A Base object for definition of connector object to Salome Viewer. More...
#include <ModuleBase_IViewer.h>
Public Types | |
| typedef std::list< std::pair< std::wstring, std::vector< int > > > | TextColor |
| Type for mapping from text to color to display the names lines in different colors. More... | |
Signals | |
| void | lastViewClosed () |
| Signal emitted when last view window is closed. More... | |
| void | tryCloseView (ModuleBase_IViewWindow *theWnd) |
| Signal emitted before view window is closed. More... | |
| void | deleteView (ModuleBase_IViewWindow *theWnd) |
| Signal emitted on delete view window. More... | |
| void | viewCreated (ModuleBase_IViewWindow *theWnd) |
| Signal emitted on creation of view window. More... | |
| void | activated (ModuleBase_IViewWindow *theWnd) |
| Signal emitted on key release. More... | |
| void | mousePress (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent) |
| Signal emitted on mouse press. More... | |
| void | mouseRelease (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent) |
| Signal emitted on mouse release. More... | |
| void | mouseDoubleClick (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent) |
| Signal emitted on mouse double click. More... | |
| void | mouseMove (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent) |
| Signal emitted on mouse move. More... | |
| void | keyPress (ModuleBase_IViewWindow *theWnd, QKeyEvent *theEvent) |
| Signal emitted on key press. More... | |
| void | keyRelease (ModuleBase_IViewWindow *theWnd, QKeyEvent *theEvent) |
| void | selectionChanged () |
| Signal emitted on selection changed. More... | |
| void | contextMenuRequested (QContextMenuEvent *) |
| void | viewTransformed (int theTransformation) |
| Signal emitted on transformation of view point in view window. More... | |
| void | trihedronVisibilityChanged (bool theState) |
| ModuleBase_IViewer (QObject *theParent) | |
| Constructor. More... | |
| virtual Handle | AISContext () const =0 |
| Returns AIS_InteractiveContext from current OCCViewer. More... | |
| virtual Handle | trihedron () const =0 |
| Trihedron 3d object shown in the viewer. More... | |
| virtual Handle | v3dViewer () const =0 |
| Retrurns V3d_Vioewer from current viewer. More... | |
| virtual Handle | activeView () const =0 |
| Returns Vsd_View object from currently active view window. More... | |
| virtual QWidget * | activeViewPort () const =0 |
| Returns currently active view port widget. More... | |
| virtual void | enableSelection (bool isEnabled)=0 |
| Enable or disable selection in the viewer. More... | |
| virtual bool | isSelectionEnabled () const =0 |
| Returns true if selection is enabled. More... | |
| virtual void | enableMultiselection (bool isEnable)=0 |
| Enable or disable multiselection in the viewer. More... | |
| virtual bool | isMultiSelectionEnabled () const =0 |
| Returns true if multiselection is enabled. More... | |
| virtual bool | enableDrawMode (bool isEnabled)=0 |
| Enable or disable draw mode in the viewer. More... | |
| virtual void | fitAll ()=0 |
| Performs the fit all for the active view. More... | |
| virtual void | eraseAll ()=0 |
| Erases all presentations from the viewer. More... | |
| virtual void | setViewProjection (double theX, double theY, double theZ, double theTwist)=0 |
| Sets the view projection. More... | |
| virtual void | setViewProjection (double theX, double theY, double theZ, double theUpX, double theUpY, double theUpZ)=0 |
| Sets the view projection and up direction. More... | |
| virtual void | addSelectionFilter (const Handle &theFilter)=0 |
| Add selection filter to the viewer. More... | |
| virtual void | removeSelectionFilter (const Handle &theFilter)=0 |
| Remove selection filter from the viewer. More... | |
| virtual bool | hasSelectionFilter (const Handle &theFilter)=0 |
| Returns true if the selection filter is set to the viewer. More... | |
| virtual void | update ()=0 |
| Update current viewer. More... | |
| const double | Scale (const Handle &theView) |
