ModuleBase_PagedContainer Class Referenceabstract
This is an abstract interface to be used for not model container widget such as switch or tool box. More...
#include <ModuleBase_PagedContainer.h>
Inheritance diagram for ModuleBase_PagedContainer:
enum  ValueState { Stored , ModifiedInPP , ModifiedInViewer , Reset }
 State of the widget. More...
enum  EnableState { On , Off , DefinedInPreferences }
 the value is reset More...
Signals
void beforeValuesChanged ()
 The signal about widget values are to be changed. More...
void valuesChanged ()
 The signal about widget values changed. More...
void valuesModified ()
 The signal about widget values modified. More...
void afterValuesChanged ()
void beforeValuesRestored ()
 The signal about widget values are to be restored. More...
void afterValuesRestored ()
void keyReleased (QObject *theObject, QKeyEvent *theEvent)
 The signal about key release on the control, that corresponds to the attribute. More...
void enterClicked (QObject *theObject)
 The signal is emitted if the enter is clicked in the control of the widget. More...
void focusInWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is get focus. More...
void focusOutWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is lost focus. More...
void valueStateChanged (int theState)
 The signal about value state modification. More...
void objectUpdated ()
 The signal is emitted after flush of updates singal for the widget. More...
 ModuleBase_PagedContainer (QWidget *theParent, const Config_WidgetAPI *theData)
 A constructor. More...
virtual int addPage (ModuleBase_PageBase *theWidget, const QString &theName, const QString &theCaseId, const QPixmap &theIcon, const QString &theTooltip)
 Add a new page. More...
virtual QList< QWidget * > getControls () const
 Redefinition of virtual function. More...
virtual bool focusTo ()
virtual void setHighlighted (bool isHighlighted)
virtual void enableFocusProcessing ()
virtual void onFeatureAccepted ()
 The slot is called when user press Ok or OkPlus buttons in the parent property panel. More...
bool reset ()
 Fills the widget with default values. More...
bool isInitialized (ObjectPtr theObject) const
 Returns the state whether the attribute of the feature is initialized. More...
virtual void selectionModes (int &theModuleSelectionModes, QIntList &theModes)
 Fills given container with selection modes if the widget has it. More...
virtual void selectionFilters (QIntList &theModuleSelectionFilters, SelectMgr_ListOfFilter &theSelectionFilters)
 Appends into container of workshop selection filters. More...
bool isComputedDefault () const
 Returns true, if default value of the widget should be computed on operation's execute, like radius for circle's constraint (can not be zero) More...
std::string getDefaultValue () const
 Returns true, if default value of the widget is defined in the XML and it is not the computed value. More...
bool isInternal () const
 Returns true, if widget is internal. More...
bool isObligatory () const
 Returns true, if the obligatory value of the widget is not defined in the XML or has true value. More...
virtual bool isValueEnabled () const
 Returns true, if the widget value is enabled and might be modified manually. More...
bool isUseReset () const
 Returns this parameter value in the xml file. More...
std::string isModifiedInEdit () const
ValueState getValueState () const
 Returns this widget value state. More...
void processValueState ()
 Stores the widget value if it is modified. More...
Events_InfoMessage getValueStateError () const
 Returns an attribute error according to the value state It exists in all cases excepring the "Store" case. More...
virtual bool isViewerSelector ()
 Defines if it is supposed that the widget should interact with the viewer. More...
virtual bool canAcceptFocus () const
 Defines if it is supported to set the value in this widget By default it returns true. More...
virtual QString getError (const bool theValueStateChecked=true) const
 Returns the widget error, get it from the attribute validator and state of the widget If the feature is correct, it returns an empty value. More...
virtual bool setSelection (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues, const bool theToValidate)
 Set the given wrapped value to the current widget This value should be processed in the widget according to the needs. More...
virtual void getHighlighted (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Returns values which should be highlighted when the whidget is active. More...
virtual bool isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
 Checks if the selection presentation is valid in widget. More...
