A model widget implementation for a label which provides specific behaviour for sketcher starting and launching operations. More...
#include <PartSet_WidgetSketchLabel.h>
Public Types | |
Signals | |
| void | planeSelected (const std::shared_ptr< GeomAPI_Pln > &thePln) |
| Signal on plane selection. More... | |
| void | showConstraintToggled (int theType, bool theState) |
| A show constraint toggled signal. More... | |
| void | showFreePoints (bool toShow) |
| The signal is emitted when user checks "Show free points" button. More... | |
| void | autoConstraints (bool isOn) |
| The signal is emitted when user checks "Automatic constraints" button. More... | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| PartSet_WidgetSketchLabel (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData, const QMap< PartSet_Tools::ConstraintVisibleState, bool > &toShowConstraints) | |
| Constructor. More... | |
| Returns True if data of its attribute was modified. More... | |
| Set the given wrapped value to the current widget This value should be processed in the widget according to the needs The method is called by the current operation to process the operation preselection. More... | |
| Using widget selection filter only if plane is not defined. More... | |
| The methiod called when widget is deactivated. More... | |
| std::shared_ptr< GeomAPI_Pln > | plane () const |
| Returns sketcher plane. More... | |
| virtual bool | focusTo () |
| This control accepts focus. More... | |
| virtual void | setHighlighted (bool) |
| void | setShowPointsState (bool theState) |
| Set current state of show free points. More... | |
| virtual bool | isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue) |
| Checks all widget validator if the owner is valid. More... | |
| ObjectPtr | findPresentedObject (const AISObjectPtr &theAIS) const |
| Returns data object by AIS. More... | |
| void | clearValidatedCash () |
| Clear all validated cash in the widget. More... | |
| bool | isFilterActivated () const |
| Returns true if the workshop validator filter has been already activated. More... | |
| bool | reset () |
| bool | restoreValue () |
| bool | storeValue () |
| void | activate () |
| static bool | canFillSketch (const ModuleBase_ViewerPrsPtr &thePrs) |
| Returns True if the selected presentation can be used for plane definition. More... | |
| static void | blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| Block the model flush of update and initialization of attribute. More... | |
| static bool | isValidAttribute (const AttributePtr &theAttribute) |
| Checks the current attribute in all attribute validators. More... | |
Protected Slots | |
| virtual void | storeAttributeValue (const AttributePtr &theAttribute) |
| Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More... | |
| virtual void | restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid) |
| virtual bool | setSelectionCustom (const ModuleBase_ViewerPrsPtr &thePrs) |
| Fills the attribute with the value of the selected owner. More... | |
| The methiod called when widget is activated. More... | |
| virtual void | blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| Block the model flush of update and initialization of attribute In additional to curstom realization it blocks initialization for all feature attributes as the current attribute is selection but its modification leads to other attributes change. More... | |
| Returns true if envent is processed. More... | |
| bool | setSelectionInternal (const QList< ModuleBase_ViewerPrsPtr > &theValues, const bool theToValidate) |
| void | updateByPlaneSelected (const ModuleBase_ViewerPrsPtr &thePrs) |
| Erase preview planes, disconnect widget, change the view projection. More... | |
| bool | fillSketchPlaneBySelection (const ModuleBase_ViewerPrsPtr &thePrs) |
| Set sketch plane from selected object. More... | |
| virtual void | showEvent (QShowEvent *theEvent) |
| Redefinition of a virtual function. More... | |
| virtual void | hideEvent (QHideEvent *theEvent) |
| virtual bool | eventFilter (QObject *theObj, QEvent *theEvent) |
| virtual bool | isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks whether all active viewer filters validate the presentation. More... | |
| bool | isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute) |
| Checks all attribute validators returns valid. More... | |
| virtual AttributePtr | attribute () const |
| Returns attribute, which should be validated. More... | |
| virtual bool | isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks the widget validity. More... | |
| QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getFilteredSelected () |
| Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More... | |
| bool | getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid) |
| Gets the validity state of the presentation in an internal map. More... | |
| void | storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid) |
| Store the validity state of the presentation in an internal map. More... | |
Protected Attributes | |
| ModuleBase_IWorkshop * | myWorkshop |
| Reference to workshop. More... | |
| bool | myIsInValidate |
| The widget is in validation mode: store is performed, restore is not. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
Friends | |
| class | PartSet_WidgetSketchGrid |
| class | PartSet_WidgetSketchRectangularGrid |
| class | PartSet_WidgetSketchCircularGrid |
| PartSet_WidgetSketchLabel::PartSet_WidgetSketchLabel | ( | QWidget * | theParent, |
| ModuleBase_IWorkshop * | theWorkshop, | ||
| const Config_WidgetAPI * | theData, | ||
| const QMap< PartSet_Tools::ConstraintVisibleState, bool > & | toShowConstraints | ||
| theParent | the parent object |
| theWorkshop | a reference to workshop |
| theData | the widget configuration. The attribute of the model widget is obtained from |
| toShowConstraints | a current show constraints state |
inlinevirtual |
It is redefined to do nothing if the plane of the sketch has been already set.
| theToValidate | a validation flag |
| theModes | [out] a container of modes |
| [out] | selection | filters |
Reimplemented from ModuleBase_WidgetValidated.
inlinevirtual |
| std::shared_ptr< GeomAPI_Pln > PartSet_WidgetSketchLabel::plane | ( | ) | const |
inlinevirtual |
| void PartSet_WidgetSketchLabel::setShowPointsState | ( | bool | theState | ) |
| theState | a state of the corresponded check box |
static |
| thePrs | a presentation |
inlinevirtual |
By default does nothing
signal |
signal |
| theType | a ConstraintVisibleState value |
| theState | a state of the check box |
signal |
| toShow | a state of the check box |
signal |
| isOn | a state of the check box |
protectedvirtual |
| theAttribute | an attribute to be stored |
protectedvirtual |
| theAttribute | an attribute to be restored |
| theValid | a boolean flag, if restore happens for valid parameters |
protectedvirtual |
| thePrs | a selected owner |
Implements ModuleBase_WidgetValidated.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
| theAttribute | an attribute |
| theToBlock | flag whether the model is blocked or unblocked |
| isFlushesActived | out value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked |
| isAttributeSetInitializedBlocked | out value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked |
| isAttributeSendUpdatedBlocked | out value if model signal is blocked |
protectedvirtual |
protected |
protected |
| thePrs | a selected presentation |
protected |
| theFeature | a feature of sketch |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
Reimplemented in PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
staticinherited |
| theAttribute | an attribute of blocking |
| theFeature | a feature |
staticinherited |
| theAttribute | an attribute to be validated |
protectedvirtualinherited |
| thePrs | a selected presentation in the view |
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
protectedinherited |
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
| theAttribute | the attribute |
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
In default implementation, this is an attribute of ID
By default, it returns true.
Reimplemented in ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, CollectionPlugin_WidgetField, and PartSet_WidgetSketchCreator.
Returns true if the valid state of value is stored
| theValue | a viewer presentation |
| theValid | a valid state |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
inlineprotectedinherited |
| theState | a new state |
protectedslotinherited |
A feature ID.
