PartSet_Module Class Reference
Implementation of Partset module. More...
#include <PartSet_Module.h>
Inheritance diagram for PartSet_Module:
enum  ModuleBase_CustomizeFlag { CustomizeArguments = 0 , CustomizeResults , CustomizeHighlightedObjects }
 enumeration to know which objects should be customized More...
Public Slots
virtual void onObjectDisplayed (ObjectPtr theObject, AISObjectPtr theAIS)
 Slolt called on object display. More...
virtual void onBeforeObjectErase (ObjectPtr theObject, AISObjectPtr theAIS)
 Slot called on before object erase. More...
virtual void onViewTransformed (int theTrsfType=2)
 Called on transformation in current viewer. More...
void onRemoveConflictingConstraints ()
 Called on remove conflicting constraints. More...
virtual void onFeatureTriggered ()
 Called on call of command corresponded to a feature. More...
Signals
void resumed (ModuleBase_Operation *theOp)
 Segnal emitted when an operation is resumed. More...
 PartSet_Module (ModuleBase_IWorkshop *theWshop)
virtual void storeSelection ()
 Stores the current selection. More...
virtual void restoreSelection ()
 Restores the current selection. More...
virtual ModuleBase_ModelWidget * createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi)
 Creates custom widgets for property panel. More...
virtual ModuleBase_ModelWidget * activeWidget () const
 Returns the active widget, by default it is the property panel active widget If the internal edit operation is started, this is the first widget of the operation. More...
virtual void propertyPanelDefined (ModuleBase_Operation *theOperation)
 Call back forlast tuning of property panel before operation performance. More...
virtual bool createWidgets (const FeaturePtr &theFeature, const QString &theXmlRepr, QList< ModuleBase_ModelWidget * > &theWidgets) const
 If there is found selected attribute, widgets are created and contains only a widget for the attribute It is important for Property Panel filling by sketch point attribute. More...
virtual void editFeature (FeaturePtr theFeature)
 Launching of a edit operation on the feature. More...
virtual bool canCommitOperation () const
 Returns true if the operation can be committed. More...
virtual void launchOperation (const QString &theCmdId, const bool &isStartAfterCommitOnly)
 Creates an operation and send it to loop. More...
virtual void operationStarted (ModuleBase_Operation *theOperation)
 Realizes some functionality by an operation start Displays all sketcher sub-Objects, hides sketcher result, appends selection filters Activate the operation presentation. More...
virtual void operationResumed (ModuleBase_Operation *theOperation)
 Realizes some functionality by an operation resume Activate the operation presentation. More...
virtual void operationCommitted (ModuleBase_Operation *theOperation)
 Realizes some functionality by an operation commit Restarts sketcher operation automatically of it is necessary. More...
virtual void operationAborted (ModuleBase_Operation *theOperation)
 Realizes some functionality by an operation abort Hides all sketcher sub-Objects, displays sketcher result and removes selection filters. More...
virtual void operationStopped (ModuleBase_Operation *theOperation)
 Realizes some functionality by an operation stop Hides all sketcher sub-Objects, displays sketcher result and removes selection filters. More...
virtual ModuleBase_Operation * currentOperation () const
 Returns current operation. More...
virtual bool canUndo () const
 Returns True if there are available Undos and the sketch manager allows undo. More...
virtual bool canRedo () const
 Returns True if there are available Redos and the sketch manager allows redo. More...
virtual bool canApplyAction (const ObjectPtr &theObject, const QString &theActionId) const
 Returnas true if the action can be applied to the object. More...
virtual bool canEraseObject (const ObjectPtr &theObject) const
 Returns True if the current operation can be committed. More...
virtual bool canDisplayObject (const ObjectPtr &theObject) const
 Returns whether the object can be displayed at the bounds of the active operation. More...
virtual bool canUsePreselection (const QString &thePreviousOperationKind, const QString &theStartedOperationKind)
 Returns parent result if accepted, true if the started operation is a nested operation of the previous operation. More...
virtual bool canActivateSelection (const ObjectPtr &theObject) const
 Make some functionality after the objects are hidden in viewer. More...
virtual void addObjectBrowserMenu (QMenu *theMenu) const
 Add menu atems for object browser into the given menu. More...