ModuleBase_WidgetValidator * widgetValidator ()
 Returns widget validator, by default it is NULL. To be created in a child if necessary. More...
bool restoreValue ()
 Restore value from attribute data to the widget's control. More...
bool storeValue ()
 Saves the internal parameters to the given feature. More...
virtual void selectContent ()
 Select the internal content if it can be selected. It is empty in the default realization. More...
void activate ()
 The method called when widget is activated. More...
virtual void deactivate ()
 The method called when widget is deactivated. More...
virtual void updateAfterDeactivation ()
 Opportunity to do something after the active widget of the property panel changed. More...
virtual void updateAfterActivation ()
virtual bool needToBeActivated ()
 The method called if widget should be activated always. More...
QWidget * getControlAcceptingFocus (const bool isFirst)
 Returns the first or the last control that can accept the focus. More...
virtual bool eventFilter (QObject *theObject, QEvent *theEvent)
 FocusIn events processing. More...
std::string attributeID () const
 Returns the attribute name. More...
FeaturePtr feature () const
virtual std::string context () const
virtual void setFeature (const FeaturePtr &theFeature, const bool theToStoreValue=false, const bool isUpdateFlushed=true)
 Set feature which is processing by active operation. More...
virtual void setEditingMode (bool isEditing)
 Editing mode depends on mode of current operation. This value is defined by it. More...
bool isEditingMode () const
virtual bool canProcessAction (ModuleBase_ActionType theActionType, bool &isActionEnabled)
 Returns true if the action can be processed. More...
virtual bool processAction (ModuleBase_ActionType theActionType, const ActionParamPtr &theParam=ActionParamPtr())
 Returns true if the event is processed. The default implementation is empty, returns false. More...
virtual QList< ActionInfo > actionsList (ModuleBase_ActionType theActionType) const
 Returns list of accessible actions for Undo/Redo commands. More...
void updateObject (ObjectPtr theObj)
 Sends Update and Redisplay for the given object. More...
virtual QString translate (const std::string &theStr) const
 Translate passed string with widget context() More...
void emitFocusInWidget ()
 Emit focus in widget to set this control as active in property panel. More...
virtual bool usesAttribute () const
 Returns True if the widget uses feature attribute. More...
virtual bool isInformative () const
 Returns True in case if the widget contains useful information for inspection tool. More...
virtual void showInformativePage ()
 If widgets has several panels then this method has to show a page which contains information for current feature. More...
 Returns True if data of its attribute was modified. More...
virtual void setReadOnly (bool isReadOnly)
virtual bool isReadOnly () const
bool canUseExternalParts () const
 Returns true if the widget should have access to external parts. More...
static ModuleBase_ModelWidget * findModelWidget (ModuleBase_IPropertyPanel *theProp, QWidget *theWidget)
 Finds model widget parent of the given sub widget. More...
Protected Slots
void onPageChanged ()
 A slot called on page change. More...
void onWidgetValuesChanged ()
 Processing of values changed in model widget by store the current value to the feature. More...
void onWidgetValuesModified ()
 Changes widget state. More...
virtual int currentPageIndex () const =0
 Returns index of current page. More...
virtual void setCurrentPageIndex (int)=0
 Set current page by index. More...
virtual void activateCustom ()
virtual bool storeValueCustom ()
virtual bool restoreValueCustom ()
void setDefaultValue (const std::string &theValue)
 Sets default value of widget. More...
void setAttributeID (const std::string &theAttribute)
 Set the attribute name. More...
ValueState setValueState (const ValueState &theState)
 Sets the current value state. More...
bool blockValueState (const bool theBlocked)
 Blocks the value state change. More...
virtual void initializeValueByActivate ()
 Compute the feature default value and fill the controls with it or store the control value to the feature. More...
virtual bool resetCustom ()
virtual bool processEnter ()
virtual bool processEscape ()
virtual bool processDelete ()
virtual bool processSelection ()
 Returns true if envent is processed. It applies workshop selection for the widget attribute. More...
bool myRemeberChoice
std::unique_ptr< ModuleBase_WidgetValidator > myWidgetValidator
 own validator, by default it is zero More...
std::string myAttributeID
 The attribute name of the model feature. More...
FeaturePtr myFeature
 A feature which is processing by active operation. More...
std::string myFeatureId
 A feature ID. More...
bool myIsObligatory
 Flag which shows whether current widget is obligatory The non-obligatory widgets should not accept the focus in the property panel. More...
EnableState myIsValueEnabled
 Flag about value of the control is enabled (can be modified) More...
