Implementation of widget for feature action (tool button) More...
#include <ModuleBase_WidgetAction.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetAction (QWidget *theParent, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual bool | focusTo () |
| Do not accept focus, returns false. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| void | activate () |
| Returns True if data of its attribute was modified. More... | |
Protected Slots | |
| void | onActionClicked () |
| Listens the button click and call the customAction function of the current feature. More... | |
| Do nothing. More... | |
Protected Attributes | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
| ModuleBase_WidgetAction::ModuleBase_WidgetAction | ( | QWidget * | theParent, |
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theData | the widget configuration. The attribute of the model widget is obtained from |
inlinevirtual |
protectedvirtual |
protectedvirtual |
Do nothing.
protectedslot |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
Reimplemented in ModuleBase_PagedContainer, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ParametersPlugin_WidgetParamsMgr, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, and PartSet_WidgetSketchLabel.
protectedslotinherited |
A feature ID.
