PartSet_WidgetSketchCreator Class Reference
A widget which allow creation of a sketch in another operation. More...
#include <PartSet_WidgetSketchCreator.h>
Inheritance diagram for PartSet_WidgetSketchCreator:
enum  ValueState { Stored , ModifiedInPP , ModifiedInViewer , Reset }
 State of the widget. More...
enum  EnableState { On , Off , DefinedInPreferences }
 the value is reset More...
Signals
void beforeValuesChanged ()
 The signal about widget values are to be changed. More...
void valuesChanged ()
 The signal about widget values changed. More...
void valuesModified ()
 The signal about widget values modified. More...
void afterValuesChanged ()
void beforeValuesRestored ()
 The signal about widget values are to be restored. More...
void afterValuesRestored ()
void keyReleased (QObject *theObject, QKeyEvent *theEvent)
 The signal about key release on the control, that corresponds to the attribute. More...
void enterClicked (QObject *theObject)
 The signal is emitted if the enter is clicked in the control of the widget. More...
void focusInWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is get focus. More...
void focusOutWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is lost focus. More...
void valueStateChanged (int theState)
 The signal about value state modification. More...
void objectUpdated ()
 The signal is emitted after flush of updates singal for the widget. More...
 PartSet_WidgetSketchCreator (QWidget *theParent, PartSet_Module *theModule, const Config_WidgetAPI *theData)
virtual QList< QWidget * > getControls () const
 Returns list of widget controls. More...
virtual bool focusTo ()
 Set focus to the first control of the current widget. More...
virtual void deactivate ()
 The methiod called when widget is deactivated. More...
virtual bool setSelection (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues, const bool theToValidate)
 Set the given wrapped value to the current widget This value should be processed in the widget according to the needs. More...
virtual void setEditingMode (bool isEditing)
 Editing mode depends on mode of current operation. This value is defined by it. More...
virtual bool isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
 Checks all widget validator if the owner is valid. More...
virtual bool isInformative () const
 Returns True in case if the widget contains useful information for inspection tool. More...
virtual void selectionModes (int &theModuleSelectionModes, QIntList &theModes)
 Fills given container with selection modes if the widget has it. More...
virtual bool isViewerSelector ()
 Defines if it is supposed that the widget should interact with the viewer. More...
virtual void updateSelectionModesAndFilters (bool toActivate)
 Activate or deactivate selection and selection filters. More...
virtual bool setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Fills the attribute with the value of the selected owner. More...
virtual QList< std::shared_ptr< ModuleBase_ViewerPrs > > getAttributeSelection () const
 Return the attribute values wrapped in a list of viewer presentations. More...
virtual bool isWholeResultAllowed () const
ObjectPtr findPresentedObject (const AISObjectPtr &theAIS) const
 Returns data object by AIS. More...
void clearValidatedCash ()
 Clear all validated cash in the widget. More...
bool isFilterActivated () const
 Returns true if the workshop validator filter has been already activated. More...
virtual void selectionFilters (QIntList &theModuleSelectionFilters, SelectMgr_ListOfFilter &theSelectionFilters)
 Appends into container of workshop selection filters. More...
bool reset ()
 Fills the widget with default values. More...
bool isInitialized (ObjectPtr theObject) const
 Returns the state whether the attribute of the feature is initialized. More...
bool isComputedDefault () const
 Returns true, if default value of the widget should be computed on operation's execute, like radius for circle's constraint (can not be zero) More...
std::string getDefaultValue () const
 Returns true, if default value of the widget is defined in the XML and it is not the computed value. More...
bool isInternal () const
 Returns true, if widget is internal. More...
bool isObligatory () const
 Returns true, if the obligatory value of the widget is not defined in the XML or has true value. More...
virtual bool isValueEnabled () const
 Returns true, if the widget value is enabled and might be modified manually. More...
bool isUseReset () const
 Returns this parameter value in the xml file. More...
std::string isModifiedInEdit () const
ValueState getValueState () const
 Returns this widget value state. More...
void processValueState ()
 Stores the widget value if it is modified. More...
