XGUI_ViewerProxy Class Reference
Proxy class which repersents or AppElements_Viewer or Salome Viewer dependently on current launching environment. More...
#include <XGUI_ViewerProxy.h>
Inheritance diagram for XGUI_ViewerProxy:
typedef std::list< std::pair< std::wstring, std::vector< int > > > TextColor
 Type for mapping from text to color to display the names lines in different colors. More...
Signals
void enterViewPort ()
 Emits by mouse entering the view port. More...
void leaveViewPort ()
 Emits by mouse leaving of the view port. More...
void lastViewClosed ()
 Signal emitted when last view window is closed. More...
void tryCloseView (ModuleBase_IViewWindow *theWnd)
 Signal emitted before view window is closed. More...
void deleteView (ModuleBase_IViewWindow *theWnd)
 Signal emitted on delete view window. More...
void viewCreated (ModuleBase_IViewWindow *theWnd)
 Signal emitted on creation of view window. More...
void activated (ModuleBase_IViewWindow *theWnd)
 Signal emitted on key release. More...
void mousePress (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent)
 Signal emitted on mouse press. More...
void mouseRelease (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent)
 Signal emitted on mouse release. More...
void mouseDoubleClick (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent)
 Signal emitted on mouse double click. More...
void mouseMove (ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent)
 Signal emitted on mouse move. More...
void keyPress (ModuleBase_IViewWindow *theWnd, QKeyEvent *theEvent)
 Signal emitted on key press. More...
void keyRelease (ModuleBase_IViewWindow *theWnd, QKeyEvent *theEvent)
void selectionChanged ()
 Signal emitted on selection changed. More...
void contextMenuRequested (QContextMenuEvent *)
void viewTransformed (int theTransformation)
 Signal emitted on transformation of view point in view window. More...
void trihedronVisibilityChanged (bool theState)
 XGUI_ViewerProxy (XGUI_Workshop *theParent)
void connectViewProxy ()
 Connects some signals to the viewer from the module connector. More...
virtual Handle AISContext () const
 Returns AIS_InteractiveContext from current OCCViewer. More...
virtual Handle trihedron () const
 Trihedron 3d object shown in the viewer. More...
virtual Handle v3dViewer () const
 Retrurns V3d_Vioewer from current viewer. More...
virtual Handle activeView () const
 Returns Vsd_View object from currently active view window. More...
virtual QWidget * activeViewPort () const
 Returns currently active view port widget. More...
virtual void enableSelection (bool isEnabled)
 Enable or disable selection in the viewer. More...
virtual bool isSelectionEnabled () const
 Returns true if selection is enabled. More...
virtual void enableMultiselection (bool isEnable)
 Enable or disable multiselection in the viewer. More...
virtual bool isMultiSelectionEnabled () const
 Returns true if multiselection is enabled. More...
virtual bool enableDrawMode (bool isEnabled)
 Enable or disable draw mode in the viewer. More...
virtual void setViewProjection (double theX, double theY, double theZ, double theTwist)
 Sets the view projection. More...
virtual void setViewProjection (double theX, double theY, double theZ, double theUpX, double theUpY, double theUpZ)
 Sets the view projection and up direction. More...
virtual void fitAll ()
 Sets the view fitted all. More...
virtual void eraseAll ()
 Erases all presentations from the viewer. More...
void connectToViewer ()
 Connects to a viewer according to current environment. More...
virtual void addSelectionFilter (const Handle &theFilter)
 Add selection filter to the viewer. More...
virtual void removeSelectionFilter (const Handle &theFilter)
 Remove selection filter from the viewer. More...
virtual bool hasSelectionFilter (const Handle &theFilter)
 Returns true if the selection filter is set to the viewer. More...
virtual void clearSelectionFilters ()
 Remove all selection filters from the viewer. More...
virtual void update ()
 Update current viewer. More...
virtual bool canDragByMouse () const
 Method returns True if the viewer can process editing objects by mouse drugging. More...
virtual void updateHighlight ()
 Fit all along Z (perpendicular to display) More...
virtual bool isColorScaleVisible () const
 Returns True if ColorScale is visible. More...
virtual void setColorScaleShown (bool on)
 Show/Hide ColorScale object. More...
virtual void setColorScalePosition (double theX, double theY)
 Set position of color scale. More...
virtual void setColorScaleSize (double theW, double theH)
 Set size of color scale. More...
virtual void setColorScaleRange (double theMin, double theMax)
 Set range of color scale. More...
virtual void setColorScaleIntervals (int theNb)
 Set number of intervals of color scale. More...
virtual void setColorScaleTextHeigth (int theH)
 Set text height of color scale. More...
virtual void setColorScaleTextColor (const QColor &theColor)
 Set color of text of color scale. More...
