Class which defines a configuration of the application (Workshop) and launches it. More...
#include <XGUI_Workshop.h>
Public Slots | |
| void | updateCommandStatus () |
| Update of commands status. More... | |
| void | updateHistory () |
| update history list (undo/redo commands) More... | |
| bool | onSave () |
| Save current document. More... | |
| bool | onSaveAs () |
| Save current document to a file selected by user. More... | |
| void | onUndo (int times=1) |
| Undo last command. More... | |
| void | onRedo (int times=1) |
| Redo previous command. More... | |
| void | onWidgetStateChanged (int thePreviousState) |
| Validates the operation to change the "Apply" button state. More... | |
| void | onValuesChanged () |
| Calls activate of the current widget again. More... | |
| void | onWidgetObjectUpdated () |
| Listens the corresponded signal of model widget and updates Apply button state by feature. More... | |
| void | showPanel (QDockWidget *theDockWidget) |
| Show dock widget panel. More... | |
| void | hidePanel (QDockWidget *theDockWidget) |
| Hide dock widget panel. More... | |
| void | showObjectBrowser () |
| Show object Browser. More... | |
| void | hideObjectBrowser () |
| Hide object Browser. More... | |
| void | showConstraintsBrowser () |
| Show Sketch constraints Browser. More... | |
| void | hideConstraintsBrowser () |
| Hide Sketch constraints Browser. More... | |
| void | closeDocument () |
| Close document. More... | |
| void | onOpen () |
| Open document from file. More... | |
| void | onNew () |
| Create a new document. More... | |
| void | onImportPart () |
| Import part structure from a file. More... | |
| void | onImportShape () |
| Import shape from a file. More... | |
| void | onImportImage () |
| Import image from a file. More... | |
| void | onExportPart () |
| Export features to a file. More... | |
| void | onExportShape () |
| Export a shape to a file. More... | |
| void | onExit () |
| Exit application. More... | |
| void | onPreferences () |
| Open preferences dialog box. More... | |
| void | onAutoApply () |
| A slot calleon toggle of auto-compute button. More... | |
| void | onTrihedronVisibilityChanged (bool theState) |
| Activates/deactivates the trihedron in the viewer AIS context. More... | |
| void | onTransparencyValueChanged () |
| Apply the current transparency value if preview in transparency dialog is switched on. More... | |
Signals | |
| void | salomeViewerSelection () |
| Emitted when selection happens in Salome viewer. More... | |
| void | commandStatusUpdated () |
| the signal about the workshop actions states are updated. More... | |
| void | applicationStarted () |
| the application is started More... | |
| void | updateUndoHistory (const QList< ActionInfo > &) |
| Signal to update Undo history list. More... | |
| void | updateRedoHistory (const QList< ActionInfo > &) |
| Signal to update Redo history list. More... | |
| XGUI_Workshop (XGUI_SalomeConnector *theConnector=0) | |
| Constructor. More... | |
| QDockWidget * | createConstraintsBrowser (QWidget *theParent) |
| Create Sketch constraints browser widget. More... | |
| void | removeConstrBrowser () |
| void | startApplication () |
| Starting of the application. More... | |
| void | activateModule () |
| Activates the module controls. Should be called after module creation. More... | |
| void | deactivateModule () |
| Deactivates the module controls. Should be called after module creation. More... | |
| AppElements_MainWindow * | mainWindow () const |
| Returns main window (Desktop) of the application. More... | |
| AppElements_Workbench * | addWorkbench (const QString &theName) |
| Creates and adds a new workbench (menu group) with the given name and returns it. More... | |
| XGUI_SelectionMgr * | selector () const |
| Returns selection manager object. More... | |
| XGUI_SelectionActivate * | selectionActivate () const |
| Returns selection activating object. More... | |
| XGUI_Displayer * | displayer () const |
| Returns displayer. More... | |
| XGUI_OperationMgr * | operationMgr () const |
| Returns operation manager. More... | |
| XGUI_ErrorMgr * | errorMgr () const |
| Returns error manager. More... | |
| XGUI_ActionsMgr * | actionsMgr () const |
| Returns an actions manager. More... | |
| XGUI_ActiveControlMgr * | activeControlMgr () const |
| Returns an active control manager. More... | |
| XGUI_MenuMgr * | menuMgr () const |
| XGUI_PropertyPanel * | propertyPanel () const |
| Returns property panel widget. More... | |
| XGUI_InspectionPanel * | inspectionPanel () const |
