ModuleBase_ParamSpinBox Class Reference
An extension of a double spin box which let to use parameters and expressions for value definition. More...
#include <ModuleBase_ParamSpinBox.h>
Inheritance diagram for ModuleBase_ParamSpinBox:
Signals
void textChanged (const QString &)
 ModuleBase_ParamSpinBox (QWidget *theParent=0, int thePrecision=12)
void setCompletionList (QStringList &)
 Set list of completion strings. More...
virtual ~ModuleBase_ParamSpinBox ()
virtual void stepBy (int)
 Perform steps increment/decrement steps. More...
virtual QValidator::State validate (QString &, int &) const
 This function is used to determine whether input is valid. More...
virtual void setValue (double)
 This function is used to set a current value for this spinbox. More...
double value () const
virtual void setText (const QString &)
 This function is used to set a text for this spinbox. More...
QString text () const
void setAcceptVariables (const bool)
 Set a flag about accepted variable. More...
bool isAcceptVariables () const
 Returns accepted variables flag. More...
bool hasVariable () const
 Returns True if the input value contains variable. More...
double minimum () const
double maximum () const
void setMinimum (double theMin)
void setMaximum (double theMax)
int decimals () const
void setDecimals (int thePrecision)
double singleStep () const
void setSingleStep (double theStep)
void setValueEnabled (bool theEnable)
virtual void keyReleaseEvent (QKeyEvent *event)
 This function is called when the spinbox receives key release event. More...
virtual bool eventFilter (QObject *theObj, QEvent *theEvent)
virtual void timerEvent (QTimerEvent *)
 The virtual function is reimplemented in order to avoid extra increasing of value by StepBy method. More...
virtual StepEnabled stepEnabled () const
bool hasVariable (const QString &theText) const
 Returns True if the given text contains variable. More...
◆ ModuleBase_ParamSpinBox()
ModuleBase_ParamSpinBox::ModuleBase_ParamSpinBox ( QWidget *  theParent = 0,
int  thePrecision = 12
Constructs a spin box with 0.0 as minimum value and 99.99 as maximum value, a step value of 1.0 and a precision of 2 decimal places. The value is initially set to 0.00.
theParenta parent object
thePrecisiona precision of values display
◆ ~ModuleBase_ParamSpinBox()
ModuleBase_ParamSpinBox::~ModuleBase_ParamSpinBox ( )
◆ setCompletionList()
void ModuleBase_ParamSpinBox::setCompletionList ( QStringList &  theList)
◆ stepBy()
void ModuleBase_ParamSpinBox::stepBy ( int  steps)
Re-implemented to handle cases when Notebook variable name is specified by the user as the widget text. Otherwise, simply calls the base implementation.
stepsnumber of increment/decrement steps
◆ validate()
QValidator::State ModuleBase_ParamSpinBox::validate ( QString &  str,
int &  pos
strcurrently entered value
poscursor position in the string
validating operation result
If decimals = 0 do not accept '.' (interpret as int)
◆ setValue()
void ModuleBase_ParamSpinBox::setValue ( double  value)
valuecurrent value
The new value is ignored if the spinbox has a variable.
◆ setText()
void ModuleBase_ParamSpinBox::setText ( const QString &  value)
valuecurrent value
◆ setAcceptVariables()
void ModuleBase_ParamSpinBox::setAcceptVariables ( const bool  flag)
Enables or disables variable names in the spin box. By default, variable names are enabled.
flagIf true, variable names are enabled.
◆ isAcceptVariables()
bool ModuleBase_ParamSpinBox::isAcceptVariables ( ) const
Returns true if the spin box accepts variable names.
◆ hasVariable() [1/2]
bool ModuleBase_ParamSpinBox::hasVariable ( ) const
◆ keyReleaseEvent()
void ModuleBase_ParamSpinBox::keyReleaseEvent ( QKeyEvent *  event)
◆ timerEvent()
virtual void ModuleBase_ParamSpinBox::timerEvent ( QTimerEvent *  )
inlineprotectedvirtual
◆ hasVariable() [2/2]
bool ModuleBase_ParamSpinBox::hasVariable ( const QString &  theText) const
theTexta text string
