Implementation of model widget to provide widget to input point 2d In XML can be defined as folloung: More...
#include <PartSet_WidgetPoint2d.h>
Public Types | |
Signals | |
| void | vertexSelected () |
| Signal about selection of an existing vertex from an object. More... | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| PartSet_WidgetPoint2D (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual | ~PartSet_WidgetPoint2D () |
| Destructor. More... | |
| Checks if the selection presentation is valid in widget. More... | |
| bool | isValidSelectionForAttribute_ (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const std::shared_ptr< ModelAPI_Attribute > &theAttribute) |
| Checks all attribute validators returns valid. More... | |
| bool | setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue) |
| Fills the attribute with the value of the selected owner. More... | |
| The methiod called when widget is deactivated. More... | |
| CompositeFeaturePtr | sketch () const |
| void | setSketch (CompositeFeaturePtr theSketch) |
| Set sketch instance. More... | |
| bool | setPoint (double theX, double theY) |
| Fill the widget values by given point. More... | |
| double | x () const |
| Returns coordinate X currently defined in the control. More... | |
| double | y () const |
| Returns coordinate Y currently defined in the control. More... | |
| Returns true if the event is processed. More... | |
| virtual bool | useSelectedShapes () const |
| Returns true if the attribute can be changed using the selected shapes in the viewer and creating a coincidence constraint to them. More... | |
| virtual void | mouseMoved (ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent) |
| Processing the mouse move event in the viewer. More... | |
| virtual void | mouseReleased (ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent) |
| Processing the mouse release event in the viewer. More... | |
| virtual void | setPreSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePreSelected, ModuleBase_IViewWindow *theWnd, QMouseEvent *theEvent) |
| Fill preselection used in mouseReleased. More... | |
| void | getGeomSelection_ (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, std::shared_ptr< ModelAPI_Object > &theObject, std::shared_ptr< GeomAPI_Shape > &theShape) |
| Return an object and geom shape by the viewer presentation. More... | |
| PartSet_ExternalObjectsMgr * | getExternalObjectMgr () const |
| Return reference to external objects manager. More... | |
| bool | reset () |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| Returns True if data of its attribute was modified. More... | |
| virtual void | mousePressed (ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent) |
| Processing the mouse press event in the viewer. More... | |
| virtual void | mouseDoubleClick (ModuleBase_IViewWindow *theWindow, QMouseEvent *theEvent) |
| Processing the mouse double click event in the viewer. More... | |
| static bool | isOrphanPoint (const FeaturePtr &theFeature, const CompositeFeaturePtr &theSketch, double theX, double theY) |
| Returns if the feature is an orphan point, circle or an arc. More... | |
| static bool | shapeExploreHasVertex (const std::shared_ptr< GeomAPI_Shape > &theShape, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint, const CompositeFeaturePtr &theSketch) |
| Explode the given shape by vertices and found closed to the point vertes. More... | |
| static std::shared_ptr< GeomDataAPI_Point2D > | findFirstEqualPointInArgumentFeatures (const FeaturePtr &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) |
| Finds in the feature's sub-features first Point2D attribute with the given point coordinates. More... | |
| static std::shared_ptr< GeomDataAPI_Point2D > | findFirstEqualPoint (const FeaturePtr &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) |
| Finds in the feature first Point2D attribute with the given point coordinates. More... | |
| static std::shared_ptr< GeomDataAPI_Point2D > | findFirstEqualPointInSketch (const CompositeFeaturePtr &theSketch, const FeaturePtr &theSkipFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) |
| Finds in the sketch attribute point of any feature that is nearest to the given point. More... | |
| static bool | convertPointToLocal (ModuleBase_IWorkshop *theWorkshop, const std::shared_ptr< ModelAPI_CompositeFeature > &theSketch, ModuleBase_IViewWindow *theWindow, const QPoint &theEventPos, double &theX, double &theY, bool theSnap=true, bool theHighlight=false, bool theAddOffset=false) |
| Converts position of mouse cursor to local coordinates on sketch plane. More... | |
Protected Slots | |
| void | storeCurentValue () |
| Store current value in cashed value. More... | |
| bool | restoreCurentValue () |
| Restore cashed value in the model attribute. More... | |
| The methiod called when widget is activated. More... | |
| bool | isFeatureContainsPoint (const FeaturePtr &theFeature, double theX, double theY) |
| Returns true if the feature contains Point2D attribute with the same coordinates The attribute of the widget is not processed. More... | |
| Process value changed event. More... | |
Protected Attributes | |
| ModuleBase_IWorkshop * | myWorkshop |
| workshop More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
| PartSet_WidgetPoint2D::PartSet_WidgetPoint2D | ( | QWidget * | theParent, |
| ModuleBase_IWorkshop * | theWorkshop, | ||
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theWorkshop | a current workshop |
| theData | the widget configuration. The attribute of the model widget is obtained from |
| theModes | [out] a container of modes |
when internal edit is started a new feature is created. I has not results, AIS
the selection is not possible if the current feature has no presentation for the current attribute not in AIS not in results. If so, no object in current feature where make coincidence, so selection is not necessary
Avoid coincidence build to passed point. Coincidence is build later only if there are no reference attribute. The condition is that the selected feature has shape that has after explore a point equal to clicked one.
