Interface to a module. More...
#include <ModuleBase_IModule.h>
Public Types | |
| enum | ModuleBase_CustomizeFlag { CustomizeArguments = 0 , CustomizeResults , CustomizeHighlightedObjects } |
| enumeration to know which objects should be customized More... | |
Public Slots | |
| virtual void | onFeatureTriggered () |
| Called on call of command corresponded to a feature. More... | |
| virtual void | onObjectDisplayed (ObjectPtr theObject, AISObjectPtr theAIS) |
| Slot called on object display. More... | |
| virtual void | onBeforeObjectErase (ObjectPtr theObject, AISObjectPtr theAIS) |
| Slot called on before object erase. More... | |
| virtual void | onViewTransformed (int theTrsfType=2) |
| Called on transformation in current viewer. More... | |
Signals | |
| void | resumed (ModuleBase_Operation *theOp) |
| Segnal emitted when an operation is resumed. More... | |
| ModuleBase_IModule (ModuleBase_IWorkshop *theParent) | |
| Constructor. More... | |
| virtual void | storeSelection () |
| Stores the current selection. More... | |
| virtual void | restoreSelection () |
| Restores the current selection. More... | |
| virtual void | createFeatures () |
| Reads description of features from XML file. More... | |
| virtual void | actionCreated (QAction *) |
| Called on creation of menu item in desktop. More... | |
| virtual void | editFeature (FeaturePtr theFeature) |
| Launching of a edit operation on the feature. More... | |
| virtual bool | canCommitOperation () const |
| Returns true if the operation can be committed. More... | |
| virtual void | launchOperation (const QString &theCmdId, const bool &isStartAfterCommitOnly) |
| Creates an operation and send it to loop. More... | |
| virtual void | launchModal (const QString &theCmdId) |
| Executes feature as a modal dialog box. More... | |
| virtual void | operationStarted (ModuleBase_Operation *theOperation) |
| Realizes some functionality by an operation start. More... | |
| virtual void | operationResumed (ModuleBase_Operation *theOperation) |
| Realizes some functionality by an operation resume By default it emits operationResumed signal. More... | |
| virtual void | operationStopped (ModuleBase_Operation *theOperation) |
| Realizes some functionality by an operation stop. More... | |
| virtual void | operationCommitted (ModuleBase_Operation *theOperation) |
| Realizes some functionality by an operation commit. More... | |
| virtual void | operationAborted (ModuleBase_Operation *theOperation) |
| Realizes some functionality by an operation abort. More... | |
| virtual ModuleBase_Operation * | currentOperation () const =0 |
| virtual bool | addViewerMenu (const QMap< QString, QAction * > &theStdActions, QWidget *theParent, QMap< int, QAction * > &theMenuActions) const |
| Add menu items for viewer into the actions map. More... | |
| virtual void | addObjectBrowserMenu (QMenu *theMenu) const |
| Add menu items for object browser into the given menu. More... | |
| virtual void | addConstraintBrowserMenu (QMenu *theMenu) const |
| Add menu items for constraints browser into the given menu. More... | |
| virtual ModuleBase_ModelWidget * | createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi) |
| Creates custom widgets for property panel. More... | |
| virtual ModuleBase_ModelWidget * | activeWidget () const =0 |
| Returns the active widget, by default it is the property panel active widget. More... | |
| ModuleBase_IWorkshop * | workshop () const |
| Returns current workshop. More... | |
| virtual void | propertyPanelDefined (ModuleBase_Operation *theOperation) |
| Call back forlast tuning of property panel before operation performance It is called as on clearing of property panel as on filling with new widgets. More... | |
| virtual bool | createWidgets (const FeaturePtr &theFeature, const QString &theXmlRepr, QList< ModuleBase_ModelWidget * > &theWidgets) const |
| Have an opportunity to create widgets for the current operation instead of standard creation in workshop. More... | |
| virtual bool | canUndo () const |
| Returns True if there are available Undos and there is not an active operation. More... | |
| virtual bool | canRedo () const |
| Returns True if there are available Redos and there is not an active operation. More... | |
