PartSet_ExternalObjectsMgr Class Reference
Customosation of ModuleBase_WidgetShapeSelector in order to provide working with sketch specific objects. More...
#include <PartSet_ExternalObjectsMgr.h>
 PartSet_ExternalObjectsMgr (const std::string &theExternal, const std::string &theCanCreateExternal, const bool theDefaultValue)
bool useExternal () const
 Returns the state whether the external object is used. More...
bool canCreateExternal ()
 Returns if new external objects can be created. More...
bool isValidObject (const ObjectPtr &theObject)
 Checks validity of the given object. More...
ObjectPtr externalObject (const ObjectPtr &theSelectedObject, const GeomShapePtr &theShape, const CompositeFeaturePtr &theSketch, const bool theTemporary=false)
 Finds or create and external object. More...
ObjectPtr externalCenterObject (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, const CompositeFeaturePtr &theSketch, const bool theTemporary)
 Finds or create and external object by selected circle center (PartSet_CenterPrs) More...
ObjectPtr getExternalObjectValidated () const
 Returns created external object or NULL. More...
void removeExternal (const CompositeFeaturePtr &theSketch, const FeaturePtr &theFeature, ModuleBase_IWorkshop *theWorkshop, const bool theTemporary)
virtual void getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape, ModuleBase_IWorkshop *theWorkshop, const CompositeFeaturePtr &theSketch, const bool isInValidate)
 Return an object and geom shape by the viewer presentation. More...
void removeExternalObject (const ObjectPtr &theObject, const CompositeFeaturePtr &theSketch, const FeaturePtr &theFeature, ModuleBase_IWorkshop *theWorkshop)
 Delete from the document the feature of the object. More...
static XGUI_Workshop * workshop (ModuleBase_IWorkshop *theWorkshop)
 Returns the workshop. More...
ObjectPtr myExternalObjectValidated
 An external object. More...
bool myUseExternal
 Boolean value about the neccessity of the external object use. More...
bool myCanCreateExternal
 Boolean value about the necessity of a new external object creation. More...
◆ PartSet_ExternalObjectsMgr()
PartSet_ExternalObjectsMgr::PartSet_ExternalObjectsMgr ( const std::string &  theExternal,
const std::string &  theCanCreateExternal,
theExternalthe external state
theCanCreateExternalthe state if it can and should create external features
theDefaultValuethe default value for the external object using
◆ useExternal()
bool PartSet_ExternalObjectsMgr::useExternal ( ) const
◆ canCreateExternal()
bool PartSet_ExternalObjectsMgr::canCreateExternal ( )
boolean value
◆ isValidObject()
bool PartSet_ExternalObjectsMgr::isValidObject ( const ObjectPtr &  theObject)
theObjectan object to check
valid or not valid
◆ externalObject()
ObjectPtr PartSet_ExternalObjectsMgr::externalObject ( const ObjectPtr &  theSelectedObject,
const GeomShapePtr &  theShape,
const CompositeFeaturePtr &  theSketch,
const bool  theTemporary = false
theSelectedObjectan object
theShapea selected shape, which is used in the selection attribute
theSketcha current sketch
theTemporarythe created external object is temporary, execute is not performed for it
the object
◆ externalCenterObject()
ObjectPtr PartSet_ExternalObjectsMgr::externalCenterObject ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs,
thePrsa selection
the object
◆ getExternalObjectValidated()
ObjectPtr PartSet_ExternalObjectsMgr::getExternalObjectValidated ( ) const
an object instance
◆ removeExternal()
void PartSet_ExternalObjectsMgr::removeExternal ( const CompositeFeaturePtr &  theSketch,
const FeaturePtr &  theFeature,
ModuleBase_IWorkshop *  theWorkshop,
theFeaturea current feature
theWorkshopa current workshop
theTemporaryif true, a temporary external object is removed, otherwise all ext objects
◆ getGeomSelection()
void PartSet_ExternalObjectsMgr::getGeomSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs,
ObjectPtr &  theObject,
thePrsa selection
theObjectan output object
theShapea shape of the selection
use objects of found selection
the object is null if the selected feature is "external"(not sketch entity feature of the current sketch) and it is not created by object manager
◆ removeExternalObject()
void PartSet_ExternalObjectsMgr::removeExternalObject ( const ObjectPtr &  theObject,
It deletes all objects, which refers to the deleted one. The parameter feature is ignored even it refer to the deleted object.
theObjecta removed object
◆ workshop()
XGUI_Workshop * PartSet_ExternalObjectsMgr::workshop ( ModuleBase_IWorkshop *  theWorkshop)
staticprotected
◆ myExternalObjectValidated
ObjectPtr PartSet_ExternalObjectsMgr::myExternalObjectValidated
An external object.
◆ myUseExternal
bool PartSet_ExternalObjectsMgr::myUseExternal
◆ myCanCreateExternal
bool PartSet_ExternalObjectsMgr::myCanCreateExternal