analysis of results
Reimplemented in PartSet_WidgetPoint2DFlyout.
| bool PartSet_WidgetPoint2D::isValidSelectionForAttribute_ | ( | const std::shared_ptr< ModuleBase_ViewerPrs > & | theValue, |
| const std::shared_ptr< ModelAPI_Attribute > & | theAttribute | ||
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
| theAttribute | the attribute |
| bool PartSet_WidgetPoint2D::setSelectionCustom | ( | const std::shared_ptr< ModuleBase_ViewerPrs > & | theValue | ) |
| thePrs | a selected owner |
| theValues | the wrapped widget values |
| theToValidate | a validation flag |
Returns list of widget controls
inline |
inline |
| bool PartSet_WidgetPoint2D::setPoint | ( | double | theX, |
| double | theY | ||
| theX | the X coordinate |
| theY | the Y coordinate |
| double PartSet_WidgetPoint2D::x | ( | ) | const |
| double PartSet_WidgetPoint2D::y | ( | ) | const |
This control use them.
| theWindow | a view window |
| theEvent | a mouse event |
Reimplemented from PartSet_MouseProcessor.
| void PartSet_WidgetPoint2D::getGeomSelection_ | ( | const std::shared_ptr< ModuleBase_ViewerPrs > & | theValue, |
| std::shared_ptr< ModelAPI_Object > & | theObject, | ||
| std::shared_ptr< GeomAPI_Shape > & | theShape | ||
| thePrs | a selection |
| theObject | an output object |
| theShape | a shape of the selection |
inline |
signal |
protectedvirtual |
protectedvirtual |
protected |
protected |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protected |
| theFeature | a feature |
protectedvirtual |
Compute the feature default value and fill the controls with it or store the control value to the feature The widget is not initialize the attribute value in order to avoid the incorrect visualization in Sketch. E.g. by a line creation, the line should not be visualized immediately when the end point widget is activated.
static |
Returns true if it has no a coincident to other lines. It processes point, circle and arc features In circle an arc features, only centers are processed, for other points, it returns that the point is not an orphan.
| theFeature | a checked feature |
| theSketch | a sketch |
| theX | an X coordinate of the point |
| theY | an Y coordinate of the point |
check that the geometry point with the given coordinates is the checked point e.g. in arc the (x,y) point can not coicide to the center point and it automatically means that this point is not an orphant one.
static |
| theShape | a shape to be exploded |
| thePoint | a point |
static |
| theFeature | a feature with sub-feature attributes |
| thePoint | a point to provided searched coordinates |
static |
| theFeature | a feature with point attributes |
static |
| theSketch | a sketch, that is a container of features |
| theSkipFeature | a feature that do not participate in the search |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
protectedslotinherited |
staticinherited |
Snaps on-sketch-plane-coordinates to closest construction grid node.
| theEventPos | is position of mouse cursor. |
| theX | and |
| theY | are local coordinates on sketch plane. |
| theSnap | theX and theY are snapped to construction grid if both theSnap == true and snapping is enabled. |
| theHighlight | If point is snapped, highlight grid point. |
| theAddOffset | If true, serves as a remedy for odd crash during drawing of a line on a sketch. |
protected |
workshop
A feature ID.
