Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetNameEdit (QWidget *theParent, const Config_WidgetAPI *theData, const std::string &thePlaceHolder) | |
| virtual bool | focusTo () |
| Redefinition of virtual method. More... | |
| Returns True if data of its feature was modified during operation. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| void | activate () |
Protected Slots | |
| Returns true if the event is processed. More... | |
Protected Attributes | |
| QLineEdit * | myLineEdit |
| A line edit control. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
inlinevirtual |
inlinevirtual |
protectedvirtual |
Reimplemented from ModuleBase_WidgetLineEdit.
protectedvirtual |
protectedvirtualinherited |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
Reimplemented in ModuleBase_PagedContainer, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ParametersPlugin_WidgetParamsMgr, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, and PartSet_WidgetSketchLabel.
protectedslotinherited |
A feature ID.