ValueState myState
 The widget value state. More...
◆ ValueState
ModifiedInPP
modification is finished and applied to the model
ModifiedInViewer
modification has not been finished and set to the model yet
Reset
modification performed by viewer events
◆ EnableState
the value is reset
Off
the widget value is always enabled
the widget value is always disabled
the widget value enable state is defined in preferences
◆ ModuleBase_PagedContainer()
ModuleBase_PagedContainer::ModuleBase_PagedContainer ( QWidget *  theParent,
const Config_WidgetAPI *  theData
A constructor.
theParenta parent widget
theDataa data of the widget
◆ addPage()
int ModuleBase_PagedContainer::addPage ( ModuleBase_PageBase *  theWidget,
const QString &  theName,
const QString &  theCaseId,
const QPixmap &  theIcon,
const QString &  theTooltip
Add a new page.
theWidgeta page object
theNamea name of the page
theCaseIdan Id of the page
theIconaqn Icon of the page
Reimplemented in ModuleBase_WidgetRadiobox, ModuleBase_WidgetSwitch, and ModuleBase_WidgetToolbox.
◆ getControls()
QList< QWidget * > ModuleBase_PagedContainer::getControls ( ) const
◆ focusTo()
bool ModuleBase_PagedContainer::focusTo ( )
◆ setHighlighted()
void ModuleBase_PagedContainer::setHighlighted ( bool  isHighlighted)
◆ enableFocusProcessing()
void ModuleBase_PagedContainer::enableFocusProcessing ( )
◆ onFeatureAccepted()
void ModuleBase_PagedContainer::onFeatureAccepted ( )
◆ currentPageIndex()
virtual int ModuleBase_PagedContainer::currentPageIndex ( ) const
protectedpure virtual
Implemented in ModuleBase_WidgetRadiobox, ModuleBase_WidgetSwitch, and ModuleBase_WidgetToolbox.
◆ setCurrentPageIndex()
virtual void ModuleBase_PagedContainer::setCurrentPageIndex ( int  )
Implemented in ModuleBase_WidgetSwitch, ModuleBase_WidgetRadiobox, and ModuleBase_WidgetToolbox.
◆ activateCustom()
void ModuleBase_PagedContainer::activateCustom ( )
◆ storeValueCustom()
bool ModuleBase_PagedContainer::storeValueCustom ( )
◆ restoreValueCustom()
bool ModuleBase_PagedContainer::restoreValueCustom ( )
◆ onPageChanged
void ModuleBase_PagedContainer::onPageChanged ( )
protectedslot
◆ reset()
bool ModuleBase_ModelWidget::reset ( )
true if the widget current value is reset
◆ isInitialized()
bool ModuleBase_ModelWidget::isInitialized ( ObjectPtr  theObject) const
theObjecta model feature to be checked
the boolean result
◆ selectionModes()
void ModuleBase_ModelWidget::selectionModes ( int &  theModuleSelectionModes,
QIntList &  theModes
[out]theModuleSelectionModesmodule additional modes, -1 means all default modes
[out]theModesa container of modes
◆ selectionFilters()
void ModuleBase_ModelWidget::selectionFilters ( QIntList &  theModuleSelectionFilters,
SelectMgr_ListOfFilter &  theSelectionFilters
[out]theModuleSelectionFiltersmodule additional modes, -1 means all default modes
[out]theSelectionFiltersselection filters
◆ isComputedDefault()
bool ModuleBase_ModelWidget::isComputedDefault ( ) const
◆ getDefaultValue()
std::string ModuleBase_ModelWidget::getDefaultValue ( ) const
the boolean result
◆ isInternal()
bool ModuleBase_ModelWidget::isInternal ( ) const
the boolean result
◆ isObligatory()
bool ModuleBase_ModelWidget::isObligatory ( ) const
the boolean result
◆ isValueEnabled()
bool ModuleBase_ModelWidget::isValueEnabled ( ) const
the boolean result
◆ isUseReset()
bool ModuleBase_ModelWidget::isUseReset ( ) const
the boolean result
◆ isModifiedInEdit()
std::string ModuleBase_ModelWidget::isModifiedInEdit ( ) const
the boolean result
