ModuleBase_WidgetMultiSelector Class Reference
Implementation of widget for shapes selection. More...
#include <ModuleBase_WidgetMultiSelector.h>
Inheritance diagram for ModuleBase_WidgetMultiSelector:
enum  ValueState { Stored , ModifiedInPP , ModifiedInViewer , Reset }
 State of the widget. More...
enum  EnableState { On , Off , DefinedInPreferences }
 the value is reset More...
Public Slots
void onSelectionTypeChanged ()
 Slot is called on selection type changed. More...
Signals
void beforeValuesChanged ()
 The signal about widget values are to be changed. More...
void valuesChanged ()
 The signal about widget values changed. More...
void valuesModified ()
 The signal about widget values modified. More...
void afterValuesChanged ()
void beforeValuesRestored ()
 The signal about widget values are to be restored. More...
void afterValuesRestored ()
void keyReleased (QObject *theObject, QKeyEvent *theEvent)
 The signal about key release on the control, that corresponds to the attribute. More...
void enterClicked (QObject *theObject)
 The signal is emitted if the enter is clicked in the control of the widget. More...
void focusInWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is get focus. More...
void focusOutWidget (ModuleBase_ModelWidget *theWidget)
 The signal about the widget is lost focus. More...
void valueStateChanged (int theState)
 The signal about value state modification. More...
void objectUpdated ()
 The signal is emitted after flush of updates singal for the widget. More...
 ModuleBase_WidgetMultiSelector (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData)
virtual QList< QWidget * > getControls () const
 Returns list of widget controls. More...
virtual void deactivate ()
 The methiod called when widget is deactivated. More...
virtual void updateAfterDeactivation ()
 Update Undo/Redo actions state. More...
virtual void updateAfterActivation ()
virtual bool setSelection (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues, const bool theToValidate)
 Set the given wrapped value to the current widget This value should be processed in the widget according to the needs. More...
virtual void getHighlighted (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Returns values which should be highlighted when the whidget is active. More...
virtual bool canProcessAction (ModuleBase_ActionType theActionType, bool &isActionEnabled)
 Returns true if the action can be processed. More...
virtual bool processAction (ModuleBase_ActionType theActionType, const ActionParamPtr &theParam=ActionParamPtr())
 Returns true if the event is processed. The default implementation is empty, returns false. More...
virtual bool isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Checks the widget validity. More...
virtual QList< ActionInfo > actionsList (ModuleBase_ActionType theActionType) const
 Returns list of accessible actions for Undo/Redo commands. More...
virtual void onFeatureAccepted ()
 The slot is called when user press Ok or OkPlus buttons in the parent property panel. More...
 Returns True if data of its feature was modified during operation. More...
virtual void setReadOnly (bool isReadOnly)
virtual void selectionModes (int &theModuleSelectionModes, QIntList &theModes)
 Fills given container with selection modes if the widget has it. More...
virtual bool isViewerSelector ()
 Defines if it is supposed that the widget should interact with the viewer. More...
virtual void updateSelectionModesAndFilters (bool toActivate)
 Activate or deactivate selection and selection filters. More...
virtual bool setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Fills the attribute with the value of the selected owner. More...
virtual bool isWholeResultAllowed () const
virtual bool isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue)
 Checks all widget validator if the owner is valid. More...
ObjectPtr findPresentedObject (const AISObjectPtr &theAIS) const
 Returns data object by AIS. More...
void clearValidatedCash ()
 Clear all validated cash in the widget. More...
bool isFilterActivated () const
 Returns true if the workshop validator filter has been already activated. More...
virtual void selectionFilters (QIntList &theModuleSelectionFilters, SelectMgr_ListOfFilter &theSelectionFilters)
 Appends into container of workshop selection filters. More...
bool reset ()
 Fills the widget with default values. More...
bool isInitialized (ObjectPtr theObject) const
 Returns the state whether the attribute of the feature is initialized. More...
bool isComputedDefault () const
 Returns true, if default value of the widget should be computed on operation's execute, like radius for circle's constraint (can not be zero) More...
std::string getDefaultValue () const
 Returns true, if default value of the widget is defined in the XML and it is not the computed value. More...
bool isInternal () const
 Returns true, if widget is internal. More...
bool isObligatory () const
 Returns true, if the obligatory value of the widget is not defined in the XML or has true value. More...
virtual bool isValueEnabled () const
 Returns true, if the widget value is enabled and might be modified manually. More...
bool isUseReset () const
 Returns this parameter value in the xml file. More...
std::string isModifiedInEdit () const
ValueState getValueState () const
 Returns this widget value state. More...
void processValueState ()
 Stores the widget value if it is modified. More...
