Implementation of widget with validators and filters processing. More...
#include <ModuleBase_WidgetValidated.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetValidated (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual bool | isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue) |
| Checks all widget validator if the owner is valid. More... | |
| ObjectPtr | findPresentedObject (const AISObjectPtr &theAIS) const |
| Returns data object by AIS. More... | |
| void | clearValidatedCash () |
| Clear all validated cash in the widget. More... | |
| bool | isFilterActivated () const |
| Returns true if the workshop validator filter has been already activated. More... | |
| bool | reset () |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| virtual QList< QWidget * > | getControls () const =0 |
| Returns True if data of its attribute was modified. More... | |
| static void | blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| Block the model flush of update and initialization of attribute. More... | |
| static bool | isValidAttribute (const AttributePtr &theAttribute) |
| Checks the current attribute in all attribute validators. More... | |
Protected Slots | |
| virtual bool | isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks whether all active viewer filters validate the presentation. More... | |
| bool | isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute) |
| Checks all attribute validators returns valid. More... | |
| virtual AttributePtr | attribute () const |
| Returns attribute, which should be validated. More... | |
| virtual void | storeAttributeValue (const AttributePtr &theAttribute) |
| Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More... | |
| virtual void | restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid) |
| virtual bool | isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks the widget validity. More... | |
| virtual bool | setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)=0 |
| Fills the attribute with the value of the selected owner. More... | |
| QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getFilteredSelected () |
| Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More... | |
| virtual void | blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| bool | getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid) |
| Gets the validity state of the presentation in an internal map. More... | |
| void | storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid) |
| Store the validity state of the presentation in an internal map. More... | |
| virtual bool | storeValueCustom ()=0 |
| virtual bool | restoreValueCustom ()=0 |
Protected Attributes | |
| ModuleBase_IWorkshop * | myWorkshop |
| Reference to workshop. More... | |
| bool | myIsInValidate |
| The widget is in validation mode: store is performed, restore is not. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
| ModuleBase_WidgetValidated::ModuleBase_WidgetValidated | ( | QWidget * | theParent, |
| ModuleBase_IWorkshop * | theWorkshop, | ||
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theWorkshop | a reference to workshop |
| theData | the widget configuration. The attribute of the model widget is obtained from |
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
Reimplemented in PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
| ObjectPtr ModuleBase_WidgetValidated::findPresentedObject | ( | const AISObjectPtr & | theAIS | ) | const |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, PartSet_WidgetFeaturePointSelector, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
| void ModuleBase_WidgetValidated::clearValidatedCash | ( | ) |
| bool ModuleBase_WidgetValidated::isFilterActivated | ( | ) | const |
| [out] | selection | filters |
Reimplemented in PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
static |
| theAttribute | an attribute of blocking |
| theFeature | a feature |
| theToBlock | flag whether the model is blocked or unblocked |
| isFlushesActived | out value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked |
| isAttributeSetInitializedBlocked | out value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked |
| isAttributeSendUpdatedBlocked | out value if model signal is blocked |
static |
| theAttribute | an attribute to be validated |
protectedvirtual |
| thePrs | a selected presentation in the view |
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
protected |
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
| theAttribute | the attribute |
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
protectedvirtual |
In default implementation, this is an attribute of ID
protectedvirtual |
| theAttribute | an attribute to be stored |
protectedvirtual |
| theAttribute | an attribute to be restored |
| theValid | a boolean flag, if restore happens for valid parameters |
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
protectedvirtual |
By default, it returns true.
Reimplemented in ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, CollectionPlugin_WidgetField, and PartSet_WidgetSketchCreator.
protectedpure virtual |
| thePrs | a selected owner |
Implemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetSketchLabel, ModuleBase_WidgetFeatureSelector, and ModuleBase_WidgetSelector.
protected |
protectedvirtual |
protected |
Returns true if the valid state of value is stored
| theValue | a viewer presentation |
| theValid | a valid state |
protected |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
pure virtualinherited |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
protectedpure virtualinherited |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ModuleBase_WidgetUndoLabel, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
Reimplemented in ModuleBase_PagedContainer, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ParametersPlugin_WidgetParamsMgr, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, and PartSet_WidgetSketchLabel.
protectedslotinherited |
protected |
protected |
A feature ID.