virtual void setColorScaleTitle (const QString &theText)
 Set title of color scale. More...
void setupColorScale ()
 Set color scale parameters according to user preferences and window size. More...
virtual void setText (const ModuleBase_IViewer::TextColor &theText, const int theSize)
 Sets the text displayed in right-top corner of the 3D view. More...
virtual void setFitter (AppElements_Fitter *theFitter)
virtual AppElements_Fitter * fitter () const
const double Scale (const Handle &theView)
 Returns a scale factor of the given view. More...
void SetScale (const Handle &theView, const double theVal)
 Remember a scale factor for the view object. More...
void set2dMode (bool is2d)
 Set flag which indicates that viewer is used for 2d operations. More...
bool is2dMode () const
 Returns current state of 2d mode flag. More...
void showSelectionHighlight ()
 Switches On additional highlight for objects preselection. More...
void hideSelectionHighlight ()
 Switches Off additional highlight for objects preselection. More...
Static Public Attributes
static Handle DefaultHighlightDrawer
bool eventFilter (QObject *theObject, QEvent *theEvent)
 processes the application signals to catch the mouse leaving state of the main window More...
QMap< Handle, double > myWindowScale
 A map for storing a scale factors dependent on view object. More...
bool myIs2dMode
bool myShowHighlight
It is reccomennded to use this class in operation for accessing to viewer functionality instead of direct access to a viewer
◆ TextColor
typedef std::list<std::pair<std::wstring, std::vector<int> > > ModuleBase_IViewer::TextColor
◆ XGUI_ViewerProxy()
XGUI_ViewerProxy::XGUI_ViewerProxy ( XGUI_Workshop *  theParent)
theParenta parent object
◆ connectViewProxy()
void XGUI_ViewerProxy::connectViewProxy ( )
◆ AISContext()
Handle XGUI_ViewerProxy::AISContext ( ) const
Implements ModuleBase_IViewer.
◆ trihedron()
Handle XGUI_ViewerProxy::trihedron ( ) const
◆ v3dViewer()
Handle XGUI_ViewerProxy::v3dViewer ( ) const
◆ activeView()
Handle XGUI_ViewerProxy::activeView ( ) const
◆ activeViewPort()
QWidget * XGUI_ViewerProxy::activeViewPort ( ) const
◆ enableSelection()
void XGUI_ViewerProxy::enableSelection ( bool  isEnabled)
◆ isSelectionEnabled()
bool XGUI_ViewerProxy::isSelectionEnabled ( ) const
◆ enableMultiselection()
void XGUI_ViewerProxy::enableMultiselection ( bool  isEnable)
◆ isMultiSelectionEnabled()
bool XGUI_ViewerProxy::isMultiSelectionEnabled ( ) const
◆ enableDrawMode()
bool XGUI_ViewerProxy::enableDrawMode ( bool  isEnabled)
◆ setViewProjection() [1/2]
void XGUI_ViewerProxy::setViewProjection ( double  theX,
double  theY,
double  theZ,
double  theTwist
theXthe X projection value
theYthe Y projection value
theZthe Z projection value
theTwistthe twist angle in radians
◆ setViewProjection() [2/2]
double  theY,
double  theZ,
double  theUpX,
double  theUpY,
double  theUpZ
theUpXthe X value of the up direction vector
theUpYthe Y value of the up direction vector
theUpZthe Z value of the up direction vector
◆ fitAll()
void XGUI_ViewerProxy::fitAll ( )
◆ eraseAll()
void XGUI_ViewerProxy::eraseAll ( )
◆ connectToViewer()
void XGUI_ViewerProxy::connectToViewer ( )
◆ addSelectionFilter()
void XGUI_ViewerProxy::addSelectionFilter ( const Handle &  theFilter)
◆ removeSelectionFilter()
void XGUI_ViewerProxy::removeSelectionFilter ( const Handle &  theFilter)
◆ hasSelectionFilter()
bool XGUI_ViewerProxy::hasSelectionFilter ( const Handle &  theFilter)
theFiltera selection filter
◆ clearSelectionFilters()
void XGUI_ViewerProxy::clearSelectionFilters ( )
◆ update()
void XGUI_ViewerProxy::update ( )
◆ canDragByMouse()
bool XGUI_ViewerProxy::canDragByMouse ( ) const
If this is impossible thet it has to return False.
Reimplemented from ModuleBase_IViewer.