Events_InfoMessage getValueStateError () const
 Returns an attribute error according to the value state It exists in all cases excepring the "Store" case. More...
virtual bool canAcceptFocus () const
 Defines if it is supported to set the value in this widget By default it returns true. More...
virtual QString getError (const bool theValueStateChecked=true) const
 Returns the widget error, get it from the attribute validator and state of the widget If the feature is correct, it returns an empty value. More...
ModuleBase_WidgetValidator * widgetValidator ()
 Returns widget validator, by default it is NULL. To be created in a child if necessary. More...
bool restoreValue ()
 Restore value from attribute data to the widget's control. More...
bool storeValue ()
 Saves the internal parameters to the given feature. More...
virtual bool focusTo ()
 Set focus to the first control of the current widget. More...
virtual void selectContent ()
 Select the internal content if it can be selected. It is empty in the default realization. More...
void activate ()
 The method called when widget is activated. More...
virtual bool needToBeActivated ()
 The method called if widget should be activated always. More...
QWidget * getControlAcceptingFocus (const bool isFirst)
 Returns the first or the last control that can accept the focus. More...
virtual bool eventFilter (QObject *theObject, QEvent *theEvent)
 FocusIn events processing. More...
virtual void enableFocusProcessing ()
 Enables processing of focus event on all controls by the widget if this widget is not obligatory and set no-focus policy otherwise. More...
virtual void setHighlighted (bool isHighlighted)
 Switch On/Off highlighting of the widget. More...
std::string attributeID () const
 Returns the attribute name. More...
FeaturePtr feature () const
virtual std::string context () const
virtual void setFeature (const FeaturePtr &theFeature, const bool theToStoreValue=false, const bool isUpdateFlushed=true)
 Set feature which is processing by active operation. More...
virtual void setEditingMode (bool isEditing)
 Editing mode depends on mode of current operation. This value is defined by it. More...
bool isEditingMode () const
void updateObject (ObjectPtr theObj)
 Sends Update and Redisplay for the given object. More...
virtual QString translate (const std::string &theStr) const
 Translate passed string with widget context() More...
void emitFocusInWidget ()
 Emit focus in widget to set this control as active in property panel. More...
virtual bool usesAttribute () const
 Returns True if the widget uses feature attribute. More...
virtual bool isInformative () const
 Returns True in case if the widget contains useful information for inspection tool. More...
virtual void showInformativePage ()
 If widgets has several panels then this method has to show a page which contains information for current feature. More...
virtual bool isReadOnly () const
bool canUseExternalParts () const
 Returns true if the widget should have access to external parts. More...
static void blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked)
 Block the model flush of update and initialization of attribute. More...
static bool isValidAttribute (const AttributePtr &theAttribute)
 Checks the current attribute in all attribute validators. More...
static ModuleBase_ModelWidget * findModelWidget (ModuleBase_IPropertyPanel *theProp, QWidget *theWidget)
 Finds model widget parent of the given sub widget. More...
Protected Slots
void onDeleteItem ()
 Slot for delete command in a list pop-up menu. More...
void onListSelection ()
 Slot is called on selection of list of selected items. More...
void onListActivated ()
void onSameTopology (bool theOn)
void onShowOnly (bool)
void onRemoveFilters ()
void onWidgetValuesChanged ()
 Processing of values changed in model widget by store the current value to the feature. More...
void onWidgetValuesModified ()
 Changes widget state. More...
virtual bool processSelection ()
 Returns true if envent is processed. More...
virtual bool processDelete ()
virtual void activateCustom ()
 The methiod called when widget is activated. More...
virtual bool storeValueCustom ()
virtual bool restoreValueCustom ()
 restire type of selection by feature attribute More...
virtual void appendFirstSelectionInHistory ()
 Creates an element of the attribute current selection if history is empty. More...