Events_InfoMessage getValueStateError () const
 Returns an attribute error according to the value state It exists in all cases excepring the "Store" case. More...
virtual bool canAcceptFocus () const
 Defines if it is supported to set the value in this widget By default it returns true. More...
virtual QString getError (const bool theValueStateChecked=true) const
 Returns the widget error, get it from the attribute validator and state of the widget If the feature is correct, it returns an empty value. More...
virtual void getHighlighted (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Returns values which should be highlighted when the whidget is active. More...
ModuleBase_WidgetValidator * widgetValidator ()
 Returns widget validator, by default it is NULL. To be created in a child if necessary. More...
bool restoreValue ()
 Restore value from attribute data to the widget's control. More...
bool storeValue ()
 Saves the internal parameters to the given feature. More...
virtual void selectContent ()
 Select the internal content if it can be selected. It is empty in the default realization. More...
void activate ()
 The method called when widget is activated. More...
virtual void updateAfterDeactivation ()
 Opportunity to do something after the active widget of the property panel changed. More...
virtual void updateAfterActivation ()
virtual bool needToBeActivated ()
 The method called if widget should be activated always. More...
QWidget * getControlAcceptingFocus (const bool isFirst)
 Returns the first or the last control that can accept the focus. More...
virtual bool eventFilter (QObject *theObject, QEvent *theEvent)
 FocusIn events processing. More...
virtual void enableFocusProcessing ()
 Enables processing of focus event on all controls by the widget if this widget is not obligatory and set no-focus policy otherwise. More...
virtual void setHighlighted (bool isHighlighted)
 Switch On/Off highlighting of the widget. More...
std::string attributeID () const
 Returns the attribute name. More...
FeaturePtr feature () const
virtual std::string context () const
virtual void setFeature (const FeaturePtr &theFeature, const bool theToStoreValue=false, const bool isUpdateFlushed=true)
 Set feature which is processing by active operation. More...
bool isEditingMode () const
virtual bool canProcessAction (ModuleBase_ActionType theActionType, bool &isActionEnabled)
 Returns true if the action can be processed. More...
virtual bool processAction (ModuleBase_ActionType theActionType, const ActionParamPtr &theParam=ActionParamPtr())
 Returns true if the event is processed. The default implementation is empty, returns false. More...
virtual QList< ActionInfo > actionsList (ModuleBase_ActionType theActionType) const
 Returns list of accessible actions for Undo/Redo commands. More...
void updateObject (ObjectPtr theObj)
 Sends Update and Redisplay for the given object. More...
virtual QString translate (const std::string &theStr) const
 Translate passed string with widget context() More...
void emitFocusInWidget ()
 Emit focus in widget to set this control as active in property panel. More...
virtual bool usesAttribute () const
 Returns True if the widget uses feature attribute. More...
virtual void onFeatureAccepted ()
 It is called when user press Ok or OkPlus buttons in the parent property panel By default this slot does nothing. More...
virtual void showInformativePage ()
 If widgets has several panels then this method has to show a page which contains information for current feature. More...
 Returns True if data of its attribute was modified. More...
virtual void setReadOnly (bool isReadOnly)
virtual bool isReadOnly () const
bool canUseExternalParts () const
 Returns true if the widget should have access to external parts. More...
static void blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked)
 Block the model flush of update and initialization of attribute. More...
static bool isValidAttribute (const AttributePtr &theAttribute)
 Checks the current attribute in all attribute validators. More...
static ModuleBase_ModelWidget * findModelWidget (ModuleBase_IPropertyPanel *theProp, QWidget *theWidget)
 Finds model widget parent of the given sub widget. More...
Protected Slots
void onWidgetValuesChanged ()
 Processing of values changed in model widget by store the current value to the feature. More...
void onWidgetValuesModified ()
 Changes widget state. More...
void openExtrusionTransaction ()
 If there is no operation in current session, start operation for modify parameters. More...
virtual bool isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
 Checks whether the selection presentation contains preview planes. More...
virtual bool storeValueCustom ()
virtual bool restoreValueCustom ()
virtual AttributePtr attribute () const
 Returns attribute, which should be validated. More...
void activateSelectionControl ()
 Sets the selection control visible and set the current widget as active in property panel It leads to connect to onSelectionChanged slot. More...
void setVisibleSelectionControl (const bool theSelectionControl)
 Visualization of the current control or others in PP. More...
virtual QIntList shapeTypes () const
 Returns a list of possible shape types. More...
void updateOnSelectionChanged (const bool theDone)
 Emits model changed info, updates the current control by selection change. More...
virtual bool processSelection ()
 Returns true if envent is processed. More...
virtual void updateFocus ()
 Update focus after the attribute value change. More...