| XGUI_FacesPanel * | facesPanel () const |
| Returns panel for hide object faces. More... | |
| XGUI_ContextMenuMgr * | contextMenuMgr () const |
| Returns context menu manager object. More... | |
| XGUI_SalomeConnector * | salomeConnector () const |
| Returns an object which provides interface to Salome Module (LightApp_Module) More... | |
| ModuleBase_IViewer * | salomeViewer () const |
| Provides an object which provides interface to Salome Viewer. More... | |
| bool | isSalomeMode () const |
| Returns true if the application works as SALOME module. More... | |
| XGUI_ObjectsBrowser * | objectBrowser () const |
| Returns Object browser. More... | |
| XGUI_SketchConstraintsBrowser * | constraintsBrowser () const |
| Returns Sketch constraints browser. More... | |
| void | salomeViewerSelectionChanged () |
| This method is called by Salome module when selection is changed. More... | |
| XGUI_ViewerProxy * | viewer () const |
| Returns viewer which unifies access as to Salome viewer as to standalone viewer. More... | |
| XGUI_ModuleConnector * | moduleConnector () const |
| Returns the module connector. More... | |
| QMainWindow * | desktop () const |
| Returns a desktop. More... | |
| virtual bool | prepareForDisplay (const std::set< ObjectPtr > &theObjects) const |
| If faces panel made the object hidden, show message box whether the object should be restored (removed from the panel) and displayed, if answer is No, returns false. More... | |
| void | deleteObjects () |
| Delete features. More... | |
| void | editConstraints () |
| Eit constraints. More... | |
| void | deactivateCosntraint () |
| void | cleanHistory () |
| Searches for selected features unused in other (not selected) features. More... | |
| bool | canMoveFeature () |
| Returns true if the selected feature can be moved to the position after the current feature. More... | |
| void | moveObjects (const bool theSplit) |
| Move selected features to be after the current feature. More... | |
| void | recoverFeature () |
| Start a "Recover" feature on the selected one. More... | |
| bool | canBeShaded (const ObjectPtr &theObject) const |
| Returns true if the object can be shaded. More... | |
| bool | canChangeProperty (const QString &theActionName) const |
| Returns true if there is at least one selected body/construction/group result. More... | |
| void | changeColor (const QMap< ResultPtr, QList< GeomShapePtr > > &theSelectedObjects) |
| Change color of the selected objects (result and subshape of result) if it is possible The operation is available for subshape of result, construction, body and group results theSelectedObjects a list of selected objects. More... | |
| void | changeAutoColor (const QMap< ResultPtr, QList< GeomShapePtr > > &theSelectedObjects) |
| Change Autocolor of the results if it is possible The operation is available for group results theObjects a list of selected objects. More... | |
| void | changeDeflection (const QObjectPtrList &theObjects) |
| Change deflection of the results if it is possible The operation is available for construction, body and group results theObjects a list of selected objects. More... | |
| void | changeTransparency (const QObjectPtrList &theObjects) |
| Change transparency of the results if it is possible The operation is available for construction, body and group results theObjects a list of selected objects. More... | |
| void | changeIsoLines (const QObjectPtrList &theObjects) |
| Change number of iso-lines for the given objects theObjects a list of selected objects. More... | |
| void | showObjects (const QObjectPtrList &theList, bool isVisible) |
| Show the given features in 3d Viewer. More... | |
| void | showOnlyObjects (const QObjectPtrList &theList) |
| void | setDisplayMode (const QObjectPtrList &theList, int theMode) |
| Set display mode for the given objects. More... | |
| void | toggleEdgesDirection (const QObjectPtrList &theList) |
| Toggle visualisation of edges direction. More... | |
| void | toggleBringToFront (const QObjectPtrList &theList) |
| Toggle state of display priority (normal/in front) More... | |
| void | setViewerSelectionMode (int theMode) |
| Set selection mode in viewer. More... | |
| void | activateObjectsSelection (const QObjectPtrList &theList) |
| Activates current selection mode for the given list of objects. More... | |
| ModuleBase_IModule * | module () const |
| Returns current module. More... | |
| QString | currentDataFile () const |
| Returns current file. More... | |
| void | setCurrentDataFile (const QString &theDir) |