virtual bool addViewerMenu (const QMap< QString, QAction * > &theStdActions, QWidget *theParent, QMap< int, QAction * > &theMenuActions) const
 Add menu items for viewer into the actions map. More...
virtual void activeSelectionModes (QIntList &theModes)
 Returns a list of modes, where the AIS objects should be activated. More...
virtual void moduleSelectionModes (int theModesType, QIntList &theModes)
 Appends specific selection modes for the module to the list of types. More...
virtual void moduleSelectionFilters (const QIntList &theFilterTypes, SelectMgr_ListOfFilter &theSelectionFilters)
 Appends into container of filters module filters corresponded to the modes type. More...
bool isMouseOverWindow ()
 Returns whether the mouse enter the viewer's window. More...
PartSet_SketcherMgr * sketchMgr () const
 Returns sketch manager object. More...
PartSet_SketcherReentrantMgr * sketchReentranceMgr () const
 Returns sketch reentrant manager. More...
virtual void getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theSelected, ObjectPtr &theObject, AttributePtr &theAttribute)
 Find object and attribute(if selected) for the given viewer selection. More...
PartSet_OverconstraintListener * overconstraintListener ()
 Returns listener of overconstraint signal. More...
bool isSketchNeutralPointActivated () const
 Returns true if the current operation is not reentrant and the current state of the application is not in launch operation mode. More...
virtual void closeDocument ()
 Performs functionality on closing document. More...
virtual void clearViewer ()
 Clears specific presentations in the viewer. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Event Listener method. More...
void setCustomized (const FeaturePtr &theFeature)
 Set the object with the object results are customized. More...
virtual bool isCustomPrsActivated (const ModuleBase_CustomizeFlag &theFlag) const
 Return true if the custom presentation is activated. More...
virtual void activateCustomPrs (const FeaturePtr &theFeature, const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 Activate custom presentation for the object. More...
virtual void deactivateCustomPrs (const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 Deactivate custom presentation for the object. More...
virtual bool customizeFeature (ObjectPtr theObject, const ModuleBase_CustomizeFlag &theFlag, const bool theUpdateViewer)
 Modifies the given presentation in the custom way. More...
virtual void disableCustomMode (ModuleBase_CustomizeFlag theMode)
 Disable displaying of custom mode. More...
virtual void enableCustomModes ()
 Enables disabled custom mode. More...
virtual void customizeObjectBrowser (QWidget *theObjectBrowser)
 This method is called on object browser creation for customisation of module specific features. More...
int getVisualLayerId () const
 Returns the viewer Z layer. More...
virtual AISObjectPtr createPresentation (const ObjectPtr &theResult)
 Create specific for the module presentation. More...
virtual void customizePresentation (const ObjectPtr &theObject, const AISObjectPtr &thePrs) const
 Customize presentation according to objects attributes. More...
virtual ObjectPtr findPresentedObject (const AISObjectPtr &theAIS) const
 Returns data object by AIS. More...
virtual bool canBeShaded (Handle theAIS) const
 Returns true if the presentation can be shown in shading mode. More...
virtual void updateViewerMenu (const QMap< QString, QAction * > &theStdActions)
 Update state of pop-up menu items in viewer. More...
virtual bool isActionEnableStateFixed (const int theActionId) const
 Returns true if the action should be always enabled. More...
virtual QString getFeatureError (const FeaturePtr &theFeature)
 Returns the feature error if the current state of the feature in the module is not correct If the feature is correct, it returns an empty value. More...
virtual void grantedOperationIds (ModuleBase_Operation *theOperation, QStringList &theIds) const
 Returns list of granted operation indices. More...
virtual void widgetStateChanged (int thePreviousState)
 Validates the current operation and send the state change to sketch manager. More...
virtual bool processEnter (const std::string &thePreviousAttributeID)
 Returns true if the event is processed. More...
virtual void beforeOperationStopped (ModuleBase_Operation *theOperation)
 Performs some GUI actions before an operation transaction is stopped Default realization is empty. More...
virtual GeomShapePtr findShape (const AttributePtr &theAttribute)
 Finds a shape by attribute if it is possible. More...
virtual AttributePtr findAttribute (const ObjectPtr &theObject, const GeomShapePtr &theGeomShape)
 Finds an attribute by geom shape if it is possible. More...
virtual std::shared_ptr< Events_Message > reentrantMessage ()
 Returns reentrant message if it was accepted. More...
virtual void setReentrantPreSelection (const std::shared_ptr< Events_Message > &theMessage)
 Put current selection into reentrant message. More...
virtual ModuleBase_ITreeNode * rootNode () const
 Returns root tree node which represents a data model. More...