void appendSelectionInHistory ()
 Create an element in the history that stores the current selection, position in the history is incremented. More...
void clearSelectedHistory ()
 Clear list of stored selected items, reset current position into '-1'. More...
virtual void updateFocus ()
 Set the focus on the last item in the list. More...
virtual void updateSelectionName ()
 Computes and updates name of selected object in the widget. More...
virtual void updateOnSelectionChanged (const bool theDone)
 Emits model changed info, updates the current control by selection change. More...
virtual QIntList shapeTypes () const
 Returns a list of possible shape types. More...
void setCurrentShapeType (const QString &theShapeType)
 Set current shape type for selection. More...
virtual QList< std::shared_ptr< ModuleBase_ViewerPrs > > getAttributeSelection () const
 Return the attribute values wrapped in a list of viewer presentations. More...
void updateSelectionList ()
 Fills the list control by the attribute values. More...
std::string validatorType (const QString &theType) const
 Converts the XML defined type choice to the validator type For example, the "Edges" is converted to "edge". More...
void clearSelection ()
 Clear selection in the viewer. The content of the widget is cleared also. More...
void getSelectedAttributeIndices (std::set< int > &theIndices)
 Returns attribute indices selected in the widget selection list. More...
void convertIndicesToViewerSelection (std::set< int > theAttributeIds, QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues) const
 Gets the feature attribute and fill a list of viewer presentation for the attribute indices. More...
virtual bool removeUnusedAttributeObjects (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Iterates through the model attribute list and remove elements which do not present in the list. More...
std::map< ObjectPtr, std::set< GeomShapePtr > > convertSelection (QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Converts viewer presentation selection list to objects and shapes map. More...
QIntList getShapeTypes () const
bool acceptSubShape (const GeomShapePtr &theShape, const std::shared_ptr< ModelAPI_Result > &theResult) const
 Returns true if selected shape corresponds to requested shape types. More...
virtual void getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape)
 Return an object and geom shape by the viewer presentation. More...
virtual bool isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
 Checks whether all active viewer filters validate the presentation. More...
bool isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute)
 Checks all attribute validators returns valid. More...
virtual AttributePtr attribute () const
 Returns attribute, which should be validated. More...
virtual void storeAttributeValue (const AttributePtr &theAttribute)
 Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More...
virtual void restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid)
QList< std::shared_ptr< ModuleBase_ViewerPrs > > getFilteredSelected ()
 Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More...
virtual void blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked)
bool getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid)
 Gets the validity state of the presentation in an internal map. More...
void storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid)
 Store the validity state of the presentation in an internal map. More...
void setDefaultValue (const std::string &theValue)
 Sets default value of widget. More...
void setAttributeID (const std::string &theAttribute)
 Set the attribute name. More...
ValueState setValueState (const ValueState &theState)
 Sets the current value state. More...
bool blockValueState (const bool theBlocked)
 Blocks the value state change. More...
virtual void initializeValueByActivate ()
 Compute the feature default value and fill the controls with it or store the control value to the feature. More...
virtual bool resetCustom ()
virtual bool processEnter ()
virtual bool processEscape ()
static bool findInSelection (const ObjectPtr &theObject, GeomShapePtr theShape, const std::map< ObjectPtr, std::set< GeomShapePtr > > &theGeomSelection, ModuleBase_IWorkshop *theWorkshop)
 Returns true if the object and shape present in the container. More...
ModuleBase_ListView * myListView
 List control. More...
bool myIsUseChoice
 A flag to store use_choice parameter state. More...
QStringList myShapeTypes
 List of Shape types defined in XML. More...
ModuleBase_ChoiceCtrl * myTypeCtrl
 Control for types. More...
bool myIsNeutralPointClear
 A flag to clear selection by click in empty place in the viewer. More...
bool myIsSetSelectionBlocked
 A flag to block set selection perform if the method is in process. More...
