A class for processing overconstraint situation. More...
#include <PartSet_OverconstraintListener.h>
| PartSet_OverconstraintListener (ModuleBase_IWorkshop *theWorkshop) | |
| Constructor. More... | |
| void | setActive (const bool &theActive) |
| If active state is changed, update fully defined state and sketch sub-entities color. More... | |
| void | getCustomColor (const ObjectPtr &theObject, std::vector< int > &theColor) |
| Returns true if the object belongs to internal container of conflicting objects. More... | |
| virtual void | processEvent (const std::shared_ptr< Events_Message > &theMessage) |
| Redefinition of Events_Listener method. More... | |
| bool | isConflictingObject (const ObjectPtr &theObject) const |
| const std::set< ObjectPtr > & | conflictingObjects () const |
| const std::set< ObjectPtr > & | objectsToRemove () const |
| bool | isFullyConstrained () const |
| virtual EVENTS_EXPORT bool | groupMessages () |
| Listener that needs mostly grouped messages received returns true in this method. More... | |
| bool | appendConflictingObjects (const std::set< ObjectPtr > &theObjects) |
| Append objects to the internal container of conflicting object, redisplay necessary objects. More... | |
| bool | repairConflictingObjects (const std::set< ObjectPtr > &theObjects) |
| Removes objects from internal container of conflicting object, redisplay necessary objects. More... | |
| void | redisplayObjects (const std::set< ObjectPtr > &theObjects) |
| Sends update object signal for each object in the container and flush it. More... | |
| void | groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage) |
| Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More... | |
| EVENTS_EXPORT void | flushGrouped (const Events_ID &theID) |
| Sends myGroups on flush finish. More... | |
It contains is a list of sketch constraints with conflicts.
| PartSet_OverconstraintListener::PartSet_OverconstraintListener | ( | ModuleBase_IWorkshop * | theWorkshop | ) |
| theWorkshop | a current workshop to obtain AIS presentation from displayer |
| void PartSet_OverconstraintListener::setActive | ( | const bool & | theActive | ) |
| theActive | a state |
returned to default state, no custom color for it
| void PartSet_OverconstraintListener::getCustomColor | ( | const ObjectPtr & | theObject, |
| std::vector< int > & | theColor | ||
| theObject | an object to be checked |
| theColor | the output container to be filled in [red, green, blue] values |
Implements Events_Listener.
protected |
| theObjects | a list of new conflicting objects |
protected |
| theObjects | a list of repaired objects |
protected |
| theObjects | a list of object to be redisplayed |
inlinevirtualinherited |
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
protectedinherited |