XGUI_Workshop * getWorkshop () const
 Returns the workshop. More...
virtual void createFeatures ()
 Reads description of features from XML file. More...
virtual void actionCreated (QAction *)
 Called on creation of menu item in desktop. More...
virtual void launchModal (const QString &theCmdId)
 Executes feature as a modal dialog box. More...
virtual void addConstraintBrowserMenu (QMenu *theMenu) const
 Add menu items for constraints browser into the given menu. More...
ModuleBase_IWorkshop * workshop () const
 Returns current workshop. More...
virtual QIntList selectionFilters ()
 Returns types of registered module selection filters. More...
virtual Handle selectionFilter (const int theType)
 Returns selection filter. More...
void registerSelectionFilter (const ModuleBase_SelectionFilterType theFilterType, const Handle &theFilter)
 Append selection filter into the module and type of the filter in internal container. More...
virtual ModuleBase_Operation * createOperation (const std::string &theCmdId)
 Creates a new operation. More...
virtual void updateObjectBrowserMenu (const QMap< QString, QAction * > &theStdActions)
 Update state of pop-up menu items in object browser. More...
void getXMLRepresentation (const std::string &theFeatureId, std::string &theXmlCfg, std::string &theDescription)
 Returns XML information by the feature index. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
static void setTexture (const AISObjectPtr &thePrs, const ResultPtr &theResult)
 add texture More...
Protected Slots
virtual void onSelectionChanged ()
 Called when previous operation is finished. More...
void onKeyRelease (ModuleBase_IViewWindow *theWnd, QKeyEvent *theEvent)
 SLOT, that is called by key release in the viewer. More...
void onViewCreated (ModuleBase_IViewWindow *)
 A slot called on view window creation. More...
void onChoiceChanged (ModuleBase_ModelWidget *theWidget, int theIndex)
 A slot to change property panel title by choice type change if the title information exists in the XML definition of this control attribute. More...
virtual void customSubShapesSelectionModes (QIntList &theModes)
void storeConstraintsState (const std::string &theFeatureKindId)
 Sets the constraints states in internal map. More...
void updateConstraintsState (const std::string &theFeatureKind)
 If the feature kind is a geometrical or dimensional constraint, set visible state for all types of constraints. More...
virtual void registerValidators ()
 Register validators for this module. More...
virtual void connectToPropertyPanel (ModuleBase_ModelWidget *theWidget, const bool isToConnect)
 Connects or disconnects to the value changed signal of the property panel widgets. More...
void updateSketcherOnStart (ModuleBase_Operation *theOperation)
 Updates reentrant manager state or sketcher operations for the started operation. More...
void updatePresentationsOnStart (ModuleBase_Operation *theOperation)
 Updates presetnations of results and arguments by operation start. More...
virtual void registerProperties ()
 Register properties of this module. More...
virtual ModuleBase_Operation * getNewOperation (const std::string &theFeatureId)
 Returns new instance of operation object (used in createOperation for customization) More...
void loadProprietaryPlugins ()
 Load plugins required license. More...
void processProprietaryFeatures ()
 Collect features, which have valid license. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
ModuleBase_IWorkshop * myWorkshop
 Reference to workshop. More...
std::map< std::string, std::string > myFeaturesInFiles
 Map of features in XML. More...
std::map< std::string, std::string > myProprietaryFeatures
 Map of features in XML, which require license but not confirmed yet. More...
std::set< std::string > myProprietaryPlugins
 Proprietary plugins. More...
std::set< std::string > myFeaturesValidLicense
 Features, which have valid license. More...
std::map< ModuleBase_SelectionFilterType, Handle > mySelectionFilters
◆ ModuleBase_CustomizeFlag
CustomizeResults
references of other objects referenced to the current feature
results of the current feature
highlighted objects of the active widget
◆ PartSet_Module()
PartSet_Module::PartSet_Module ( ModuleBase_IWorkshop *  theWshop)
theWshopa pointer to a workshop
◆ storeSelection()
void PartSet_Module::storeSelection ( )
Reimplemented from ModuleBase_IModule.