QList< QList< std::shared_ptr< ModuleBase_ViewerPrs > > > mySelectedHistoryValues
 A container of selected objects. More...
int myCurrentHistoryIndex
 Position in a container of selected values. More...
bool myIsFirst
std::string myDefMode
QVBoxLayout * myMainLayout
QCheckBox * myGeomCheck
ModuleBase_FilterStarter * myFiltersWgt
QPushButton * myShowOnlyBtn
QPushButton * myRemoveFiltersBtn
QObjectPtrList myVisibleObjects
QStringList myAllowedObjects
QStringList myTmpAllowed
std::string myUseFilters
bool myIsPointsFiltering
ModuleBase_IWorkshop * myWorkshop
 Reference to workshop. More...
bool myIsInValidate
 The widget is in validation mode: store is performed, restore is not. More...
std::unique_ptr< ModuleBase_WidgetValidator > myWidgetValidator
 own validator, by default it is zero More...
std::string myAttributeID
 The attribute name of the model feature. More...
FeaturePtr myFeature
 A feature which is processing by active operation. More...
std::string myFeatureId
 A feature ID. More...
bool myIsObligatory
 Flag which shows whether current widget is obligatory The non-obligatory widgets should not accept the focus in the property panel. More...
EnableState myIsValueEnabled
 Flag about value of the control is enabled (can be modified) More...
ValueState myState
 The widget value state. More...
This widget provides selection of several shapes. It can be defined in XML file as following:
<multi_selector id="group_list"
tooltip="Select a set of objects"
shape_types="Vertices Edges Faces Solids" />
It uses following parameters:
  • id - is a name of corresponded attribute
  • tooltip - a tooltip for the widget
  • shape_types - list of expected shape types.
◆ ValueState
ModifiedInPP
modification is finished and applied to the model
ModifiedInViewer
modification has not been finished and set to the model yet
Reset
modification performed by viewer events
◆ EnableState
the value is reset
Off
the widget value is always enabled
the widget value is always disabled
the widget value enable state is defined in preferences
◆ ModuleBase_WidgetMultiSelector()
ModuleBase_WidgetMultiSelector::ModuleBase_WidgetMultiSelector ( QWidget *  theParent,
ModuleBase_IWorkshop *  theWorkshop,
const Config_WidgetAPI *  theData
theParentthe parent object
theWorkshopinstance of workshop interface
theDatathe widget configuration. The attribute of the model widget is obtained from
◆ getControls()
QList< QWidget * > ModuleBase_WidgetMultiSelector::getControls ( ) const
a control list
◆ deactivate()
void ModuleBase_WidgetMultiSelector::deactivate ( )
Reimplemented from ModuleBase_WidgetSelector.
◆ updateAfterDeactivation()
void ModuleBase_WidgetMultiSelector::updateAfterDeactivation ( )
◆ updateAfterActivation()
void ModuleBase_WidgetMultiSelector::updateAfterActivation ( )
◆ setSelection()
bool ModuleBase_WidgetMultiSelector::setSelection ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues,
theValuesthe wrapped selection values
theToValidatea validation of the values flag
remove unused objects from the model attribute. It should be performed before new attributes append.
it is not optimal as hasObject() is already checked
hope that something is redisplayed by object updated
◆ getHighlighted()
void ModuleBase_WidgetMultiSelector::getHighlighted ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
◆ canProcessAction()
bool ModuleBase_WidgetMultiSelector::canProcessAction ( ModuleBase_ActionType  theActionType,
bool &  isActionEnabled
theActionTypean action type
isActionEnabledif true, the enable state of the action
◆ processAction()
bool ModuleBase_WidgetMultiSelector::processAction ( ModuleBase_ActionType  theActionType,
const ActionParamPtr &  theParam = ActionParamPtr()
◆ isValidSelectionCustom()
bool ModuleBase_WidgetMultiSelector::isValidSelectionCustom ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
By default, it returns true.
thePrsa selected presentation in the view
a boolean value
Reimplemented in PartSet_WidgetMultiSelector.
◆ actionsList()
QList< ActionInfo > ModuleBase_WidgetMultiSelector::actionsList ( ModuleBase_ActionType  theActionType) const
theActionTypetype of action. It can be ActionUndo or ActionRedo.
