XGUI_Displayer Class Reference
Displayer. More...
#include <XGUI_Displayer.h>
Inheritance diagram for XGUI_Displayer:
enum  DisplayMode { NoMode = -1 , Wireframe , Shading }
 display mode More...
Signals
void objectDisplayed (ObjectPtr theObject, AISObjectPtr theAIS)
 Signal on object display. More...
void beforeObjectErase (ObjectPtr theObject, AISObjectPtr theAIS)
 Signal on before object erase. More...
 XGUI_Displayer (XGUI_Workshop *theWorkshop)
virtual ~XGUI_Displayer ()
bool isVisible (ObjectPtr theObject) const
 Returns the feature visibility state. More...
bool display (ObjectPtr theObject, bool theUpdateViewer=true)
 Display the feature. More...
bool displayAIS (AISObjectPtr theAIS, const bool toActivateInSelectionModes, const Standard_Integer theDisplayMode=0, bool theUpdateViewer=true)
 Display the given AIS object. More...
bool displayAIS (Handle theAISIO, const bool toActivateInSelectionModes, const Standard_Integer theDisplayMode=0, bool theUpdateViewer=true)
 Display the given AISIO. More...
bool redisplay (ObjectPtr theObject, bool theUpdateViewer=true)
 Redisplay the shape if it was displayed. More...
void redisplayObjects ()
 Sends and flushes a signal to redisplay all visualized objects. More...
void setSelected (const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues, bool theUpdateViewer=true)
 Add presentations to current selection. More...
void clearSelected (const bool theUpdateViewer=true)
 Unselect all objects. More...
bool erase (ObjectPtr theObject, const bool theUpdateViewer=true)
 Erase the feature and a shape. More...
bool eraseAIS (AISObjectPtr theAIS, const bool theUpdateViewer=true)
 Erase the given AIS object displayed by corresponded display method. More...
bool eraseAIS (Handle theAISIO, const bool theUpdateViewer=true)
 Erase the given AISIO displayed by corresponded display method. More...
bool eraseAll (const bool theUpdateViewer=true)
 Erase all presentations. More...
void deactivateSelectionFilters (const bool theAddFilterOnly=true)
 Remove default selection filters of the module from the current viewer. More...
void addSelectionFilter (const Handle &theFilter)
 Add selection filter. More...
void removeSelectionFilter (const Handle &theFilter)
 Remove selection filter. More...
virtual bool hasSelectionFilter (const Handle &theFilter)
 Returns true if the selection filter is set to the viewer. More...
void removeFilters ()
 Remove all selection filters. More...
bool enableUpdateViewer (const bool isEnabled)
 Sets a flag to the displayer whether the internal viewer can be updated by the updateViewer method call. More...
bool isUpdateEnabled () const
 Returns true if the viewer update is not blocked. More...
void updateViewer () const
 Updates the viewer. More...
AISObjectPtr getAISObject (ObjectPtr theObject) const
 Searches the interactive object by feature. More...
ObjectPtr getObject (const AISObjectPtr &theIO) const
 Searches the feature by interactive object. More...
ObjectPtr getObject (const Handle &theIO) const
void deactivateObjects (const QObjectPtrList &theObjList, const bool theUpdateViewer=true)
 Deactivates the given objects (not allow selection) More...
void setDisplayMode (ObjectPtr theObject, DisplayMode theMode, bool theUpdateViewer=true)
 Sets display mode for the given object if this object is displayed. More...
DisplayMode displayMode (ObjectPtr theObject) const
 Returns current display mode for the given object. More...
void showOnly (const QObjectPtrList &theList)
 Displays only objects listed in the list. More...
int objectsCount () const
 Returns number of displayed objects. More...
QObjectPtrList displayedObjects () const
 Returns list of displayed objects. More...
QList< Handle > displayedPresentations () const
bool canBeShaded (ObjectPtr theObject) const
 Returns true if the given object can be shown in shaded mode. More...
QColor setObjectColor (ObjectPtr theObject, const QColor &theColor, bool theUpdateViewer=true)
 Set color on presentation of an object if it is displayed. More...
void displayTrihedron (bool theToDisplay) const
 Displays/erases thrihedron in current modes. More...