| virtual bool | canApplyAction (const ObjectPtr &theObject, const QString &theActionId) const =0 |
| Returns true if the action can be applied to the object. More... | |
| virtual bool | canEraseObject (const ObjectPtr &theObject) const |
| Returns True if the current operation can be committed. More... | |
| virtual bool | canDisplayObject (const ObjectPtr &theObject) const |
| Returns whether the object can be displayed. More... | |
| virtual bool | canUsePreselection (const QString &thePreviousOperationKind, const QString &theStartedOperationKind) |
| Returns whether the started operation may use preselection of the previous one Cases are: previous operation is null, edit operation, previuos and started operations kinds are the same. More... | |
| virtual bool | canActivateSelection (const ObjectPtr &theObject) const |
| Make some functionality after the objects are hidden in viewer. More... | |
| virtual bool | deleteObjects () |
| Reacts to the delete action in module. More... | |
| virtual void | closeDocument ()=0 |
| Performs functionality on closing document. More... | |
| virtual void | clearViewer ()=0 |
| Clears specific presentations in the viewer. More... | |
| virtual void | activeSelectionModes (QIntList &theModes) |
| Returns a list of modes, where the AIS objects should be activated. More... | |
| virtual void | moduleSelectionModes (int theModesType, QIntList &theModes)=0 |
| Appends specific selection modes for the module to the list of types. More... | |
| virtual void | moduleSelectionFilters (const QIntList &theFilterTypes, SelectMgr_ListOfFilter &theSelectionFilters)=0 |
| Appends into container of filters module filters corresponded to the modes type. More... | |
| virtual QIntList | selectionFilters () |
| Returns types of registered module selection filters. More... | |
| virtual Handle | selectionFilter (const int theType) |
| Returns selection filter. More... | |
| void | registerSelectionFilter (const ModuleBase_SelectionFilterType theFilterType, const Handle &theFilter) |
| Append selection filter into the module and type of the filter in internal container. More... | |
| virtual bool | isCustomPrsActivated (const ModuleBase_CustomizeFlag &theFlag) const |
| Return true if the custom presentation is activated. More... | |
| virtual void | activateCustomPrs (const FeaturePtr &theFeature, const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer) |
| Activate custom presentation for the object. More... | |
| virtual void | deactivateCustomPrs (const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer) |
| Deactivate custom presentation for the object. More... | |
| virtual bool | customizeFeature (ObjectPtr theObject, const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer) |
| Modifies the given presentation in the custom way. More... | |
| virtual void | disableCustomMode (ModuleBase_CustomizeFlag theMode) |
| Disable displaying of custom mode. More... | |
| virtual void | enableCustomModes () |
| Enables disabled custom mode. More... | |
| virtual void | customizeObjectBrowser (QWidget *theObjectBrowser) |
| This method is called on object browser creation for customization of module specific features. More... | |
| virtual ModuleBase_Operation * | createOperation (const std::string &theCmdId) |
| Creates a new operation. More... | |
| virtual AISObjectPtr | createPresentation (const ObjectPtr &theResult) |
| Create specific for the module presentation. More... | |
| virtual void | customizePresentation (const ObjectPtr &theObject, const AISObjectPtr &thePrs) const |
| Customize presentation according to objects attributes. More... | |
| virtual ObjectPtr | findPresentedObject (const AISObjectPtr &theAIS) const =0 |
| Returns data object by AIS. More... | |
| virtual bool | canBeShaded (Handle theAIS) const |
| Returns true if the presentation can be shown in shading mode. More... | |
| virtual void | updateObjectBrowserMenu (const QMap< QString, QAction * > &theStdActions) |
| Update state of pop-up menu items in object browser. More... | |
| virtual void | updateViewerMenu (const QMap< QString, QAction * > &theStdActions) |
| Update state of pop-up menu items in viewer. More... | |
| virtual bool | isActionEnableStateFixed (const int theActionId) const |