◆ getValueState()
ValueState ModuleBase_ModelWidget::getValueState ( ) const
the enumeration result
◆ processValueState()
void ModuleBase_ModelWidget::processValueState ( )
◆ getValueStateError()
Events_InfoMessage ModuleBase_ModelWidget::getValueStateError ( ) const
◆ isViewerSelector()
virtual bool ModuleBase_ModelWidget::isViewerSelector ( )
inlinevirtualinherited
◆ canAcceptFocus()
virtual bool ModuleBase_ModelWidget::canAcceptFocus ( ) const
◆ getError()
QString ModuleBase_ModelWidget::getError ( const bool  theValueStateChecked = true) const
theValueStateCheckedthe boolean flag if the state of the widget should be checked
string value
◆ setSelection()
virtual bool ModuleBase_ModelWidget::setSelection ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues,
theValuesthe wrapped selection values
theToValidatethe boolean value whether the value should be checked by filters
◆ getHighlighted()
virtual void ModuleBase_ModelWidget::getHighlighted ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
◆ isValidSelectionCustom()
virtual bool ModuleBase_ModelWidget::isValidSelectionCustom ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue)
theValuea selected presentation in the view
a boolean value
◆ widgetValidator()
ModuleBase_WidgetValidator * ModuleBase_ModelWidget::widgetValidator ( )
◆ restoreValue()
bool ModuleBase_ModelWidget::restoreValue ( )
True in success
◆ storeValue()
bool ModuleBase_ModelWidget::storeValue ( )
True in success
◆ selectContent()
virtual void ModuleBase_ModelWidget::selectContent ( )
◆ activate()
void ModuleBase_ModelWidget::activate ( )
◆ deactivate()
◆ updateAfterDeactivation()
virtual void ModuleBase_ModelWidget::updateAfterDeactivation ( )
◆ updateAfterActivation()
virtual void ModuleBase_ModelWidget::updateAfterActivation ( )
◆ needToBeActivated()
virtual bool ModuleBase_ModelWidget::needToBeActivated ( )
◆ getControlAcceptingFocus()
QWidget * ModuleBase_ModelWidget::getControlAcceptingFocus ( const bool  isFirst)
isFirstif true, the first controls is returned or the last one
a control from a list of controls
◆ eventFilter()
bool ModuleBase_ModelWidget::eventFilter ( QObject *  theObject,
QEvent *  theEvent
◆ attributeID()
std::string ModuleBase_ModelWidget::attributeID ( ) const
the string value
◆ feature()
FeaturePtr ModuleBase_ModelWidget::feature ( ) const
Current feature
◆ context()
virtual std::string ModuleBase_ModelWidget::context ( ) const
Context for translation
◆ setFeature()
void ModuleBase_ModelWidget::setFeature ( const FeaturePtr &  theFeature,
const bool  theToStoreValue = false,
const bool  isUpdateFlushed = true
theFeaturea feature object
theToStoreValuea value about necessity to store the widget value to the feature
isUpdateFlusheda flag if update should be flushed on store value
◆ setEditingMode()
virtual void ModuleBase_ModelWidget::setEditingMode ( bool  isEditing)
◆ isEditingMode()
bool ModuleBase_ModelWidget::isEditingMode ( ) const
Current Editing mode
◆ canProcessAction()
bool ModuleBase_ModelWidget::canProcessAction ( ModuleBase_ActionType  theActionType,
bool &  isActionEnabled
theActionTypean action type
isActionEnabledif true, the enable state of the action
◆ processAction()
bool ModuleBase_ModelWidget::processAction ( ModuleBase_ActionType  theActionType,
const ActionParamPtr &  theParam = ActionParamPtr()
◆ actionsList()
virtual QList< ActionInfo > ModuleBase_ModelWidget::actionsList ( ModuleBase_ActionType  theActionType) const
theActionTypetype of action. It can be ActionUndo or ActionRedo.
