ModuleBase_IWorkshop.h
20#ifndef ModuleBase_IWorkshop_H
21#define ModuleBase_IWorkshop_H
23#include "ModuleBase.h"
24#include "ModuleBase_Definitions.h"
25#include <ModuleBase_FilterValidated.h>
26
27#include <ModelAPI_Object.h>
28#include <GeomAPI_AISObject.h>
29#include <Config_FeatureMessage.h>
30
31#include <QObject>
32
41class QMainWindow;
42
47class MODULEBASE_EXPORT ModuleBase_IWorkshop : public QObject
48{
49Q_OBJECT
50 public:
53 ModuleBase_IWorkshop(QObject* theParent);
54
55 virtual ~ModuleBase_IWorkshop()
56 {}
57
59 virtual ModuleBase_ISelection* selection() const = 0;
60
62 virtual ModuleBase_IModule* module() const = 0;
63
65 virtual ModuleBase_IViewer* viewer() const = 0;
66
69
71 virtual ModuleBase_IErrorMgr* errorMgr() const = 0;
72
75 Handle(ModuleBase_FilterValidated) validatorFilter();
76
79
82
84 virtual bool canStartOperation(QString theId, bool& isCommitted) = 0;
85
88 virtual void processLaunchOperation(ModuleBase_Operation* theOperation) = 0;
89
93 virtual ModuleBase_Operation* findStartedOperation(const QString& theId) = 0;
94
98 virtual bool canStopOperation(ModuleBase_Operation* theOperation) = 0;
99
103 virtual void stopOperation(ModuleBase_Operation* theOperation,
104 bool& isCommitted) = 0;
105
108 virtual AISObjectPtr findPresentation(const ObjectPtr& theObject) const = 0;
109
112 virtual ObjectPtr findPresentedObject(const AISObjectPtr& theAIS) const = 0;
113
116 virtual bool isVisible(const ObjectPtr& theObject) const = 0;
117
119 virtual QObjectPtrList displayedObjects() const = 0;
120
124 virtual void setSelected(const QList<std::shared_ptr<ModuleBase_ViewerPrs>>& theValues) = 0;
125
128 virtual void setStatusBarMessage(const QString& theMessage) = 0;
129
131 virtual void updateCommandStatus() = 0;
132
135 virtual std::shared_ptr<Config_FeatureMessage> featureInfo(const QString& theId) const = 0;
136
138 virtual QMainWindow* desktop() const = 0;
139
142 virtual bool hasSHIFTPressed() const = 0;
143
144 virtual void deactivateCurrentSelector() = 0;
145
148 virtual bool enableUpdateViewer(bool isEnabled) = 0;
149
153 virtual void applyCurrentSelectionModes(const AISObjectPtr& theAIS) = 0;
154
156 virtual void undo() = 0;
157
159 virtual void setCancelEnabled(bool toEnable) = 0;
160
162 virtual bool isCancelEnabled() const = 0;
163
165 virtual void showHelpPage(const QString& thePage) const = 0;
166
167signals:
170
173
174protected:
177};
178
179#endif
A filter which provides filtering of selection in 3d viewer.
Definition: ModuleBase_FilterValidated.h:39
An interface to Errors manager object.
Definition: ModuleBase_IErrorMgr.h:38
Interface to a module.
Definition: ModuleBase_IModule.h:70
A class for Property panel object definition.
Definition: ModuleBase_IPropertyPanel.h:35
A class which provides interface of activation/deactivate selection modes and using selection filters...
Definition: ModuleBase_ISelectionActivate.h:36
A class which provides access to selection.
Definition: ModuleBase_ISelection.h:44
A Base object for definition of connector object to Salome Viewer.
Definition: ModuleBase_IViewer.h:47
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
virtual void showHelpPage(const QString &thePage) const =0
Show help of a current operation.
virtual bool isCancelEnabled() const =0
Returns current state of cancel button.
virtual AISObjectPtr findPresentation(const ObjectPtr &theObject) const =0
Returns AIS object by data object.
virtual ModuleBase_IViewer * viewer() const =0
Returns current viewer.
virtual std::shared_ptr< Config_FeatureMessage > featureInfo(const QString &theId) const =0
Returns feature info according to given feature ID.
virtual void stopOperation(ModuleBase_Operation *theOperation, bool &isCommitted)=0
Commits if possible or aborts the given operation.
virtual void undo()=0
Undo last command.
virtual ModuleBase_ISelectionActivate * selectionActivate() const =0
A selection activate in 3D View handler.
virtual bool isVisible(const ObjectPtr &theObject) const =0
Returns true if the object is displayed.
virtual void applyCurrentSelectionModes(const AISObjectPtr &theAIS)=0
The methods applies current defined selection modes to given AIS presentation.
virtual ModuleBase_IPropertyPanel * propertyPanel() const =0
Returns property panel.
virtual ObjectPtr findPresentedObject(const AISObjectPtr &theAIS) const =0
Returns data object by AIS.
virtual ModuleBase_Operation * findStartedOperation(const QString &theId)=0
Returns started operation by the operation identifier.
virtual ModuleBase_IErrorMgr * errorMgr() const =0
Returns error manager.
virtual bool enableUpdateViewer(bool isEnabled)=0
Temporary enable or disable viewer update.
virtual void processLaunchOperation(ModuleBase_Operation *theOperation)=0
Performs the operation launch.
Handle myValidatorFilter
A filter to process an attribute validators.
Definition: ModuleBase_IWorkshop.h:176
virtual ModuleBase_IModule * module() const =0
Returns instance of loaded module.
virtual bool hasSHIFTPressed() const =0
Returns true if SHIFT is pressed.
virtual void setStatusBarMessage(const QString &theMessage)=0
Shows the message in the status bar.
virtual ModuleBase_Operation * currentOperation() const =0
Returns currently active operation.
virtual QMainWindow * desktop() const =0
Returns main window of the application.
virtual void updateCommandStatus()=0
Update of commands status.
virtual ModuleBase_ISelection * selection() const =0
Return current selection instance.
virtual bool canStopOperation(ModuleBase_Operation *theOperation)=0
Returns true if the operation with id theId can be stopped.
virtual void setSelected(const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)=0
Select features clearing previous selection.
virtual bool canStartOperation(QString theId, bool &isCommitted)=0
Returns true if the operation with id theId can be started.
virtual void setCancelEnabled(bool toEnable)=0
Set enabled state of cancel button in property panel.
void propertyPanelActivated()
Signal which is emitted after activation of property panel.
void selectionChanged()
Signal selection changed.
virtual QObjectPtrList displayedObjects() const =0
Returns list of currently displayed objects.
Base class for all operations.
Definition: ModuleBase_Operation.h:53
Presentation.
Definition: ModuleBase_ViewerPrs.h:37