QIntList getShapeTypes () const
virtual void updateSelectionName ()
 Computes and updates name of selected object in the widget. More...
virtual void activateCustom ()
 The methiod called when widget is activated. More...
bool acceptSubShape (const GeomShapePtr &theShape, const std::shared_ptr< ModelAPI_Result > &theResult) const
 Returns true if selected shape corresponds to requested shape types. More...
virtual void getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape)
 Return an object and geom shape by the viewer presentation. More...
virtual bool isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Checks whether all active viewer filters validate the presentation. More...
bool isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute)
 Checks all attribute validators returns valid. More...
virtual void storeAttributeValue (const AttributePtr &theAttribute)
 Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More...
virtual void restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid)
QList< std::shared_ptr< ModuleBase_ViewerPrs > > getFilteredSelected ()
 Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More...
virtual void blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked)
bool getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid)
 Gets the validity state of the presentation in an internal map. More...
void storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid)
 Store the validity state of the presentation in an internal map. More...
void setDefaultValue (const std::string &theValue)
 Sets default value of widget. More...
void setAttributeID (const std::string &theAttribute)
 Set the attribute name. More...
ValueState setValueState (const ValueState &theState)
 Sets the current value state. More...
bool blockValueState (const bool theBlocked)
 Blocks the value state change. More...
virtual void initializeValueByActivate ()
 Compute the feature default value and fill the controls with it or store the control value to the feature. More...
virtual bool resetCustom ()
virtual bool processEnter ()
virtual bool processEscape ()
virtual bool processDelete ()
bool myIsPointsFiltering
ModuleBase_IWorkshop * myWorkshop
 Reference to workshop. More...
bool myIsInValidate
 The widget is in validation mode: store is performed, restore is not. More...
std::unique_ptr< ModuleBase_WidgetValidator > myWidgetValidator
 own validator, by default it is zero More...
std::string myAttributeID
 The attribute name of the model feature. More...
FeaturePtr myFeature
 A feature which is processing by active operation. More...
std::string myFeatureId
 A feature ID. More...
bool myIsObligatory
 Flag which shows whether current widget is obligatory The non-obligatory widgets should not accept the focus in the property panel. More...
EnableState myIsValueEnabled
 Flag about value of the control is enabled (can be modified) More...
ValueState myState
 The widget value state. More...
It creates sketch on aqctivation of this widget. If sketch object is already created then it will transfer a focus to next widget. It is supposed that the widget will be placed as a first widget in property panel
◆ ValueState
ModifiedInPP
modification is finished and applied to the model
ModifiedInViewer
modification has not been finished and set to the model yet
Reset
modification performed by viewer events
◆ EnableState
the value is reset
Off
the widget value is always enabled
the widget value is always disabled
the widget value enable state is defined in preferences
◆ PartSet_WidgetSketchCreator()
PartSet_WidgetSketchCreator::PartSet_WidgetSketchCreator ( QWidget *  theParent,
PartSet_Module *  theModule,
const Config_WidgetAPI *  theData
theParentthe parent object
theModulea reference to a module object
theDatathe widget configuration. The attribute of the model widget is obtained from
◆ getControls()
QList< QWidget * > PartSet_WidgetSketchCreator::getControls ( ) const
a control list
◆ focusTo()
bool PartSet_WidgetSketchCreator::focusTo ( )
the state whether the widget can accept the focus
◆ deactivate()
void PartSet_WidgetSketchCreator::deactivate ( )
Reimplemented from ModuleBase_WidgetSelector.
