Implements a model widget for switch as a container widget. More...
#include <ModuleBase_WidgetToolbox.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetToolbox (QWidget *theParent, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| Defines if it is supported to set the value in this widget. More... | |
| virtual int | addPage (ModuleBase_PageBase *theWidget, const QString &theName, const QString &theCaseId, const QPixmap &theIcon, const QString &theTooltip) |
| Add a page to the widget. More... | |
| Redefinition of virtual function. More... | |
| virtual bool | focusTo () |
| The slot is called when user press Ok or OkPlus buttons in the parent property panel. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| void | activate () |
| Returns True if data of its attribute was modified. More... | |
Protected Slots | |
| void | onPageChanged () |
| A slot called on page change. More... | |
| virtual int | currentPageIndex () const |
| Implements ModuleBase_PagedContainer. More... | |
| virtual void | setCurrentPageIndex (int) |
Protected Attributes | |
| bool | myRemeberChoice |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
It can be defined in XML with "toolbox" keyword
| ModuleBase_WidgetToolbox::ModuleBase_WidgetToolbox | ( | QWidget * | theParent, |
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theData | the widget configuration. The attribute of the model widget is obtained from |
inlinevirtual |
| theWidget | a page widget |
| theName | a name of page |
| theCaseId | an Id of the page |
| theIcon | an icon of the page |
Reimplemented from ModuleBase_PagedContainer.
protectedvirtual |
protectedvirtual |
protectedvirtualinherited |
protectedslotinherited |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
A feature ID.
