the given id, if it was registered in the manager. More...
ActionInfo actionInfoById (const QString &theId)
 Return info (icon, text, etc) about the action by the given id, if it was registered in the manager. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
Friends
class XGUI_Workshop
◆ OperationStateActionId
◆ XGUI_ActionsMgr()
XGUI_ActionsMgr::XGUI_ActionsMgr ( XGUI_Workshop *  theWorkshop)
theWorkshopan instance of workshop
◆ addCommand()
void XGUI_ActionsMgr::addCommand ( QAction *  theCmd)
Please note that nested commands in the Salome mode (No AppElements_Command, pure QActions) won't be extracted and should be added manually using the addNestedCommands method.
◆ addNestedCommands()
void XGUI_ActionsMgr::addNestedCommands ( const QString &  theId,
const QStringList &  theCommands
◆ nestedCommands()
QStringList XGUI_ActionsMgr::nestedCommands ( const QString &  theId) const
theIda parent command Id
◆ isNested()
bool XGUI_ActionsMgr::isNested ( const QString &  theId) const
theIdan Id to check
◆ registerShortcut() [1/2]
QKeySequence XGUI_ActionsMgr::registerShortcut ( const QKeySequence &  theKeySequence)
theKeySequencea key sequence to register
◆ registerShortcut() [2/2]
QKeySequence XGUI_ActionsMgr::registerShortcut ( const QString &  theKeySequence)
theKeySequence- string that contain a key sequence to register
◆ processEvent()
void XGUI_ActionsMgr::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
Implements Events_Listener.
◆ operationStateAction()
QAction * XGUI_ActionsMgr::operationStateAction ( OperationStateActionId  theId)
If there is no such action, it will be created.
◆ action()
QAction * XGUI_ActionsMgr::action ( const QString &  theId)
◆ actionInfoById()
ActionInfo XGUI_ActionsMgr::actionInfoById ( const QString &  theId)
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
inlinevirtualinherited
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