◆ onFeatureAccepted()
void ModuleBase_WidgetMultiSelector::onFeatureAccepted ( )
◆ isModified()
bool ModuleBase_WidgetMultiSelector::isModified ( ) const
◆ setReadOnly()
void ModuleBase_WidgetMultiSelector::setReadOnly ( bool  isReadOnly)
◆ onSelectionTypeChanged
void ModuleBase_WidgetMultiSelector::onSelectionTypeChanged ( )
slot
store the selected type
◆ processSelection()
bool ModuleBase_WidgetMultiSelector::processSelection ( )
Redefined to process XML state about clear selection in neutral point
◆ onDeleteItem
void ModuleBase_WidgetMultiSelector::onDeleteItem ( )
protectedslot
◆ onListSelection
void ModuleBase_WidgetMultiSelector::onListSelection ( )
protectedslot
◆ processDelete()
bool ModuleBase_WidgetMultiSelector::processDelete ( )
◆ activateCustom()
void ModuleBase_WidgetMultiSelector::activateCustom ( )
◆ storeValueCustom()
bool ModuleBase_WidgetMultiSelector::storeValueCustom ( )
True in success
◆ restoreValueCustom()
bool ModuleBase_WidgetMultiSelector::restoreValueCustom ( )
◆ appendFirstSelectionInHistory()
void ModuleBase_WidgetMultiSelector::appendFirstSelectionInHistory ( )
◆ appendSelectionInHistory()
void ModuleBase_WidgetMultiSelector::appendSelectionInHistory ( )
◆ clearSelectedHistory()
void ModuleBase_WidgetMultiSelector::clearSelectedHistory ( )
◆ updateFocus()
void ModuleBase_WidgetMultiSelector::updateFocus ( )
◆ updateSelectionName()
void ModuleBase_WidgetMultiSelector::updateSelectionName ( )
◆ updateOnSelectionChanged()
void ModuleBase_WidgetMultiSelector::updateOnSelectionChanged ( const bool  theDone)
theDonea state whether the selection is set
◆ shapeTypes()
QIntList ModuleBase_WidgetMultiSelector::shapeTypes ( ) const
a list of shapes
Implements ModuleBase_WidgetSelector.
◆ setCurrentShapeType()
void ModuleBase_WidgetMultiSelector::setCurrentShapeType ( const QString &  theShapeType)
◆ getAttributeSelection()
QList< ModuleBase_ViewerPrsPtr > ModuleBase_WidgetMultiSelector::getAttributeSelection ( ) const
a list of viewer presentations, which contains an attribute result and a shape. If the attribute do not uses the shape, it is empty
◆ updateSelectionList()
void ModuleBase_WidgetMultiSelector::updateSelectionList ( )
◆ validatorType()
std::string ModuleBase_WidgetMultiSelector::validatorType ( const QString &  theType) const
◆ clearSelection()
void ModuleBase_WidgetMultiSelector::clearSelection ( )
◆ getSelectedAttributeIndices()
void ModuleBase_WidgetMultiSelector::getSelectedAttributeIndices ( std::set< int > &  theIndices)
theIndicesa list of indices
◆ convertIndicesToViewerSelection()
void ModuleBase_WidgetMultiSelector::convertIndicesToViewerSelection ( std::set< int >  theAttributeIds,
If the the container of indices is empty, it returns all objects.
theAttributeIdsindices in attribute list to be returned
theValuesthe result presentations, filled with object and shape of an attribute item
◆ removeUnusedAttributeObjects()
bool ModuleBase_WidgetMultiSelector::removeUnusedAttributeObjects ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
true if at least one object is removed
◆ convertSelection()
std::map< ObjectPtr, std::set< GeomShapePtr > > ModuleBase_WidgetMultiSelector::convertSelection ( QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
selection list
◆ findInSelection()
bool ModuleBase_WidgetMultiSelector::findInSelection ( const ObjectPtr &  theObject,
const std::map< ObjectPtr, std::set< GeomShapePtr > > &  theGeomSelection,
staticprotected
theObjecta model object, a set of shapes is searched by it
theShapea shape to be in the set of the object shapes
theGeomSelectiona map built on selection
theWorkshopa current workshop
boolean result
◆ selectionModes()
void ModuleBase_WidgetSelector::selectionModes ( int &  theModuleSelectionModes,
QIntList &  theModes
[out]theModuleSelectionModesmodule additional modes, -1 means all default modes
[out]theModesa container of modes
Reimplemented in ModuleBase_WidgetPointInput.