| void | saveDocument (const QString &theName, std::list< std::string > &theFileNames) |
| Save the current document into a directory. More... | |
| bool | abortAllOperations () |
| If there is an active (uncommitted) operation shows a prompt to abort it and performs abortion if user agreed. More... | |
| void | operationStarted (ModuleBase_Operation *theOperation) |
| Updates workshop state according to the started operation, e.g. More... | |
| bool | deleteFeatures (const QObjectPtrList &theFeatures) |
| void | deactivateActiveObject (const ObjectPtr &theObject, const bool theUpdateViewer) |
| Deactivates the object, if it is active and the module returns that the activation of selection for the object is not possible currently(the current operation uses it) More... | |
| bool | isFeatureOfNested (const FeaturePtr &theFeature) |
| Returns true if the action of the feature is created to contain Accept/Cancel button. More... | |
| void | setStatusBarMessage (const QString &theMessage) |
| Shows the message in the status bar. More... | |
| void | fillPropertyPanel (ModuleBase_Operation *theOperation) |
| Update the property panel content by the XML description of the operation and set the panel into the operation. More... | |
| void | connectToPropertyPanel (const bool isToConnect) |
| Connects or disconnects to the value changed signal of the property panel widgets. More... | |
| QIntList | viewerSelectionModes () const |
| Returns default selection mode in 3d viewer. More... | |
| void | highlightResults (const QObjectPtrList &theObjects) |
| Highlights result objects in Object Browser according to features found in the given list. More... | |
| void | highlightFeature (const QObjectPtrList &theObjects) |
| Highlights feature objects in Object Browser according to features found in the given list. More... | |
| const Config_DataModelReader * | dataModelXMLReader () const |
| Returns Data Model XML reader which contains information about Data structure configuration. More... | |
| void | openFile (const QString &theDirectory) |
| Closes all in the current session and load the directory. More... | |
| void | updateAutoComputeState () |
| void | deactivateCurrentSelector () |
| void | updateColorScaleVisibility () |
| The method updates a Color Scale object in the viewer. More... | |
| void | updateGroupsText () |
| The method updates a Text of Group names in the viewer. More... | |
| void | showHelpPage (const QString &thePage) const |
| void | setBackupState (bool theDoBackup=true) |
| bool | backupState () const |
| void | setWaitForBackup (bool theDoWait=true) |
| bool | waitForBackup () const |
Static Public Attributes | |
| static QString | MOVE_TO_END_COMMAND = QObject::tr("Move to the end") |
| A constant string used for "Move to end" command definition It is used for specific processing of Undo/Redo for this command. More... | |
| static QString | MOVE_TO_END_SPLIT_COMMAND = QObject::tr("Move to the end and split") |
| A constant string used for "Move to end and split" command definition It is used for specific processing of Undo/Redo for this command. More... | |
| void | setGrantedFeatures (ModuleBase_Operation *theOperation) |
| Sets the granted operations for the parameter operation. More... | |
| XGUI_Workshop::XGUI_Workshop | ( | XGUI_SalomeConnector * | theConnector = 0 | ) |
| theConnector | a Salome connector object. Used only if the workshop is launched in Salome environment |
If version of OCCT is 7.4.0 or more then it means that this is version of SALOME older then 9.4.0
| QDockWidget * XGUI_Workshop::createConstraintsBrowser | ( | QWidget * | theParent | ) |
| theParent | a parent of widget |
| void XGUI_Workshop::startApplication | ( | ) |
| void XGUI_Workshop::activateModule | ( | ) |
| void XGUI_Workshop::deactivateModule | ( | ) |
inline |
| AppElements_Workbench * XGUI_Workshop::addWorkbench | ( | const QString & | theName | ) |
inline |
inline |
inline |
Returns displayer.
inline |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
| ModuleBase_IViewer * XGUI_Workshop::salomeViewer | ( | ) | const |
inline |
inline |
inline |
| void XGUI_Workshop::salomeViewerSelectionChanged | ( | ) |
inline |
inline |
| QMainWindow * XGUI_Workshop::desktop | ( | ) | const |
Returns a desktop.
| theObject | a model object |
| void XGUI_Workshop::deleteObjects | ( | ) |
Delete features.
| void XGUI_Workshop::editConstraints | ( | ) |
Eit constraints.
| void XGUI_Workshop::cleanHistory | ( | ) |
If one or several selected features are found, a warning message proposes to delete them. It contains the list of features to be deleted.
