XGUI_MenuMgr Class Reference
A class for management of menu actions (features). More...
#include <XGUI_MenuMgr.h>
Inheritance diagram for XGUI_MenuMgr:
 XGUI_MenuMgr (XGUI_Workshop *theWorkshop)
void createFeatureActions ()
 Creates feature actions. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Redefinition of Events_Listener method. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
void addFeature (const std::shared_ptr< Config_FeatureMessage > &theMessage)
 Process event "Add a feature". More...
std::shared_ptr< XGUI_MenuWorkbench > findWorkbench (const std::string &theWorkbenchName)
 Finds or creates a workbench for the given name. More...
QAction * buildAction (const std::shared_ptr< Config_FeatureMessage > &theMessage, const std::string &theWchName, const bool aUseSeparator) const
 Creates a new action by the message. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
The actions should be arranged like they are in XML file. It listens the read feature of XML and fills internal structure of menu workbenches and groups of feature. After, it creates menus and tools in the module.
◆ XGUI_MenuMgr()
XGUI_MenuMgr::XGUI_MenuMgr ( XGUI_Workshop *  theWorkshop)
theWorkshopthe current workshop
◆ createFeatureActions()
void XGUI_MenuMgr::createFeatureActions ( )
◆ processEvent()
void XGUI_MenuMgr::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
theMessagea message
Implements Events_Listener.
◆ addFeature()
void XGUI_MenuMgr::addFeature ( const std::shared_ptr< Config_FeatureMessage > &  theMessage)
◆ findWorkbench()
std::shared_ptr< XGUI_MenuWorkbench > XGUI_MenuMgr::findWorkbench ( const std::string &  theWorkbenchName)
theWorkbenchNamea name defined in XML
an instance of workbench
◆ buildAction()
QAction * XGUI_MenuMgr::buildAction ( const std::shared_ptr< Config_FeatureMessage > &  theMessage,
const std::string &  theWchName,
theMessagean XML information of the feature
theWchNamea workbench name, will be used as menu/tool bar name
aUseSeparatorboolean value if a separator should be added after the action
an action
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
inlinevirtualinherited
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