◆ isViewerSelector()
virtual bool ModuleBase_WidgetSelector::isViewerSelector ( )
inlinevirtualinherited
Reimplemented in ModuleBase_WidgetPointInput, and PartSet_WidgetMultiSelector.
◆ updateSelectionModesAndFilters()
void ModuleBase_WidgetSelector::updateSelectionModesAndFilters ( bool  toActivate)
◆ setSelectionCustom()
bool ModuleBase_WidgetSelector::setSelectionCustom ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
thePrsa selected owner
Implements ModuleBase_WidgetValidated.
Reimplemented in PartSet_WidgetFeaturePointSelector.
◆ getShapeTypes()
QIntList ModuleBase_WidgetSelector::getShapeTypes ( ) const
a list of shapes
◆ acceptSubShape()
bool ModuleBase_WidgetSelector::acceptSubShape ( const GeomShapePtr &  theShape,
const std::shared_ptr< ModelAPI_Result > &  theResult
If the widget type of shapes contains the faces item, the result is converted to construction result and the method returns true if there is at least one face in the construction.
theShapea shape
theResulta selected result
◆ getGeomSelection()
void ModuleBase_WidgetSelector::getGeomSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs,
thePrsa selection
theObjectan output object
theShapea shape of the selection
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, and PartSet_WidgetShapeSelector.
◆ isValidSelection()
bool ModuleBase_WidgetValidated::isValidSelection ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue)
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
theValuea selected presentation in the view
a boolean value
Reimplemented in PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
◆ findPresentedObject()
ObjectPtr ModuleBase_WidgetValidated::findPresentedObject ( const AISObjectPtr &  theAIS) const
◆ clearValidatedCash()
void ModuleBase_WidgetValidated::clearValidatedCash ( )
◆ isFilterActivated()
bool ModuleBase_WidgetValidated::isFilterActivated ( ) const
boolean value
◆ selectionFilters()
void ModuleBase_WidgetValidated::selectionFilters ( QIntList &  theModuleSelectionFilters,
SelectMgr_ListOfFilter &  theSelectionFilters
[out]theModuleSelectionFiltersmodule additional modes, -1 means all default modes
[out]selectionfilters
Reimplemented in PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
◆ blockFeatureAttribute()
void ModuleBase_WidgetValidated::blockFeatureAttribute ( const AttributePtr &  theAttribute,
const FeaturePtr &  theFeature,
const bool &  theToBlock,
bool &  isFlushesActived,
bool &  isAttributeSetInitializedBlocked,
bool &  isAttributeSendUpdatedBlocked
theAttributean attribute of blocking
theFeaturea feature
theToBlockflag whether the model is blocked or unblocked
isFlushesActivedout value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked
isAttributeSetInitializedBlockedout value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked
isAttributeSendUpdatedBlockedout value if model signal is blocked
◆ isValidAttribute()
bool ModuleBase_WidgetValidated::isValidAttribute ( const AttributePtr &  theAttribute)
theAttributean attribute to be validated
true if all validators return that the attribute is valid
◆ isValidInFilters()
bool ModuleBase_WidgetValidated::isValidInFilters ( const std::shared_ptr< ModuleBase_ViewerPrs > &  thePrs)
a boolean value
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
◆ isValidSelectionForAttribute()
bool ModuleBase_WidgetValidated::isValidSelectionForAttribute ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
theAttributethe attribute
a boolean value
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
◆ attribute()
AttributePtr ModuleBase_WidgetValidated::attribute ( ) const
In default implementation, this is an attribute of ID
an attribute
◆ storeAttributeValue()
void ModuleBase_WidgetValidated::storeAttributeValue ( const AttributePtr &  theAttribute)
