XGUI_SelectionActivate Class Reference
A class which implements activation/deactivate selection modes and using selection filters. More...
#include <XGUI_SelectionActivate.h>
Inheritance diagram for XGUI_SelectionActivate:
enum  SelectionPlace { Workshop , PropertyPanel , FacesPanel }
 Types of the activation place. More...
 XGUI_SelectionActivate (ModuleBase_IWorkshop *theWorkshop)
 ~XGUI_SelectionActivate ()
SelectionPlace activeSelectionPlace () const
 Returns place of activation modes that now is active. More...
virtual void updateSelectionModes ()
 Updates active selection modes in the viewer depending on the application state. More...
virtual void updateSelectionFilters ()
 Updates active selection filters in the viewer depending on the application state. More...
virtual void activateSelectionFilters (const SelectMgr_ListOfFilter &theSelectionFilters)
 Activates parameter filters in the workshop, deactivate active out of the container Please find a possibility to use updateSelectionFilters instead of direct call this method. More...
QIntList activeSelectionModes () const
 Returns list of currently active selection modes Selection modes will be returned according to TopAbs_ShapeEnum. More...
bool isActive (ObjectPtr theObject) const
 Returns true if the given object can be selected. More...
void activateObjects (const QIntList &theModes, const QObjectPtrList &theObjList, const bool theUpdateViewer=true)
 Activates in local context displayed outside of the context. More...
void setSelectionModes (const QIntList &theModes)
 Fill container of current selection modes. More...
void activateOnDisplay (const Handle &theIO, const bool theUpdateViewer)
 Activate object in the selection modes. More...
void activateAIS (const Handle &theIO, const int theMode, const bool theUpdateViewer) const
 Activate interactive object. More...
void deactivateAIS (const Handle &theIO, const int theMode=-1) const
bool activate (const Handle &theIO, const bool theUpdateViewer) const
 Activates the interactive object in the local context. More...
void deactivate (const std::shared_ptr< ModelAPI_Object > &theObject, const bool theUpdateViewer)
 Deactivates the given object (not allow selection) More...
bool isTrihedronActive () const
 Returns true if the trihedron should be activated in current selection modes. More...
void activateTrihedron (bool theIsActive)
 Set trihedron active (used in selection) or non active. More...
void deactivateTrihedron (const bool theUpdateViewer) const
 Find a trihedron in a list of displayed presentations and deactivate it. More...
void deactivateTrihedronInSelectionModes ()
 Get selection modes of trihedron and deactivate it in it. More...
void getSelectionModes (ModuleBase_ModelWidget *theWidget, QIntList &theModes)
 Returns selection modes of the widget. More...
Handle getTrihedron () const
 Returns Trihedron object if it is displayed. More...
Handle AISContext () const
 Returns context of the 3D viewer. More...
XGUI_Displayer * getDisplayer () const
 Returns displayer. More...
AISObjectPtr getDisplayedAISObject (std::shared_ptr< ModelAPI_Object > theObject) const
 Returns AIS object displayed in 3D viewer for the given model object. More...
static int getSelectionMode (int theShapeType)
 Converts shape type (TopAbs_ShapeEnum) to selection mode. More...
QIntList myActiveSelectionModes
 Current activated selection modes. More...
bool myIsTrihedronActive
 Flag: use trihedgon for selection or not. More...
ModuleBase_IWorkshop * myWorkshop
 active workshop More...
◆ SelectionPlace
◆ XGUI_SelectionActivate()
XGUI_SelectionActivate::XGUI_SelectionActivate ( ModuleBase_IWorkshop *  theWorkshop)
◆ ~XGUI_SelectionActivate()
XGUI_SelectionActivate::~XGUI_SelectionActivate ( )
◆ activeSelectionPlace()
XGUI_SelectionActivate::SelectionPlace XGUI_SelectionActivate::activeSelectionPlace ( ) const
place
◆ updateSelectionModes()
void XGUI_SelectionActivate::updateSelectionModes ( )
Implements ModuleBase_ISelectionActivate.