GeomPlanePtr getScreenPlane () const
 Returns screen plane of active view. More...
double getViewScale () const
 Returns scale of active view. More...
void setSelectionColor (const std::vector< int > &theColor)
 Set color of selection. More...
std::vector< int > selectionColor () const
 Returns current selection color. More...
static bool isVisible (XGUI_Displayer *theDisplayer, const ObjectPtr &theObject)
 Return true if the object is visible. More...
Handle AISContext () const
 Returns currently installed AIS_InteractiveContext. More...
Handle GetFilter ()
 Returns the viewer context top filter. More...
bool display (ObjectPtr theObject, AISObjectPtr theAIS, bool isShading, bool theUpdateViewer=true)
 Display the feature and a shape. More...
Displayer.
Provides mechanizm of display/erase of objects in the viewer
◆ DisplayMode
display mode
NoMode
Mode is not defined.
Wireframe
Wireframe display mode.
Shading
Shading display mode.
◆ XGUI_Displayer()
XGUI_Displayer::XGUI_Displayer ( XGUI_Workshop *  theWorkshop)
theWorkshopa workshop instance
◆ ~XGUI_Displayer()
XGUI_Displayer::~XGUI_Displayer ( )
◆ isVisible() [1/2]
bool XGUI_Displayer::isVisible ( ObjectPtr  theObject) const
theObjectan object instance
◆ display() [1/2]
bool XGUI_Displayer::display ( ObjectPtr  theObject,
bool  theUpdateViewer = true
Obtain the visualized object from the feature.
theObjectan object to display
theUpdateViewerthe parameter whether the viewer should be updated immediately
true if the object visibility state is changed
◆ displayAIS() [1/2]
bool XGUI_Displayer::displayAIS ( AISObjectPtr  theAIS,
const Standard_Integer  theDisplayMode = 0,
This object is not added to the displayer internal map of objects So, it can not be obtained from displayer. This is just a wrap method of OCC display in order to perform the display with correct flags.
theAISAIOS object to display
toActivateInSelectionModesboolean value whether the presentation should be activated in the current selection modes
theDisplayModemode how the presentation should be displayed
◆ displayAIS() [2/2]
bool XGUI_Displayer::displayAIS ( Handle  theAISIO,
theAISIOis an object to display
◆ redisplay()
bool XGUI_Displayer::redisplay ( ObjectPtr  theObject,
◆ redisplayObjects()
void XGUI_Displayer::redisplayObjects ( )
◆ setSelected()
void XGUI_Displayer::setSelected ( const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues,
It unhighlight and deselect the current selection. The shape and result components are processed in the values. If the presentation shape is not empty, select it, otherwise select the result.
theValuesa list of presentation to be selected
◆ clearSelected()
void XGUI_Displayer::clearSelected ( const bool  theUpdateViewer = true)
theUpdateViewerthe parameter to update viewer
◆ erase()
bool XGUI_Displayer::erase ( ObjectPtr  theObject,
◆ eraseAIS() [1/2]
bool XGUI_Displayer::eraseAIS ( AISObjectPtr  theAIS,
theAISinstance of AIS object
◆ eraseAIS() [2/2]
bool XGUI_Displayer::eraseAIS ( Handle  theAISIO,
◆ eraseAll()
bool XGUI_Displayer::eraseAll ( const bool  theUpdateViewer = true)
◆ deactivateSelectionFilters()
void XGUI_Displayer::deactivateSelectionFilters ( const bool  theAddFilterOnly = true)
theAddFilterOnlyif is not 'true' it will deactivate all fiters in viewer
◆ addSelectionFilter()
void XGUI_Displayer::addSelectionFilter ( const Handle &  theFilter)
theFiltera filter instance
◆ removeSelectionFilter()
void XGUI_Displayer::removeSelectionFilter ( const Handle &  theFilter)
◆ hasSelectionFilter()
bool XGUI_Displayer::hasSelectionFilter ( const Handle &  theFilter)
theFiltera selection filter
◆ removeFilters()
void XGUI_Displayer::removeFilters ( )
◆ enableUpdateViewer()
bool XGUI_Displayer::enableUpdateViewer ( const bool  isEnabled)
If it is not enabled, this method do nothing. This state maintain recurse, if the update is blocked twice or three times, the viewer will not be updated until it is unblocked necessary times (twice or three in the example).
