A class of property panel widget for double value input It can be defined with "doublevalue" keyword. More...
#include <ModuleBase_WidgetDoubleValue.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetDoubleValue (QWidget *theParent, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| The methiod called when widget is activated. More... | |
| Returns True if data of its feature was modified during operation. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
Protected Slots | |
| Returns true if the event is processed. More... | |
| Read value of corresponded attribute from data model to the input control. More... | |
Protected Attributes | |
| QLabel * | myLabel |
| Label of the widget. More... | |
| ModuleBase_ParamSpinBox * | mySpinBox |
| Input value control. More... | |
| FeaturePtr | myParameter |
| double | myDefaultVal |
| bool | myHasDefault |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
For example:
| ModuleBase_WidgetDoubleValue::ModuleBase_WidgetDoubleValue | ( | QWidget * | theParent, |
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theData | the widget configuration. The attribute of the model widget is obtained from |
protectedvirtual |
Reimplemented in ModuleBase_WidgetEditor.
protectedvirtual |
protectedvirtual |
protectedvirtual |
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
protectedslotinherited |
protected |
protected |
A feature ID.