| bool XGUI_Workshop::canMoveFeature | ( | ) |
| void XGUI_Workshop::moveObjects | ( | const bool | theSplit | ) |
| void XGUI_Workshop::recoverFeature | ( | ) |
| bool XGUI_Workshop::canBeShaded | ( | const ObjectPtr & | theObject | ) | const |
If the object is a compsolid result, the method checks subobjects of the result
| bool XGUI_Workshop::canChangeProperty | ( | const QString & | theActionName | ) | const |
| theActionName | text of the checked action |
| void XGUI_Workshop::changeColor | ( | const QMap< ResultPtr, QList< GeomShapePtr > > & | theSelectedObjects | ) |
| void XGUI_Workshop::changeAutoColor | ( | const QMap< ResultPtr, QList< GeomShapePtr > > & | theSelectedObjects | ) |
| void XGUI_Workshop::changeDeflection | ( | const QObjectPtrList & | theObjects | ) |
| void XGUI_Workshop::changeTransparency | ( | const QObjectPtrList & | theObjects | ) |
| void XGUI_Workshop::changeIsoLines | ( | const QObjectPtrList & | theObjects | ) |
| void XGUI_Workshop::showObjects | ( | const QObjectPtrList & | theList, |
| bool | isVisible | ||
| void XGUI_Workshop::showOnlyObjects | ( | const QObjectPtrList & | theList | ) |
| void XGUI_Workshop::setDisplayMode | ( | const QObjectPtrList & | theList, |
| int | theMode | ||
| theList | a list of displayed objects |
| theMode | a mode to set (see XGUI_Displayer) |
| void XGUI_Workshop::toggleEdgesDirection | ( | const QObjectPtrList & | theList | ) |
| void XGUI_Workshop::toggleBringToFront | ( | const QObjectPtrList & | theList | ) |
| void XGUI_Workshop::setViewerSelectionMode | ( | int | theMode | ) |
If theMode=-1 then activate default mode
| theMode | the selection mode (according to TopAbs_ShapeEnum) |
| void XGUI_Workshop::activateObjectsSelection | ( | const QObjectPtrList & | theList | ) |
inline |
inline |
inline |
| void XGUI_Workshop::saveDocument | ( | const QString & | theName, |
| std::list< std::string > & | theFileNames | ||
| theName | - path to the directory |
| theFileNames | - returned file names created in this directory |
| bool XGUI_Workshop::abortAllOperations | ( | ) |
Returns true if
| void XGUI_Workshop::operationStarted | ( | ModuleBase_Operation * | theOperation | ) |
visualizes the property panel and connect to it.
| theOpertion | a started operation |
< No need for property panel
| bool XGUI_Workshop::deleteFeatures | ( | const QObjectPtrList & | theFeatures | ) |
Delete features.
Delete the referenced features. There can be a question with a list of referenced objects.
| theFeatures | a list of objects to be deleted |
| void XGUI_Workshop::deactivateActiveObject | ( | const ObjectPtr & | theObject, |
| const bool | theUpdateViewer | ||
| theObject | an object |
| theUpdateViewer | a boolean flag to update viewer immediately |
| bool XGUI_Workshop::isFeatureOfNested | ( | const FeaturePtr & | theFeature | ) |
| theFeature | a feature |
| void XGUI_Workshop::setStatusBarMessage | ( | const QString & | theMessage | ) |
| theMessage | a message |
| void XGUI_Workshop::fillPropertyPanel | ( | ModuleBase_Operation * | theOperation | ) |
| theOperation | an operation |
| void XGUI_Workshop::connectToPropertyPanel | ( | const bool | isToConnect | ) |
| isToConnect | a boolean value whether connect or disconnect |
inline |
| void XGUI_Workshop::highlightResults | ( | const QObjectPtrList & | theObjects | ) |
| void XGUI_Workshop::highlightFeature | ( | const QObjectPtrList & | theObjects | ) |
inline |
| void XGUI_Workshop::openFile | ( | const QString & | theDirectory | ) |
| theDirectory | a path to directory |
| void XGUI_Workshop::updateColorScaleVisibility | ( | ) |
| void XGUI_Workshop::updateGroupsText | ( | ) |
signal |
signal |
signal |
signal |
signal |
slot |
slot |
slot |
slot |
slot |
Undo last command.
slot |
slot |
| thePreviousState | the previous state of the widget |
slot |
It is possible that selection filters are differs in the new state of paged container
slot |
slot |
<! Restore ability to close panel from the window's menu
slot |
<! Do not allow to show empty property panel
slot |
slot |
slot |
slot |
slot |
Close document.
slot |
slot |
slot |
slot |
slot |
slot |
slot |
slot |
Exit application.
slot |
slot |
slot |
slot |
protected |
Firstly, it finds the nested features and set them into the operation. Secondly, it asks the module about ids of granted operations.
static |
static |