isEnableda boolean value
◆ isUpdateEnabled()
bool XGUI_Displayer::isUpdateEnabled ( ) const
◆ updateViewer()
void XGUI_Displayer::updateViewer ( ) const
Updates the viewer.
◆ getAISObject()
AISObjectPtr XGUI_Displayer::getAISObject ( ObjectPtr  theObject) const
theObjectthe object or presentable feature
theIO an interactive object
◆ getObject() [1/2]
ObjectPtr XGUI_Displayer::getObject ( const AISObjectPtr &  theIO) const
theIOan interactive object
feature the feature or NULL if it not visualized
◆ getObject() [2/2]
ObjectPtr XGUI_Displayer::getObject ( const Handle &  theIO) const
corresponded object or NULL if it not found
◆ deactivateObjects()
void XGUI_Displayer::deactivateObjects ( const QObjectPtrList &  theObjList,
theObjList- list of objects which has to be deactivated.
theUpdateViewerupdate viewer flag
◆ setDisplayMode()
void XGUI_Displayer::setDisplayMode ( ObjectPtr  theObject,
◆ displayMode()
XGUI_Displayer::DisplayMode XGUI_Displayer::displayMode ( ObjectPtr  theObject) const
If object is not dis played then returns NoMode.
theObjectobject to check
◆ showOnly()
void XGUI_Displayer::showOnly ( const QObjectPtrList &  theList)
theListlist of objects
◆ objectsCount()
int XGUI_Displayer::objectsCount ( ) const
◆ displayedObjects()
QObjectPtrList XGUI_Displayer::displayedObjects ( ) const
◆ displayedPresentations()
QList< Handle > XGUI_Displayer::displayedPresentations ( ) const
◆ canBeShaded()
bool XGUI_Displayer::canBeShaded ( ObjectPtr  theObject) const
◆ setObjectColor()
QColor XGUI_Displayer::setObjectColor ( ObjectPtr  theObject,
const QColor &  theColor,
theObjectan object
theColora color which has to be set
previously defined color on the object
◆ displayTrihedron()
void XGUI_Displayer::displayTrihedron ( bool  theToDisplay) const
It will be activated or deactivated depending on the trihedron visible state and displayer active trihedron state
◆ isVisible() [2/2]
bool XGUI_Displayer::isVisible ( XGUI_Displayer *  theDisplayer,
const ObjectPtr &  theObject
If the object is feature, it returns true if all results of the feature are shown
theDisplayera displayer
theObjectan object
a boolean value
◆ getScreenPlane()
GeomPlanePtr XGUI_Displayer::getScreenPlane ( ) const
◆ getViewScale()
double XGUI_Displayer::getViewScale ( ) const
◆ setSelectionColor()
void XGUI_Displayer::setSelectionColor ( const std::vector< int > &  theColor)
theColorR,G,B values of color
◆ selectionColor()
std::vector< int > XGUI_Displayer::selectionColor ( ) const
◆ objectDisplayed
void XGUI_Displayer::objectDisplayed ( ObjectPtr  theObject,
AISObjectPtr  theAIS
signal
theObjecta data object
theAISa presentation object
◆ beforeObjectErase
void XGUI_Displayer::beforeObjectErase ( ObjectPtr  theObject,
AISObjectPtr  theAIS
signal
◆ AISContext()
Handle XGUI_Displayer::AISContext ( ) const
◆ GetFilter()
Handle XGUI_Displayer::GetFilter ( )
If there is no a filter, it is created and set into The context should have only this filter inside. Other filters should be add to the filter
◆ display() [2/2]
bool  isShading,
This shape would be associated to the given feature
theAISAIS presentation
isShadingflag to show in shading mode