◆ setSelection()
bool PartSet_WidgetSketchCreator::setSelection ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues,
theValuesthe wrapped selection values
theToValidatea validation of the values flag
◆ setEditingMode()
void PartSet_WidgetSketchCreator::setEditingMode ( bool  isEditing)
◆ isValidSelection()
bool PartSet_WidgetSketchCreator::isValidSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue)
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
theValuea selected presentation in the view
a boolean value
if the validated attribute is already custom
Reimplemented from ModuleBase_WidgetValidated.
◆ isInformative()
virtual bool PartSet_WidgetSketchCreator::isInformative ( ) const
◆ openExtrusionTransaction()
void PartSet_WidgetSketchCreator::openExtrusionTransaction ( )
true if the operation was not opened
◆ isValidSelectionCustom()
bool PartSet_WidgetSketchCreator::isValidSelectionCustom ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue)
theValuea selection information
a boolean value
◆ storeValueCustom()
bool PartSet_WidgetSketchCreator::storeValueCustom ( )
True in success
◆ restoreValueCustom()
bool PartSet_WidgetSketchCreator::restoreValueCustom ( )
◆ attribute()
AttributePtr PartSet_WidgetSketchCreator::attribute ( ) const
In default implementation, this is an attribute of ID
an attribute
◆ activateSelectionControl()
void PartSet_WidgetSketchCreator::activateSelectionControl ( )
◆ setVisibleSelectionControl()
void PartSet_WidgetSketchCreator::setVisibleSelectionControl ( const bool  theSelectionControl)
theSelectionControlstate whether the control should be shown/hidden
◆ shapeTypes()
QIntList PartSet_WidgetSketchCreator::shapeTypes ( ) const
a list of shapes
Implements ModuleBase_WidgetSelector.
◆ updateOnSelectionChanged()
void PartSet_WidgetSketchCreator::updateOnSelectionChanged ( const bool  theDone)
theDonea state whether the selection is set
◆ processSelection()
bool PartSet_WidgetSketchCreator::processSelection ( )
◆ selectionModes()
void ModuleBase_WidgetSelector::selectionModes ( int &  theModuleSelectionModes,
QIntList &  theModes
[out]theModuleSelectionModesmodule additional modes, -1 means all default modes
[out]theModesa container of modes
Reimplemented in ModuleBase_WidgetPointInput.
◆ isViewerSelector()
virtual bool ModuleBase_WidgetSelector::isViewerSelector ( )
inlinevirtualinherited
Reimplemented in ModuleBase_WidgetPointInput, and PartSet_WidgetMultiSelector.
◆ updateSelectionModesAndFilters()
void ModuleBase_WidgetSelector::updateSelectionModesAndFilters ( bool  toActivate)
◆ setSelectionCustom()
bool ModuleBase_WidgetSelector::setSelectionCustom ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
thePrsa selected owner
Implements ModuleBase_WidgetValidated.
Reimplemented in PartSet_WidgetFeaturePointSelector.
◆ getAttributeSelection()
QList< ModuleBase_ViewerPrsPtr > ModuleBase_WidgetSelector::getAttributeSelection ( ) const
a list of viewer presentations, which contains an attribute result and a shape. If the attribute do not uses the shape, it is empty
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetFeaturePointSelector.
◆ updateFocus()
virtual void ModuleBase_WidgetSelector::updateFocus ( )
Reimplemented in ModuleBase_WidgetMultiSelector, and ModuleBase_WidgetShapeSelector.
◆ getShapeTypes()
QIntList ModuleBase_WidgetSelector::getShapeTypes ( ) const
a list of shapes
◆ updateSelectionName()
virtual void ModuleBase_WidgetSelector::updateSelectionName ( )
◆ activateCustom()
void ModuleBase_WidgetSelector::activateCustom ( )
Reimplemented in ModuleBase_WidgetMultiSelector, and PartSet_WidgetFeaturePointSelector.
◆ acceptSubShape()
bool ModuleBase_WidgetSelector::acceptSubShape ( const GeomShapePtr &  theShape,
const std::shared_ptr< ModelAPI_Result > &  theResult
If the widget type of shapes contains the faces item, the result is converted to construction result and the method returns true if there is at least one face in the construction.
theShapea shape
theResulta selected result
◆ getGeomSelection()
void ModuleBase_WidgetSelector::getGeomSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs,
ObjectPtr &  theObject,
thePrsa selection
theObjectan output object
theShapea shape of the selection
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, and PartSet_WidgetShapeSelector.