theAttributean attribute to be stored
◆ restoreAttributeValue()
void ModuleBase_WidgetValidated::restoreAttributeValue ( const AttributePtr &  theAttribute,
const bool  theValid
theAttributean attribute to be restored
theValida boolean flag, if restore happens for valid parameters
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
◆ getFilteredSelected()
QList< ModuleBase_ViewerPrsPtr > ModuleBase_WidgetValidated::getFilteredSelected ( )
◆ blockAttribute()
void ModuleBase_WidgetValidated::blockAttribute ( const AttributePtr &  theAttribute,
◆ getValidState()
bool ModuleBase_WidgetValidated::getValidState ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
bool &  theValid
Returns true if the valid state of value is stored
theValuea viewer presentation
theValida valid state
◆ storeValidState()
void ModuleBase_WidgetValidated::storeValidState ( const std::shared_ptr< ModuleBase_ViewerPrs > &  theValue,
const bool  theValid
◆ reset()
bool ModuleBase_ModelWidget::reset ( )
true if the widget current value is reset
◆ isInitialized()
bool ModuleBase_ModelWidget::isInitialized ( ObjectPtr  theObject) const
theObjecta model feature to be checked
the boolean result
◆ isComputedDefault()
bool ModuleBase_ModelWidget::isComputedDefault ( ) const
◆ getDefaultValue()
std::string ModuleBase_ModelWidget::getDefaultValue ( ) const
the boolean result
◆ isInternal()
bool ModuleBase_ModelWidget::isInternal ( ) const
the boolean result
◆ isObligatory()
bool ModuleBase_ModelWidget::isObligatory ( ) const
the boolean result
◆ isValueEnabled()
bool ModuleBase_ModelWidget::isValueEnabled ( ) const
the boolean result
◆ isUseReset()
bool ModuleBase_ModelWidget::isUseReset ( ) const
the boolean result
◆ isModifiedInEdit()
std::string ModuleBase_ModelWidget::isModifiedInEdit ( ) const
the boolean result
◆ getValueState()
ValueState ModuleBase_ModelWidget::getValueState ( ) const
the enumeration result
◆ processValueState()
void ModuleBase_ModelWidget::processValueState ( )
◆ getValueStateError()
Events_InfoMessage ModuleBase_ModelWidget::getValueStateError ( ) const
◆ canAcceptFocus()
virtual bool ModuleBase_ModelWidget::canAcceptFocus ( ) const
◆ getError()
QString ModuleBase_ModelWidget::getError ( const bool  theValueStateChecked = true) const
theValueStateCheckedthe boolean flag if the state of the widget should be checked
string value
◆ widgetValidator()
ModuleBase_WidgetValidator * ModuleBase_ModelWidget::widgetValidator ( )
◆ restoreValue()
bool ModuleBase_ModelWidget::restoreValue ( )
True in success
◆ storeValue()
bool ModuleBase_ModelWidget::storeValue ( )
True in success
◆ focusTo()
bool ModuleBase_ModelWidget::focusTo ( )
the state whether the widget can accept the focus
◆ selectContent()
virtual void ModuleBase_ModelWidget::selectContent ( )
◆ activate()
void ModuleBase_ModelWidget::activate ( )
◆ needToBeActivated()
virtual bool ModuleBase_ModelWidget::needToBeActivated ( )
◆ getControlAcceptingFocus()
QWidget * ModuleBase_ModelWidget::getControlAcceptingFocus ( const bool  isFirst)
isFirstif true, the first controls is returned or the last one
a control from a list of controls
◆ eventFilter()
bool ModuleBase_ModelWidget::eventFilter ( QObject *  theObject,
QEvent *  theEvent
◆ enableFocusProcessing()
void ModuleBase_ModelWidget::enableFocusProcessing ( )
◆ setHighlighted()
void ModuleBase_ModelWidget::setHighlighted ( bool  isHighlighted)
◆ attributeID()
std::string ModuleBase_ModelWidget::attributeID ( ) const
the string value
◆ feature()
FeaturePtr ModuleBase_ModelWidget::feature ( ) const
Current feature
◆ context()
virtual std::string ModuleBase_ModelWidget::context ( ) const
Context for translation
◆ setFeature()
void ModuleBase_ModelWidget::setFeature ( const FeaturePtr &  theFeature,
const bool  theToStoreValue = false,
const bool  isUpdateFlushed = true