◆ restoreSelection()
void PartSet_Module::restoreSelection ( )
◆ createWidgetByType()
ModuleBase_ModelWidget * PartSet_Module::createWidgetByType ( const std::string &  theType,
QWidget *  theParent,
Config_WidgetAPI *  theWidgetApi
◆ activeWidget()
ModuleBase_ModelWidget * PartSet_Module::activeWidget ( ) const
Implements ModuleBase_IModule.
◆ propertyPanelDefined()
void PartSet_Module::propertyPanelDefined ( ModuleBase_Operation *  theOperation)
◆ createWidgets()
bool PartSet_Module::createWidgets ( const FeaturePtr &  theFeature,
const QString &  theXmlRepr,
QList< ModuleBase_ModelWidget * > &  theWidgets
theFeaturea feature of the started operation
theXmlRepran XML representation of the operation
theWidgetsa list of created widgets
boolean result, false by default
◆ editFeature()
void PartSet_Module::editFeature ( FeaturePtr  theFeature)
theFeaturefeature for editing
◆ canCommitOperation()
bool PartSet_Module::canCommitOperation ( ) const
Result in default implementation is true.
boolean value
◆ launchOperation()
void PartSet_Module::launchOperation ( const QString &  theCmdId,
const bool &  isStartAfterCommitOnly
theCmdIdthe operation name
isStartAfterCommitOnlyoperation is launched if there is no active operation or it is committed
◆ operationStarted()
void PartSet_Module::operationStarted ( ModuleBase_Operation *  theOperation)
theOperationa started operation
Restart sketcher operations automatically it is important to call method of sketch reentrant manager before filling of PP because it fills some created feature attributes, these new values should be used to fill the property panel
state of command actions should be updated after displayed objects modification because deactivation(for example) of objects may influence on selection in the viewer State of command actions may depend on selection in the viewer(e.g. Sketch)
◆ operationResumed()
void PartSet_Module::operationResumed ( ModuleBase_Operation *  theOperation)
theOperationa resumed operation
◆ operationCommitted()
void PartSet_Module::operationCommitted ( ModuleBase_Operation *  theOperation)
theOperationa committed operation
deactivate of overconstraint listener should be performed after Sketch commit (#2176)
◆ operationAborted()
void PartSet_Module::operationAborted ( ModuleBase_Operation *  theOperation)
theOperationan aborted operation
deactivate of overconstraint listener should be performed after Sketch abort (#2176)
◆ operationStopped()
void PartSet_Module::operationStopped ( ModuleBase_Operation *  theOperation)
theOperationa stopped operation
◆ currentOperation()
ModuleBase_Operation * PartSet_Module::currentOperation ( ) const
◆ canUndo()
bool PartSet_Module::canUndo ( ) const
the boolean result
◆ canRedo()
bool PartSet_Module::canRedo ( ) const
the boolean result
◆ canApplyAction()
bool PartSet_Module::canApplyAction ( const ObjectPtr &  theObject,
const QString &  theActionId
theObjecta checked object
theActionIdan identifier of action, to be found in the menu manager like "DELETE_CMD"
the a booean result
◆ canEraseObject()
bool PartSet_Module::canEraseObject ( const ObjectPtr &  theObject) const
Asks the sketch manager.