◆ findPresentedObject()
ObjectPtr ModuleBase_WidgetValidated::findPresentedObject ( const AISObjectPtr &  theAIS) const
◆ clearValidatedCash()
void ModuleBase_WidgetValidated::clearValidatedCash ( )
◆ isFilterActivated()
bool ModuleBase_WidgetValidated::isFilterActivated ( ) const
boolean value
◆ selectionFilters()
void ModuleBase_WidgetValidated::selectionFilters ( QIntList &  theModuleSelectionFilters,
SelectMgr_ListOfFilter &  theSelectionFilters
[out]theModuleSelectionFiltersmodule additional modes, -1 means all default modes
[out]selectionfilters
Reimplemented in PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
◆ blockFeatureAttribute()
void ModuleBase_WidgetValidated::blockFeatureAttribute ( const AttributePtr &  theAttribute,
const FeaturePtr &  theFeature,
const bool &  theToBlock,
bool &  isFlushesActived,
bool &  isAttributeSetInitializedBlocked,
bool &  isAttributeSendUpdatedBlocked
theAttributean attribute of blocking
theFeaturea feature
theToBlockflag whether the model is blocked or unblocked
isFlushesActivedout value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked
isAttributeSetInitializedBlockedout value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked
isAttributeSendUpdatedBlockedout value if model signal is blocked
◆ isValidAttribute()
bool ModuleBase_WidgetValidated::isValidAttribute ( const AttributePtr &  theAttribute)
theAttributean attribute to be validated
true if all validators return that the attribute is valid
◆ isValidInFilters()
bool ModuleBase_WidgetValidated::isValidInFilters ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
thePrsa selected presentation in the view
a boolean value
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
◆ isValidSelectionForAttribute()
bool ModuleBase_WidgetValidated::isValidSelectionForAttribute ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
theAttributethe attribute
a boolean value
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
◆ storeAttributeValue()
void ModuleBase_WidgetValidated::storeAttributeValue ( const AttributePtr &  theAttribute)
theAttributean attribute to be stored
◆ restoreAttributeValue()
void ModuleBase_WidgetValidated::restoreAttributeValue ( const AttributePtr &  theAttribute,
const bool  theValid
theAttributean attribute to be restored
theValida boolean flag, if restore happens for valid parameters
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
◆ getFilteredSelected()
QList< ModuleBase_ViewerPrsPtr > ModuleBase_WidgetValidated::getFilteredSelected ( )
a list of presentations
◆ blockAttribute()
void ModuleBase_WidgetValidated::blockAttribute ( const AttributePtr &  theAttribute,
◆ getValidState()
bool ModuleBase_WidgetValidated::getValidState ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
bool &  theValid
Returns true if the valid state of value is stored
theValuea viewer presentation
theValida valid state
◆ storeValidState()
void ModuleBase_WidgetValidated::storeValidState ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
const bool  theValid
◆ reset()
bool ModuleBase_ModelWidget::reset ( )
true if the widget current value is reset
◆ isInitialized()
bool ModuleBase_ModelWidget::isInitialized ( ObjectPtr  theObject) const
theObjecta model feature to be checked
the boolean result
◆ isComputedDefault()
bool ModuleBase_ModelWidget::isComputedDefault ( ) const
◆ getDefaultValue()
std::string ModuleBase_ModelWidget::getDefaultValue ( ) const
the boolean result
◆ isInternal()
