Customosation of ModuleBase_WidgetShapeSelector in order to provide working with sketch specific objects and external objects. More...
#include <PartSet_WidgetShapeSelector.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| PartSet_WidgetShapeSelector (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| void | setSketcher (CompositeFeaturePtr theSketch) |
| Set sketcher. More... | |
| CompositeFeaturePtr | sketch () const |
| Retrurns installed sketcher. More... | |
| Set the given wrapped value to the current widget This value should be processed in the widget according to the needs The method is called by the current operation to process the operation preselection. More... | |
| Returns True if data of its feature was modified during operation. More... | |
| virtual void | updateSelectionModesAndFilters (bool toActivate) |
| Activate or deactivate selection and selection filters. More... | |
| virtual bool | setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Fills the attribute with the value of the selected owner. More... | |
| The methiod called when widget is deactivated. More... | |
| virtual bool | isWholeResultAllowed () const |
| virtual bool | isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue) |
| Checks all widget validator if the owner is valid. More... | |
| ObjectPtr | findPresentedObject (const AISObjectPtr &theAIS) const |
| Returns data object by AIS. More... | |
| void | clearValidatedCash () |
| Clear all validated cash in the widget. More... | |
| bool | isFilterActivated () const |
| Returns true if the workshop validator filter has been already activated. More... | |
| bool | reset () |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| static void | blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| Block the model flush of update and initialization of attribute. More... | |
| static bool | isValidAttribute (const AttributePtr &theAttribute) |
| Checks the current attribute in all attribute validators. More... | |
Protected Slots | |
| virtual bool | isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks the widget validity. More... | |
| virtual void | getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape) |
| Return an object and geom shape by the viewer presentation. More... | |
| void | restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid) |
| Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More... | |
| virtual void | updateSelectionName () |
| Computes and updates name of selected object in the widget. More... | |
| virtual void | updateFocus () |
| Update focus after the attribute value change. More... | |
| virtual QIntList | shapeTypes () const |
| Returns a list of possible shape types. More... | |
| virtual GeomShapePtr | getShape () const |
| Get the shape from the attribute if the attribute contains a shape, e.g. More... | |
| virtual QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getAttributeSelection () const |
| Return the attribute values wrapped in a list of viewer presentations. More... | |
| Returns true if envent is processed. The default implementation is empty, returns false. More... | |
| virtual void | updateOnSelectionChanged (const bool theDone) |
| Emits model changed info, updates the current control by selection change. More... | |
| QIntList | getShapeTypes () const |
| The methiod called when widget is activated. More... | |
| bool | acceptSubShape (const GeomShapePtr &theShape, const std::shared_ptr< ModelAPI_Result > &theResult) const |
| Returns true if selected shape corresponds to requested shape types. More... | |
| virtual bool | isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks whether all active viewer filters validate the presentation. More... | |
| bool | isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute) |
| Checks all attribute validators returns valid. More... | |
| virtual AttributePtr | attribute () const |
| Returns attribute, which should be validated. More... | |
| virtual void | storeAttributeValue (const AttributePtr &theAttribute) |
| QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getFilteredSelected () |
| Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More... | |
| virtual void | blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| bool | getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid) |
| Gets the validity state of the presentation in an internal map. More... | |
| void | storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid) |
| Store the validity state of the presentation in an internal map. More... | |
Protected Attributes | |
| PartSet_ExternalObjectsMgr * | myExternalObjectMgr |
| A reference to external objects manager. More... | |
| CompositeFeaturePtr | mySketch |
| Pointer to a sketch. More... | |
| bool | myUseSketchPlane |
| state whether the sketch plane filter should be switched on More... | |
| QLabel * | myLabel |
| Label of the widget. More... | |
| QLineEdit * | myTextLine |
| Input control of the widget. More... | |
| QStringList | myShapeTypes |
| List of accepting shapes types. More... | |
| bool | myIsPointsFiltering |
| ModuleBase_IWorkshop * | myWorkshop |
| Reference to workshop. More... | |
| bool | myIsInValidate |
| The widget is in validation mode: store is performed, restore is not. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
| PartSet_WidgetShapeSelector::PartSet_WidgetShapeSelector | ( | QWidget * | theParent, |
| ModuleBase_IWorkshop * | theWorkshop, | ||
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theWorkshop | instance of workshop interface |
| theData | the widget configuration. The attribute of the model widget is obtained from |
inline |
Set sketcher.
| theSketch | a sketcher object |
inline |
| [out] | theSelectionFilters | selection filters |
Reimplemented from ModuleBase_WidgetValidated.
protectedvirtual |
By default, it returns true.
| thePrs | a selected presentation in the view |
Reimplemented from ModuleBase_WidgetSelector.
protectedvirtual |
| thePrs | a selection |
| theObject | an output object |
| theShape | a shape of the selection |
protectedvirtual |
| theAttribute | an attribute |
| theValid | a boolean flag, if restore happens for valid parameters |
It is redefined to check the value validity and if it is, fill the attribute with by value
| theToValidate | a flag on validation of the values |
protectedvirtualinherited |
Implements ModuleBase_WidgetSelector.
selection attribute
Reimplemented in PartSet_WidgetFeaturePointSelector.
Reimplemented in ModuleBase_WidgetPointInput.
inlinevirtualinherited |
Reimplemented in ModuleBase_WidgetPointInput, and PartSet_WidgetMultiSelector.
| thePrs | a selected owner |
Implements ModuleBase_WidgetValidated.
clear temporary cash
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
Reimplemented in ModuleBase_WidgetMultiSelector, and PartSet_WidgetSketchCreator.
| theDone | a state whether the selection is set |
protectedinherited |
Reimplemented in ModuleBase_WidgetMultiSelector, and PartSet_WidgetFeaturePointSelector.
If the widget type of shapes contains the faces item, the result is converted to construction result and the method returns true if there is at least one face in the construction.
| theShape | a shape |
| theResult | a selected result |
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
Reimplemented in PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
staticinherited |
| theAttribute | an attribute of blocking |
| theFeature | a feature |
| theToBlock | flag whether the model is blocked or unblocked |
| isFlushesActived | out value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked |
| isAttributeSetInitializedBlocked | out value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked |
| isAttributeSendUpdatedBlocked | out value if model signal is blocked |
staticinherited |
| theAttribute | an attribute to be validated |
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
| theAttribute | the attribute |
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
In default implementation, this is an attribute of ID
| theAttribute | an attribute to be stored |
Returns true if the valid state of value is stored
| theValue | a viewer presentation |
| theValid | a valid state |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
inlineprotectedinherited |
| theState | a new state |
protectedslotinherited |
protected |
protected |
protected |
A feature ID.