a boolean value Returns whether the object can be erased at the bounds of the active operation. The sub-objects of the current operation can not be erased
theObjecta model object
◆ canDisplayObject()
bool PartSet_Module::canDisplayObject ( const ObjectPtr &  theObject) const
Display only current operation results for usual operation and ask the sketcher manager if it is a sketch operation
◆ canUsePreselection()
bool PartSet_Module::canUsePreselection ( const QString &  thePreviousOperationKind,
const QString &  theStartedOperationKind
thePreviousOperationKinda kind of previous operation
theStartedOperationKinda kind of a new operation
◆ canActivateSelection()
bool PartSet_Module::canActivateSelection ( const ObjectPtr &  theObject) const
theObjectsa list of hidden objects Returns true if selection for the object can be activate. For sketch operation allow the selection activation if the operation is edit, for other operation uses the default result
◆ addObjectBrowserMenu()
void PartSet_Module::addObjectBrowserMenu ( QMenu *  theMenu) const
theMenua popup menu to be shown in the object browser
◆ addViewerMenu()
bool PartSet_Module::addViewerMenu ( const QMap< QString, QAction * > &  theStdActions,
QMap< int, QAction * > &  theMenuActions
theStdActionsa map of standard actions
theParenta parent widget
theMenuActionsmap of action/menu for the desirable index in the viewer menu
true if items are added and there is no necessity to provide standard menu
◆ activeSelectionModes()
void PartSet_Module::activeSelectionModes ( QIntList &  theModes)
theModesa list of modes
◆ moduleSelectionModes()
void PartSet_Module::moduleSelectionModes ( int  theModesType,
QIntList &  theModes
theModesTypecombination of available selection filters
theModesa selection modes to be extended
◆ moduleSelectionFilters()
void PartSet_Module::moduleSelectionFilters ( const QIntList &  theFilterTypes,
SelectMgr_ListOfFilter &  theSelectionFilters
theFilterTypescontainer of available selection filters
theSelectionFilters[out] container to be extend by elements
◆ isMouseOverWindow()
bool PartSet_Module::isMouseOverWindow ( )
◆ sketchMgr()
PartSet_SketcherMgr * PartSet_Module::sketchMgr ( ) const
◆ sketchReentranceMgr()
PartSet_SketcherReentrantMgr * PartSet_Module::sketchReentranceMgr ( ) const
◆ getGeomSelection()
void PartSet_Module::getGeomSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theSelected,
AttributePtr &  theAttribute
theSelecteda viewer selection
theObjecta selected model object
theAttributea selected model attribute
◆ overconstraintListener()
PartSet_OverconstraintListener * PartSet_Module::overconstraintListener ( )
the listener
◆ isSketchNeutralPointActivated()
bool PartSet_Module::isSketchNeutralPointActivated ( ) const
boolean value
◆ closeDocument()
void PartSet_Module::closeDocument ( )
◆ clearViewer()
void PartSet_Module::clearViewer ( )
◆ processEvent()
void PartSet_Module::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
theMessagean event message
Implements Events_Listener.
◆ setCustomized()
void PartSet_Module::setCustomized ( const FeaturePtr &  theFeature)
theFeaturea feature
◆ isCustomPrsActivated()
bool PartSet_Module::isCustomPrsActivated ( const ModuleBase_CustomizeFlag &  theFlag) const
theFlaga flag of level of customization, which means that only part of sub-elements
boolean value
◆ activateCustomPrs()
void PartSet_Module::activateCustomPrs ( const FeaturePtr &  theFeature,
const ModuleBase_CustomizeFlag &  theFlag,
theFeaturea feature instance
theUpdateViewerthe parameter whether the viewer should be update immediately
◆ deactivateCustomPrs()
void PartSet_Module::deactivateCustomPrs ( const ModuleBase_CustomizeFlag &  theFlag,
◆ customizeFeature()
bool PartSet_Module::customizeFeature ( ObjectPtr  theObject,
Update the object presentable properties such as color, lines width and other If the object is result with the color attribute value set, it is used, otherwise the customize is applied to the object's feature if it is a custom prs
theObjectan object instance
theFlaga flag of level of customization, which means that only part of sub-elements should be updated(e.g. only highlighted elements)
theUpdateViewerthe parameter whether the viewer should be updated immediately
true if the object is modified
◆ disableCustomMode()
void PartSet_Module::disableCustomMode ( ModuleBase_CustomizeFlag  theMode)