bool ModuleBase_ModelWidget::isInternal ( ) const
the boolean result
◆ isObligatory()
bool ModuleBase_ModelWidget::isObligatory ( ) const
the boolean result
◆ isValueEnabled()
bool ModuleBase_ModelWidget::isValueEnabled ( ) const
the boolean result
◆ isUseReset()
bool ModuleBase_ModelWidget::isUseReset ( ) const
the boolean result
◆ isModifiedInEdit()
std::string ModuleBase_ModelWidget::isModifiedInEdit ( ) const
the boolean result
◆ getValueState()
ValueState ModuleBase_ModelWidget::getValueState ( ) const
the enumeration result
◆ processValueState()
void ModuleBase_ModelWidget::processValueState ( )
◆ getValueStateError()
Events_InfoMessage ModuleBase_ModelWidget::getValueStateError ( ) const
◆ canAcceptFocus()
virtual bool ModuleBase_ModelWidget::canAcceptFocus ( ) const
◆ getError()
QString ModuleBase_ModelWidget::getError ( const bool  theValueStateChecked = true) const
theValueStateCheckedthe boolean flag if the state of the widget should be checked
string value
◆ getHighlighted()
virtual void ModuleBase_ModelWidget::getHighlighted ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
◆ widgetValidator()
ModuleBase_WidgetValidator * ModuleBase_ModelWidget::widgetValidator ( )
◆ restoreValue()
bool ModuleBase_ModelWidget::restoreValue ( )
True in success
◆ storeValue()
bool ModuleBase_ModelWidget::storeValue ( )
True in success
◆ selectContent()
virtual void ModuleBase_ModelWidget::selectContent ( )
◆ activate()
void ModuleBase_ModelWidget::activate ( )
◆ updateAfterDeactivation()
virtual void ModuleBase_ModelWidget::updateAfterDeactivation ( )
◆ updateAfterActivation()
virtual void ModuleBase_ModelWidget::updateAfterActivation ( )
◆ needToBeActivated()
virtual bool ModuleBase_ModelWidget::needToBeActivated ( )
◆ getControlAcceptingFocus()
QWidget * ModuleBase_ModelWidget::getControlAcceptingFocus ( const bool  isFirst)
isFirstif true, the first controls is returned or the last one
a control from a list of controls
◆ eventFilter()
bool ModuleBase_ModelWidget::eventFilter ( QObject *  theObject,
QEvent *  theEvent
◆ enableFocusProcessing()
void ModuleBase_ModelWidget::enableFocusProcessing ( )
◆ setHighlighted()
void ModuleBase_ModelWidget::setHighlighted ( bool  isHighlighted)
◆ attributeID()
std::string ModuleBase_ModelWidget::attributeID ( ) const
the string value
◆ feature()
FeaturePtr ModuleBase_ModelWidget::feature ( ) const
Current feature
◆ context()
virtual std::string ModuleBase_ModelWidget::context ( ) const
Context for translation
◆ setFeature()
void ModuleBase_ModelWidget::setFeature ( const FeaturePtr &  theFeature,
const bool  theToStoreValue = false,
const bool  isUpdateFlushed = true
theFeaturea feature object
theToStoreValuea value about necessity to store the widget value to the feature
isUpdateFlusheda flag if update should be flushed on store value
◆ isEditingMode()
bool ModuleBase_ModelWidget::isEditingMode ( ) const
Current Editing mode
◆ canProcessAction()
bool ModuleBase_ModelWidget::canProcessAction ( ModuleBase_ActionType  theActionType,
bool &  isActionEnabled
theActionTypean action type
isActionEnabledif true, the enable state of the action
◆ processAction()
bool ModuleBase_ModelWidget::processAction ( ModuleBase_ActionType  theActionType,
const ActionParamPtr &  theParam = ActionParamPtr()
◆ actionsList()
virtual QList< ActionInfo > ModuleBase_ModelWidget::actionsList ( ModuleBase_ActionType  theActionType) const
theActionTypetype of action. It can be ActionUndo or ActionRedo.