| Returns a scale factor of the given view. More... | |
| void | SetScale (const Handle &theView, const double theVal) |
| Remember a scale factor for the view object. More... | |
| virtual bool | canDragByMouse () const |
| Method returns True if the viewer can process editing objects by mouse drugging. More... | |
| virtual void | updateHighlight () |
| Fit all along Z (perpendicular to display) More... | |
| void | set2dMode (bool is2d) |
| Set flag which indicates that viewer is used for 2d operations. More... | |
| bool | is2dMode () const |
| Returns current state of 2d mode flag. More... | |
| virtual bool | isColorScaleVisible () const =0 |
| Returns True if ColorScale is visible. More... | |
| virtual void | setColorScaleShown (bool on)=0 |
| Show/Hide ColorScale object. More... | |
| virtual void | setColorScalePosition (double theX, double theY)=0 |
| Set position of color scale. More... | |
| virtual void | setColorScaleSize (double theW, double theH)=0 |
| Set size of color scale. More... | |
| virtual void | setColorScaleRange (double theMin, double theMax)=0 |
| Set range of color scale. More... | |
| virtual void | setColorScaleIntervals (int theNb)=0 |
| Set number of intervals of color scale. More... | |
| virtual void | setColorScaleTextHeigth (int theH)=0 |
| Set text height of color scale. More... | |
| virtual void | setColorScaleTextColor (const QColor &theColor)=0 |
| Set color of text of color scale. More... | |
| virtual void | setColorScaleTitle (const QString &theText)=0 |
| Set title of color scale. More... | |
| virtual void | setText (const TextColor &theText, const int theSize)=0 |
| Sets the text displayed in right-top corner of the 3D view. More... | |
| void | showSelectionHighlight () |
| Switches On additional highlight for objects preselection. More... | |
| void | hideSelectionHighlight () |
| Switches Off additional highlight for objects preselection. More... | |
| virtual void | setFitter (AppElements_Fitter *theFitter)=0 |
| virtual AppElements_Fitter * | fitter () const =0 |
Static Public Attributes | |
| static Handle | DefaultHighlightDrawer |
Protected Attributes | |
| QMap< Handle, double > | myWindowScale |
| A map for storing a scale factors dependent on view object. More... | |
| bool | myIs2dMode |
| bool | myShowHighlight |
Reimplemented in SHAPERGUI_SalomeViewer class
| typedef std::list<std::pair<std::wstring, std::vector<int> > > ModuleBase_IViewer::TextColor |
| ModuleBase_IViewer::ModuleBase_IViewer | ( | QObject * | theParent | ) |
| theParent | a parent object |
pure virtual |
Implemented in SHAPERGUI_SalomeViewer, and XGUI_ViewerProxy.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
| isEnabled | is enable or disable flag |
pure virtual |
pure virtual |
| isEnable | is enable or disable flag |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
| theX | the X projection value |
| theY | the Y projection value |
| theZ | the Z projection value |
| theTwist | the twist angle in radians |
pure virtual |
| theUpX | the X value of the up direction vector |
| theUpY | the Y value of the up direction vector |
| theUpZ | the Z value of the up direction vector |
pure virtual |
| theFilter | a selection filter |
pure virtual |
pure virtual |
pure virtual |
inline |
| theView | a view object |
inline |
| theVal | a scale factor |
inlinevirtual |
If this is impossible thet it has to return False.
Reimplemented in SHAPERGUI_SalomeViewer, and XGUI_ViewerProxy.
inlinevirtual |
Show highlight for pre-highlighted sub-shape
Reimplemented in XGUI_ViewerProxy.
inline |
| is2d | a new 2d mode state |
inline |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
| theText | the text to display, or empty string to erase presentation; the first item is the font name and text color |
| theSize | size of the text font |
inline |
inline |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
| theTransformation | type of transformation (see AppElements_ViewWindow::OperationType) |
signal |
protected |