theModea mode to disable
◆ enableCustomModes()
void PartSet_Module::enableCustomModes ( )
◆ customizeObjectBrowser()
void PartSet_Module::customizeObjectBrowser ( QWidget *  theObjectBrowser)
theObjectBrowsera pinter on Object Browser widget
◆ getVisualLayerId()
int PartSet_Module::getVisualLayerId ( ) const
◆ createPresentation()
AISObjectPtr PartSet_Module::createPresentation ( const ObjectPtr &  theResult)
theResultan object for presentation
created presentation or NULL(default value)
◆ customizePresentation()
void PartSet_Module::customizePresentation ( const ObjectPtr &  theObject,
const AISObjectPtr &  thePrs
theObjectan object for presentation
thePrsa presentation object
set texture parameters, if any
◆ findPresentedObject()
ObjectPtr PartSet_Module::findPresentedObject ( const AISObjectPtr &  theAIS) const
If last line finished on vertex the lines creation sequence has to be break
◆ canBeShaded()
bool PartSet_Module::canBeShaded ( Handle  theAIS) const
theAISpresentation to be checked
boolean value
◆ updateViewerMenu()
void PartSet_Module::updateViewerMenu ( const QMap< QString, QAction * > &  theStdActions)
theStdActions- a map of standard actions
◆ isActionEnableStateFixed()
bool PartSet_Module::isActionEnableStateFixed ( const int  theActionId) const
theActionIdan action index: Accept or Accept All
boolean value
◆ getFeatureError()
QString PartSet_Module::getFeatureError ( const FeaturePtr &  theFeature)
string value
◆ grantedOperationIds()
void PartSet_Module::grantedOperationIds ( ModuleBase_Operation *  theOperation,
QStringList &  theIds
◆ widgetStateChanged()
void PartSet_Module::widgetStateChanged ( int  thePreviousState)
thePreviousStatethe previous widget value state
◆ processEnter()
bool PartSet_Module::processEnter ( const std::string &  thePreviousAttributeID)
It gives the reentrance manager to process the enter.
thePreviousAttributeIDan index of the previous active attribute
◆ beforeOperationStopped()
void PartSet_Module::beforeOperationStopped ( ModuleBase_Operation *  theOperation)
◆ findShape()
GeomShapePtr PartSet_Module::findShape ( const AttributePtr &  theAttribute)
theAttributean attribute
a geom shape
◆ findAttribute()
AttributePtr PartSet_Module::findAttribute ( const ObjectPtr &  theObject,
const GeomShapePtr &  theGeomShape
theObjectan object of the attribute
theGeomShapea geom shape
theAttribute
◆ reentrantMessage()
std::shared_ptr< Events_Message > PartSet_Module::reentrantMessage ( )
◆ setReentrantPreSelection()
void PartSet_Module::setReentrantPreSelection ( const std::shared_ptr< Events_Message > &  theMessage)
theMessagea message of reentrant operation
◆ rootNode()
ModuleBase_ITreeNode * PartSet_Module::rootNode ( ) const
◆ getWorkshop()
XGUI_Workshop * PartSet_Module::getWorkshop ( ) const
◆ createFeatures()
void PartSet_Module::createFeatures ( )
◆ setTexture()
void PartSet_Module::setTexture ( const AISObjectPtr &  thePrs,
const ResultPtr &  theResult
add texture
set color to white and change material aspect, in order to keep a natural apect of the image.
◆ onObjectDisplayed
void PartSet_Module::onObjectDisplayed ( ObjectPtr  theObject,
AISObjectPtr  theAIS
virtualslot
theObjecta data object
theAISa presentation object
◆ onBeforeObjectErase
void PartSet_Module::onBeforeObjectErase ( ObjectPtr  theObject,
AISObjectPtr  theAIS
virtualslot
◆ onViewTransformed
void PartSet_Module::onViewTransformed ( int  theTrsfType = 2)
virtualslot
theTrsfTypetype of transformation
◆ onRemoveConflictingConstraints
void PartSet_Module::onRemoveConflictingConstraints ( )
slot
◆ onSelectionChanged
void PartSet_Module::onSelectionChanged ( )
protectedvirtualslot
◆ onKeyRelease
void PartSet_Module::onKeyRelease ( ModuleBase_IViewWindow *  theWnd,
QKeyEvent *  theEvent
protectedslot
theWnda view window
theEventthe key event
◆ onViewCreated
void PartSet_Module::onViewCreated ( ModuleBase_IViewWindow *  )
protectedslot
◆ onChoiceChanged
void PartSet_Module::onChoiceChanged ( ModuleBase_ModelWidget *  theWidget,
int  theIndex
protectedslot
theWidgeta sender
theIndexthe current choice index
◆ customSubShapesSelectionModes()
void PartSet_Module::customSubShapesSelectionModes ( QIntList &  theModes)
◆ storeConstraintsState()
void PartSet_Module::storeConstraintsState ( const std::string &  theFeatureKindId)
If the feature kind is a dimensional constraint other dimensions are shown.