◆ updateSelectionFilters()
void XGUI_SelectionActivate::updateSelectionFilters ( )
◆ activateSelectionFilters()
void XGUI_SelectionActivate::activateSelectionFilters ( const SelectMgr_ListOfFilter &  theSelectionFilters)
theSelectionFiltersa filtes
◆ activeSelectionModes()
QIntList XGUI_SelectionActivate::activeSelectionModes ( ) const
◆ isActive()
bool XGUI_SelectionActivate::isActive ( ObjectPtr  theObject) const
theObjectobject to check
◆ activateObjects()
void XGUI_SelectionActivate::activateObjects ( const QIntList &  theModes,
const QObjectPtrList &  theObjList,
const bool  theUpdateViewer = true
theModes- modes on which it has to be activated (can be empty)
theObjList- list of objects which has to be activated.
theUpdateVieweran update viewer flag
◆ setSelectionModes()
void XGUI_SelectionActivate::setSelectionModes ( const QIntList &  theModes)
theModesselection modes
◆ activateOnDisplay()
void XGUI_SelectionActivate::activateOnDisplay ( const Handle &  theIO,
theIOan object
◆ activateAIS()
void XGUI_SelectionActivate::activateAIS ( const Handle &  theIO,
const int  theMode,
theIOan interactive object
theModeactivation mode
theUpdateViewerupdate viewer flag
◆ deactivateAIS()
void XGUI_SelectionActivate::deactivateAIS ( const Handle &  theIO,
const int  theMode = -1
It is necessary to call ClearOutdatedSelection after deactivation
theModea mode to deactivate. When theMode=-1 then all modes will be deactivated
◆ activate()
bool XGUI_SelectionActivate::activate ( const Handle &  theIO,
theUpdateViewerthe parameter whether the viewer should be updated immediately
a flag is object activated or not
◆ deactivate()
void XGUI_SelectionActivate::deactivate ( const std::shared_ptr< ModelAPI_Object > &  theObject,
theObjectobject to deactivate
◆ isTrihedronActive()
bool XGUI_SelectionActivate::isTrihedronActive ( ) const
◆ activateTrihedron()
void XGUI_SelectionActivate::activateTrihedron ( bool  theIsActive)
#1136 hidden axis are selected in sketch
◆ deactivateTrihedron()
void XGUI_SelectionActivate::deactivateTrihedron ( const bool  theUpdateViewer) const
◆ deactivateTrihedronInSelectionModes()
void XGUI_SelectionActivate::deactivateTrihedronInSelectionModes ( )
deactivate trihedron in selection modes
◆ getSelectionModes()
void XGUI_SelectionActivate::getSelectionModes ( ModuleBase_ModelWidget *  theWidget,
QIntList &  theModes
theWidgetmodel widget
◆ getTrihedron()
Handle XGUI_SelectionActivate::getTrihedron ( ) const
◆ AISContext()
Handle XGUI_SelectionActivate::AISContext ( ) const
context instance
◆ getDisplayer()
XGUI_Displayer * XGUI_SelectionActivate::getDisplayer ( ) const
Returns displayer.
displayer
◆ getDisplayedAISObject()
AISObjectPtr XGUI_SelectionActivate::getDisplayedAISObject ( std::shared_ptr< ModelAPI_Object >  theObject) const
theObjectsource object
interactive object
◆ getSelectionMode()
int XGUI_SelectionActivate::getSelectionMode ( int  theShapeType)
staticprotected
theShapeTypea shape type from TopAbs_ShapeEnum
◆ myActiveSelectionModes
QIntList XGUI_SelectionActivate::myActiveSelectionModes
◆ myIsTrihedronActive
bool XGUI_SelectionActivate::myIsTrihedronActive
◆ myWorkshop
ModuleBase_IWorkshop* ModuleBase_ISelectionActivate::myWorkshop
active workshop