◆ updateHighlight()
void XGUI_ViewerProxy::updateHighlight ( )
Show highlight for pre-highlighted sub-shape
◆ isColorScaleVisible()
bool XGUI_ViewerProxy::isColorScaleVisible ( ) const
◆ setColorScaleShown()
void XGUI_ViewerProxy::setColorScaleShown ( bool  on)
◆ setColorScalePosition()
void XGUI_ViewerProxy::setColorScalePosition ( double  theX,
double  theY
◆ setColorScaleSize()
void XGUI_ViewerProxy::setColorScaleSize ( double  theW,
double  theH
◆ setColorScaleRange()
void XGUI_ViewerProxy::setColorScaleRange ( double  theMin,
double  theMax
◆ setColorScaleIntervals()
void XGUI_ViewerProxy::setColorScaleIntervals ( int  theNb)
◆ setColorScaleTextHeigth()
void XGUI_ViewerProxy::setColorScaleTextHeigth ( int  theH)
◆ setColorScaleTextColor()
void XGUI_ViewerProxy::setColorScaleTextColor ( const QColor &  theColor)
◆ setColorScaleTitle()
void XGUI_ViewerProxy::setColorScaleTitle ( const QString &  theText)
◆ setupColorScale()
void XGUI_ViewerProxy::setupColorScale ( )
◆ setText()
void XGUI_ViewerProxy::setText ( const ModuleBase_IViewer::TextColor &  theText,
const int  theSize
theTextthe text to display, or empty string to erase presentation; the first item is the font name and text color
theSizesize of the text font
◆ setFitter()
void XGUI_ViewerProxy::setFitter ( AppElements_Fitter *  theFitter)
◆ fitter()
AppElements_Fitter * XGUI_ViewerProxy::fitter ( ) const
◆ enterViewPort
void XGUI_ViewerProxy::enterViewPort ( )
signal
◆ leaveViewPort
void XGUI_ViewerProxy::leaveViewPort ( )
signal
◆ eventFilter()
bool XGUI_ViewerProxy::eventFilter ( QObject *  theObject,
QEvent *  theEvent
theObject
theEvent
◆ Scale()
const double ModuleBase_IViewer::Scale ( const Handle &  theView)
theViewa view object
◆ SetScale()
void ModuleBase_IViewer::SetScale ( const Handle &  theView,
const double  theVal
theVala scale factor
◆ set2dMode()
void ModuleBase_IViewer::set2dMode ( bool  is2d)
is2da new 2d mode state
◆ is2dMode()
bool ModuleBase_IViewer::is2dMode ( ) const
◆ showSelectionHighlight()
void ModuleBase_IViewer::showSelectionHighlight ( )
◆ hideSelectionHighlight()
void ModuleBase_IViewer::hideSelectionHighlight ( )
◆ lastViewClosed
void ModuleBase_IViewer::lastViewClosed ( )
signalinherited
◆ tryCloseView
void ModuleBase_IViewer::tryCloseView ( ModuleBase_IViewWindow *  theWnd)
signalinherited
◆ deleteView
void ModuleBase_IViewer::deleteView ( ModuleBase_IViewWindow *  theWnd)
signalinherited
◆ viewCreated
void ModuleBase_IViewer::viewCreated ( ModuleBase_IViewWindow *  theWnd)
signalinherited
◆ activated
void ModuleBase_IViewer::activated ( ModuleBase_IViewWindow *  theWnd)
signalinherited
◆ mousePress
void ModuleBase_IViewer::mousePress ( ModuleBase_IViewWindow *  theWnd,
QMouseEvent *  theEvent
signalinherited
◆ mouseRelease
void ModuleBase_IViewer::mouseRelease ( ModuleBase_IViewWindow *  theWnd,
signalinherited
◆ mouseDoubleClick
void ModuleBase_IViewer::mouseDoubleClick ( ModuleBase_IViewWindow *  theWnd,
signalinherited
◆ mouseMove
void ModuleBase_IViewer::mouseMove ( ModuleBase_IViewWindow *  theWnd,
signalinherited
◆ keyPress
void ModuleBase_IViewer::keyPress ( ModuleBase_IViewWindow *  theWnd,
QKeyEvent *  theEvent
signalinherited
◆ keyRelease
void ModuleBase_IViewer::keyRelease ( ModuleBase_IViewWindow *  theWnd,
signalinherited
◆ selectionChanged
void ModuleBase_IViewer::selectionChanged ( )
signalinherited
◆ contextMenuRequested
void ModuleBase_IViewer::contextMenuRequested ( QContextMenuEvent *  )
signalinherited
◆ viewTransformed
void ModuleBase_IViewer::viewTransformed ( int  theTransformation)
signalinherited
theTransformationtype of transformation (see AppElements_ViewWindow::OperationType)
◆ trihedronVisibilityChanged
void ModuleBase_IViewer::trihedronVisibilityChanged ( bool  theState)
signalinherited
◆ myWindowScale
QMap<Handle , double> ModuleBase_IViewer::myWindowScale