theFeatureKindIda feature kind
◆ updateConstraintsState()
void PartSet_Module::updateConstraintsState ( const std::string &  theFeatureKind)
◆ registerValidators()
void PartSet_Module::registerValidators ( )
◆ connectToPropertyPanel()
void PartSet_Module::connectToPropertyPanel ( ModuleBase_ModelWidget *  theWidget,
theWidgeta property control widget
isToConnecta boolean value whether connect or disconnect
◆ updateSketcherOnStart()
void PartSet_Module::updateSketcherOnStart ( ModuleBase_Operation *  theOperation)
theOperationthe started operation
◆ updatePresentationsOnStart()
void PartSet_Module::updatePresentationsOnStart ( ModuleBase_Operation *  theOperation)
◆ actionCreated()
void ModuleBase_IModule::actionCreated ( QAction *  theFeature)
◆ launchModal()
void ModuleBase_IModule::launchModal ( const QString &  theCmdId)
◆ addConstraintBrowserMenu()
virtual void ModuleBase_IModule::addConstraintBrowserMenu ( QMenu *  theMenu) const
inlinevirtualinherited
theMenua popup menu to be shown in the constraints browser
◆ workshop()
ModuleBase_IWorkshop * ModuleBase_IModule::workshop ( ) const
◆ selectionFilters()
QIntList ModuleBase_IModule::selectionFilters ( )
theSelectionFilters[out] container of type value
◆ selectionFilter()
Handle ModuleBase_IModule::selectionFilter ( const int  theType)
theTypeselection filter type
theFilterinstance of filter
◆ registerSelectionFilter()
void ModuleBase_IModule::registerSelectionFilter ( const ModuleBase_SelectionFilterType  theFilterType,
const Handle &  theFilter
theFilterTypeselection filter type
theFilteradded filter
◆ createOperation()
ModuleBase_Operation * ModuleBase_IModule::createOperation ( const std::string &  theCmdId)
◆ updateObjectBrowserMenu()
virtual void ModuleBase_IModule::updateObjectBrowserMenu ( const QMap< QString, QAction * > &  theStdActions)
◆ getXMLRepresentation()
void ModuleBase_IModule::getXMLRepresentation ( const std::string &  theFeatureId,
std::string &  theXmlCfg,
std::string &  theDescription
theFeatureIda feature id
theXmlCfgXML configuration
theDescriptionfeature description
◆ resumed
void ModuleBase_IModule::resumed ( ModuleBase_Operation *  theOp)
signalinherited
theOpa resumed operation
◆ onFeatureTriggered
void ModuleBase_IModule::onFeatureTriggered ( )
virtualslotinherited
◆ registerProperties()
virtual void ModuleBase_IModule::registerProperties ( )
◆ getNewOperation()
ModuleBase_Operation * ModuleBase_IModule::getNewOperation ( const std::string &  theFeatureId)
◆ loadProprietaryPlugins()
void ModuleBase_IModule::loadProprietaryPlugins ( )
◆ processProprietaryFeatures()
void ModuleBase_IModule::processProprietaryFeatures ( )
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
◆ myWorkshop
ModuleBase_IWorkshop* ModuleBase_IModule::myWorkshop
◆ myFeaturesInFiles
std::map<std::string, std::string> ModuleBase_IModule::myFeaturesInFiles
◆ myProprietaryFeatures
std::map<std::string, std::string> ModuleBase_IModule::myProprietaryFeatures
◆ myProprietaryPlugins
std::set<std::string> ModuleBase_IModule::myProprietaryPlugins
◆ myFeaturesValidLicense
std::set<std::string> ModuleBase_IModule::myFeaturesValidLicense
