#include <ParametersPlugin_WidgetParamsMgr.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ParametersPlugin_WidgetParamsMgr (QWidget *theParent, const Config_WidgetAPI *theData, ModuleBase_IWorkshop *theWorkshop) | |
| Constructs a model widget. More... | |
| virtual | ~ParametersPlugin_WidgetParamsMgr () |
| Destructs the model widget. More... | |
| virtual void | setDialogButtons (QDialogButtonBox *theButtons) |
| Set general buttons from dialog. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| Returns True if data of its attribute was modified. More... | |
Protected Slots | |
| virtual void | showEvent (QShowEvent *theEvent) |
| virtual void | hideEvent (QHideEvent *theEvent) |
Protected Attributes | |
| QDialogButtonBox * | myOkCancelBtn |
| Contains dialog buttons to enable/disable Ok and Cancel buttons. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
Represent a content of the property panel to show/modify parameters of some feature.
| ParametersPlugin_WidgetParamsMgr::ParametersPlugin_WidgetParamsMgr | ( | QWidget * | theParent, |
| const Config_WidgetAPI * | theData, | ||
| ModuleBase_IWorkshop * | theWorkshop | ||
inlinevirtual |
| theButtons | the dialog buttons |
Reimplemented from ModuleBase_ModelDialogWidget.
protectedvirtual |
protectedvirtual |
protectedvirtual |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
protectedslotinherited |
A feature ID.