| Returns true if the action should be always enabled. More... | |
| virtual QString | getFeatureError (const FeaturePtr &theFeature) |
| Returns the feature error if the current state of the feature in the module is not correct If the feature is correct, it returns an empty value. More... | |
| virtual void | grantedOperationIds (ModuleBase_Operation *theOperation, QStringList &theIds) const |
| Returns list of granted operation indices. More... | |
| virtual void | connectToPropertyPanel (ModuleBase_ModelWidget *theWidget, const bool isToConnect) |
| Connects or disconnects to the value changed signal of the property panel widgets. More... | |
| virtual void | widgetStateChanged (int thePreviousState) |
| Validates the operation to change the "Apply" button state. More... | |
| virtual bool | processEnter (const std::string &thePreviousAttributeID) |
| Returns true if the event is processed. More... | |
| virtual void | beforeOperationStopped (ModuleBase_Operation *theOperation) |
| Performs some GUI actions before an operation transaction is stopped Default realization is empty. More... | |
| virtual GeomShapePtr | findShape (const AttributePtr &theAttribute)=0 |
| Finds a shape by attribute if it is possible. More... | |
| virtual AttributePtr | findAttribute (const ObjectPtr &theObject, const GeomShapePtr &theGeomShape)=0 |
| Finds an attribute by geom shape if it is possible. More... | |
| virtual std::shared_ptr< Events_Message > | reentrantMessage ()=0 |
| Returns reentrant message if it was accepted. More... | |
| virtual void | setReentrantPreSelection (const std::shared_ptr< Events_Message > &theMessage)=0 |
| Put current selection into reentrant message. More... | |
| void | getXMLRepresentation (const std::string &theFeatureId, std::string &theXmlCfg, std::string &theDescription) |
| Returns XML information by the feature index. More... | |
| virtual ModuleBase_ITreeNode * | rootNode () const =0 |
| Returns root tree node which represents a data model. More... | |
Protected Slots | |
| virtual void | onSelectionChanged () |
| Called on selection changed event. More... | |
| virtual void | registerValidators () |
| Register validators for this module. More... | |
| virtual void | registerProperties () |
| Register properties of this module. More... | |
| virtual ModuleBase_Operation * | getNewOperation (const std::string &theFeatureId) |
| Returns new instance of operation object (used in createOperation for customization) More... | |
| void | loadProprietaryPlugins () |
| Load plugins required license. More... | |
| void | processProprietaryFeatures () |
| Collect features, which have valid license. More... | |
Protected Attributes | |
| ModuleBase_IWorkshop * | myWorkshop |
| Reference to workshop. More... | |
| std::map< std::string, std::string > | myFeaturesInFiles |
| Map of features in XML. More... | |
| std::map< std::string, std::string > | myProprietaryFeatures |
| Map of features in XML, which require license but not confirmed yet. More... | |
| std::set< std::string > | myProprietaryPlugins |
| Proprietary plugins. More... | |
| std::set< std::string > | myFeaturesValidLicense |
| Features, which have valid license. More... | |
| std::map< ModuleBase_SelectionFilterType, Handle > | mySelectionFilters |
| ModuleBase_IModule::ModuleBase_IModule | ( | ModuleBase_IWorkshop * | theParent | ) |
| theParent | instance of workshop interface |
inlinevirtual |
Reimplemented in PartSet_Module.
inlinevirtual |
| theFeature | feature for editing |
inlinevirtual |
Result in default implementation is true.
| theCmdId | the operation name |
| isStartAfterCommitOnly | operation is launched if there is no active operation or it is committed |
selection should be obtained from workshop before ask if the operation can be started as the canStartOperation method performs commit/abort of previous operation. Sometimes commit/abort may cause selection clear(Sketch operation) as a result it will be lost and is not used for preselection.
reentrant operation(Sketch Line) should not be started if operation is aborted
inlinevirtual |
| theOperation | a started operation |
| theOperation | a resumed operation |
inlinevirtual |
inlinevirtual |
inlinevirtual |
pure virtual |
Implemented in PartSet_Module.