◆ updateObject()
void ModuleBase_ModelWidget::updateObject ( ObjectPtr  theObj)
theObjis updating object
◆ translate()
QString ModuleBase_ModelWidget::translate ( const std::string &  theStr) const
◆ emitFocusInWidget()
void ModuleBase_ModelWidget::emitFocusInWidget ( )
◆ findModelWidget()
ModuleBase_ModelWidget * ModuleBase_ModelWidget::findModelWidget ( ModuleBase_IPropertyPanel *  theProp,
QWidget *  theWidget
theWidgeta candidate to be a child of the model widget
thePropa property panel instance
a model widget or NULL
◆ usesAttribute()
virtual bool ModuleBase_ModelWidget::usesAttribute ( ) const
◆ onFeatureAccepted()
virtual void ModuleBase_ModelWidget::onFeatureAccepted ( )
◆ showInformativePage()
virtual void ModuleBase_ModelWidget::showInformativePage ( )
By default does nothing
◆ isModified()
virtual bool ModuleBase_ModelWidget::isModified ( ) const
◆ canUseExternalParts()
bool ModuleBase_ModelWidget::canUseExternalParts ( ) const
◆ beforeValuesChanged
void ModuleBase_ModelWidget::beforeValuesChanged ( )
signalinherited
◆ valuesChanged
void ModuleBase_ModelWidget::valuesChanged ( )
signalinherited
◆ valuesModified
void ModuleBase_ModelWidget::valuesModified ( )
signalinherited
◆ afterValuesChanged
void ModuleBase_ModelWidget::afterValuesChanged ( )
signalinherited
◆ beforeValuesRestored
void ModuleBase_ModelWidget::beforeValuesRestored ( )
signalinherited
◆ afterValuesRestored
void ModuleBase_ModelWidget::afterValuesRestored ( )
signalinherited
◆ keyReleased
void ModuleBase_ModelWidget::keyReleased ( QObject *  theObject,
QKeyEvent *  theEvent
signalinherited
theObjecta sender of the event
theEventkey release event
◆ enterClicked
void ModuleBase_ModelWidget::enterClicked ( QObject *  theObject)
signalinherited
◆ focusInWidget
void ModuleBase_ModelWidget::focusInWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
theWidgetthe model base widget
◆ focusOutWidget
void ModuleBase_ModelWidget::focusOutWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
◆ valueStateChanged
void ModuleBase_ModelWidget::valueStateChanged ( int  theState)
signalinherited
◆ objectUpdated
void ModuleBase_ModelWidget::objectUpdated ( )
signalinherited
◆ setDefaultValue()
void ModuleBase_ModelWidget::setDefaultValue ( const std::string &  theValue)
◆ setAttributeID()
void ModuleBase_ModelWidget::setAttributeID ( const std::string &  theAttribute)
inlineprotectedinherited
theAttributethe string value with attribute name
◆ setValueState()
ModuleBase_ModelWidget::ValueState ModuleBase_ModelWidget::setValueState ( const ValueState &  theState)
theStatea new state
the previous value state
◆ blockValueState()
bool ModuleBase_ModelWidget::blockValueState ( const bool  theBlocked)
theBlockeda block state
the previous value
◆ initializeValueByActivate()
void ModuleBase_ModelWidget::initializeValueByActivate ( )
◆ resetCustom()
virtual bool ModuleBase_ModelWidget::resetCustom ( )
◆ processEnter()
◆ processEscape()
bool ModuleBase_ModelWidget::processEscape ( )
◆ processDelete()
bool ModuleBase_ModelWidget::processDelete ( )
◆ onWidgetValuesChanged
void ModuleBase_ModelWidget::onWidgetValuesChanged ( )
protectedslotinherited
◆ onWidgetValuesModified
void ModuleBase_ModelWidget::onWidgetValuesModified ( )
◆ myWorkshop
ModuleBase_IWorkshop* ModuleBase_WidgetValidated::myWorkshop
◆ myIsInValidate
bool ModuleBase_WidgetValidated::myIsInValidate
◆ myWidgetValidator
std::unique_ptr<ModuleBase_WidgetValidator> ModuleBase_ModelWidget::myWidgetValidator
◆ myAttributeID
std::string ModuleBase_ModelWidget::myAttributeID
◆ myFeature
FeaturePtr ModuleBase_ModelWidget::myFeature
◆ myFeatureId
std::string ModuleBase_ModelWidget::myFeatureId
A feature ID.
◆ myIsObligatory
bool ModuleBase_ModelWidget::myIsObligatory
◆ myIsValueEnabled
EnableState ModuleBase_ModelWidget::myIsValueEnabled
◆ myState
ValueState ModuleBase_ModelWidget::myState