◆ updateObject()
void ModuleBase_ModelWidget::updateObject ( ObjectPtr  theObj)
theObjis updating object
◆ translate()
QString ModuleBase_ModelWidget::translate ( const std::string &  theStr) const
◆ emitFocusInWidget()
void ModuleBase_ModelWidget::emitFocusInWidget ( )
◆ findModelWidget()
ModuleBase_ModelWidget * ModuleBase_ModelWidget::findModelWidget ( ModuleBase_IPropertyPanel *  theProp,
QWidget *  theWidget
theWidgeta candidate to be a child of the model widget
thePropa property panel instance
a model widget or NULL
◆ usesAttribute()
virtual bool ModuleBase_ModelWidget::usesAttribute ( ) const
◆ isInformative()
virtual bool ModuleBase_ModelWidget::isInformative ( ) const
◆ showInformativePage()
virtual void ModuleBase_ModelWidget::showInformativePage ( )
By default does nothing
◆ isModified()
virtual bool ModuleBase_ModelWidget::isModified ( ) const
◆ canUseExternalParts()
bool ModuleBase_ModelWidget::canUseExternalParts ( ) const
◆ beforeValuesChanged
void ModuleBase_ModelWidget::beforeValuesChanged ( )
signalinherited
◆ valuesChanged
void ModuleBase_ModelWidget::valuesChanged ( )
signalinherited
◆ valuesModified
void ModuleBase_ModelWidget::valuesModified ( )
signalinherited
◆ afterValuesChanged
void ModuleBase_ModelWidget::afterValuesChanged ( )
signalinherited
◆ beforeValuesRestored
void ModuleBase_ModelWidget::beforeValuesRestored ( )
signalinherited
◆ afterValuesRestored
void ModuleBase_ModelWidget::afterValuesRestored ( )
signalinherited
◆ keyReleased
void ModuleBase_ModelWidget::keyReleased ( QObject *  theObject,
QKeyEvent *  theEvent
signalinherited
theObjecta sender of the event
theEventkey release event
◆ enterClicked
void ModuleBase_ModelWidget::enterClicked ( QObject *  theObject)
signalinherited
◆ focusInWidget
void ModuleBase_ModelWidget::focusInWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
theWidgetthe model base widget
◆ focusOutWidget
void ModuleBase_ModelWidget::focusOutWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
◆ valueStateChanged
void ModuleBase_ModelWidget::valueStateChanged ( int  theState)
signalinherited
◆ objectUpdated
void ModuleBase_ModelWidget::objectUpdated ( )
signalinherited
◆ setDefaultValue()
void ModuleBase_ModelWidget::setDefaultValue ( const std::string &  theValue)
◆ setAttributeID()
void ModuleBase_ModelWidget::setAttributeID ( const std::string &  theAttribute)
inlineprotectedinherited
theAttributethe string value with attribute name
◆ setValueState()
ModuleBase_ModelWidget::ValueState ModuleBase_ModelWidget::setValueState ( const ValueState &  theState)
theStatea new state
the previous value state
◆ blockValueState()
bool ModuleBase_ModelWidget::blockValueState ( const bool  theBlocked)
theBlockeda block state
the previous value
◆ initializeValueByActivate()
void ModuleBase_ModelWidget::initializeValueByActivate ( )
◆ resetCustom()
virtual bool ModuleBase_ModelWidget::resetCustom ( )
◆ processEnter()
◆ processEscape()
bool ModuleBase_ModelWidget::processEscape ( )
◆ processDelete()
bool ModuleBase_ModelWidget::processDelete ( )
◆ processSelection()
bool ModuleBase_ModelWidget::processSelection ( )
◆ onWidgetValuesChanged
void ModuleBase_ModelWidget::onWidgetValuesChanged ( )
protectedslotinherited
◆ onWidgetValuesModified
void ModuleBase_ModelWidget::onWidgetValuesModified ( )
◆ myWidgetValidator
std::unique_ptr<ModuleBase_WidgetValidator> ModuleBase_ModelWidget::myWidgetValidator
◆ myAttributeID
std::string ModuleBase_ModelWidget::myAttributeID
◆ myFeature
FeaturePtr ModuleBase_ModelWidget::myFeature
◆ myFeatureId
std::string ModuleBase_ModelWidget::myFeatureId
A feature ID.
◆ myIsObligatory
bool ModuleBase_ModelWidget::myIsObligatory
◆ myIsValueEnabled
EnableState ModuleBase_ModelWidget::myIsValueEnabled
◆ myState
ValueState ModuleBase_ModelWidget::myState