inlinevirtual |
| theStdActions | a map of standard actions |
| theParent | a parent widget |
| theMenuActions | map of action/menu for the desirable index in the viewer menu |
inlinevirtual |
| theMenu | a popup menu to be shown in the object browser |
inlinevirtual |
| theMenu | a popup menu to be shown in the constraints browser |
inlinevirtual |
| theType | a type of widget |
| theParent | the parent object |
| theWidgetApi | the widget configuration. The attribute of the model widget is obtained from |
pure virtual |
inline |
inlinevirtual |
inlinevirtual |
| theFeature | a feature of the started operation |
| theXmlRepr | an XML representation of the operation |
| theWidgets | a list of created widgets |
pure virtual |
| theObject | a checked object |
| theActionId | an identifier of action, to be found in the menu manager like "DELETE_CMD" |
By default it is true.
| theObject | a model object |
The default realization returns true.
| thePreviousOperationKind | a kind of previous operation |
| theStartedOperationKind | a kind of a started operation |
| theObjects | a list of hidden objects Returns true if selection for the object can be activate. By default a result or feature of the current operation can not be activated |
inlinevirtual |
pure virtual |
pure virtual |
inlinevirtual |
| theModes | a list of modes |
pure virtual |
| theModesType | combination of available selection filters |
| theModes | a selection modes to be extended |
pure virtual |
| theFilterTypes | container of available selection filters |
| theSelectionFilters | [out] container to be extend by elements |
| theSelectionFilters | [out] container of type value |
| theType | selection filter type |
| theFilter | instance of filter |
| void ModuleBase_IModule::registerSelectionFilter | ( | const ModuleBase_SelectionFilterType | theFilterType, |
| const Handle & | theFilter | ||
| theFilterType | selection filter type |
| theFilter | added filter |
inlinevirtual |
| theFlag | a flag of level of customization, which means that only part of sub-elements |
inlinevirtual |
| theFeature | a feature instance |
| theUpdateViewer | the parameter whether the viewer should be update immediately |
inlinevirtual |
inlinevirtual |
Update the object presentable properties such as color, line width and other If the object is a result with the color attribute value set, it is used, otherwise the customization is applied to the object's feature if it is a custom prs
| theObject | an object instance |
| theFlag | a flag of level of customization, which means that only part of sub-elements should be updated(e.g. only highlighted elements) |
inlinevirtual |
| theMode | a mode to disable |
inlinevirtual |
inlinevirtual |
| theObjectBrowser | a pinter on Object Browser widget |
The presentation has to be customized accordingly to the object.
| theResult | an object for presentation |
inlinevirtual |
| theObject | an object for presentation |
| thePrs | a presentation object |
pure virtual |
| theAIS | presentation to be checked |
inlinevirtual |
| theStdActions | - a map of standard actions |
inlinevirtual |
inlinevirtual |
| theActionId | an action index: Accept or Accept All |
inlinevirtual |
| theWidget | a property control widget |
| isToConnect | a boolean value whether connect or disconnect |
inlinevirtual |
| thePreviousState | the previous state of the widget |
inlinevirtual |
| thePreviousAttributeID | an index of the previous active attribute |
inlinevirtual |
pure virtual |
| theAttribute | an attribute |
pure virtual |
| theObject | an object of the attribute |
| theGeomShape | a geom shape |
pure virtual |
pure virtual |
| theMessage | a message of reentrant operation |
| void ModuleBase_IModule::getXMLRepresentation | ( | const std::string & | theFeatureId, |
| std::string & | theXmlCfg, | ||
| std::string & | theDescription | ||
| theFeatureId | a feature id |
| theXmlCfg | XML configuration |
| theDescription | feature description |
pure virtual |
signal |
| theOp | a resumed operation |
virtualslot |
inlinevirtualslot |
| theObject | a data object |
| theAIS | a presentation object |
inlinevirtualslot |
inlinevirtualslot |
| theTrsfType | type of transformation |
inlineprotectedvirtualslot |
inlineprotectedvirtual |
protectedvirtual |
protected |
protected |
protected |
protected |
protected |
protected |
protected |