theFeaturea feature object
theToStoreValuea value about necessity to store the widget value to the feature
isUpdateFlusheda flag if update should be flushed on store value
◆ setEditingMode()
virtual void ModuleBase_ModelWidget::setEditingMode ( bool  isEditing)
◆ isEditingMode()
bool ModuleBase_ModelWidget::isEditingMode ( ) const
Current Editing mode
◆ updateObject()
void ModuleBase_ModelWidget::updateObject ( ObjectPtr  theObj)
theObjis updating object
◆ translate()
QString ModuleBase_ModelWidget::translate ( const std::string &  theStr) const
◆ emitFocusInWidget()
void ModuleBase_ModelWidget::emitFocusInWidget ( )
◆ findModelWidget()
ModuleBase_ModelWidget * ModuleBase_ModelWidget::findModelWidget ( ModuleBase_IPropertyPanel *  theProp,
QWidget *  theWidget
theWidgeta candidate to be a child of the model widget
thePropa property panel instance
a model widget or NULL
◆ usesAttribute()
virtual bool ModuleBase_ModelWidget::usesAttribute ( ) const
◆ isInformative()
virtual bool ModuleBase_ModelWidget::isInformative ( ) const
◆ showInformativePage()
virtual void ModuleBase_ModelWidget::showInformativePage ( )
By default does nothing
◆ canUseExternalParts()
bool ModuleBase_ModelWidget::canUseExternalParts ( ) const
◆ beforeValuesChanged
void ModuleBase_ModelWidget::beforeValuesChanged ( )
signalinherited
◆ valuesChanged
void ModuleBase_ModelWidget::valuesChanged ( )
signalinherited
◆ valuesModified
void ModuleBase_ModelWidget::valuesModified ( )
signalinherited
◆ afterValuesChanged
void ModuleBase_ModelWidget::afterValuesChanged ( )
signalinherited
◆ beforeValuesRestored
void ModuleBase_ModelWidget::beforeValuesRestored ( )
signalinherited
◆ afterValuesRestored
void ModuleBase_ModelWidget::afterValuesRestored ( )
signalinherited
◆ keyReleased
void ModuleBase_ModelWidget::keyReleased ( QObject *  theObject,
QKeyEvent *  theEvent
signalinherited
theObjecta sender of the event
theEventkey release event
◆ enterClicked
void ModuleBase_ModelWidget::enterClicked ( QObject *  theObject)
signalinherited
◆ focusInWidget
void ModuleBase_ModelWidget::focusInWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
theWidgetthe model base widget
◆ focusOutWidget
void ModuleBase_ModelWidget::focusOutWidget ( ModuleBase_ModelWidget *  theWidget)
signalinherited
◆ valueStateChanged
void ModuleBase_ModelWidget::valueStateChanged ( int  theState)
signalinherited
◆ objectUpdated
void ModuleBase_ModelWidget::objectUpdated ( )
signalinherited
◆ setDefaultValue()
void ModuleBase_ModelWidget::setDefaultValue ( const std::string &  theValue)
◆ setAttributeID()
void ModuleBase_ModelWidget::setAttributeID ( const std::string &  theAttribute)
inlineprotectedinherited
theAttributethe string value with attribute name
◆ setValueState()
ModuleBase_ModelWidget::ValueState ModuleBase_ModelWidget::setValueState ( const ValueState &  theState)
theStatea new state
the previous value state
◆ blockValueState()
bool ModuleBase_ModelWidget::blockValueState ( const bool  theBlocked)
theBlockeda block state
the previous value
◆ initializeValueByActivate()
void ModuleBase_ModelWidget::initializeValueByActivate ( )
◆ resetCustom()
virtual bool ModuleBase_ModelWidget::resetCustom ( )
◆ processEnter()
◆ processEscape()
bool ModuleBase_ModelWidget::processEscape ( )
◆ onWidgetValuesChanged
void ModuleBase_ModelWidget::onWidgetValuesChanged ( )
protectedslotinherited
◆ onWidgetValuesModified
void ModuleBase_ModelWidget::onWidgetValuesModified ( )
◆ myListView
ModuleBase_ListView* ModuleBase_WidgetMultiSelector::myListView
List control.
◆ myIsUseChoice
bool ModuleBase_WidgetMultiSelector::myIsUseChoice
◆ myShapeTypes
QStringList ModuleBase_WidgetMultiSelector::myShapeTypes
◆ myTypeCtrl
ModuleBase_ChoiceCtrl* ModuleBase_WidgetMultiSelector::myTypeCtrl
Control for types.
◆ myIsNeutralPointClear
bool ModuleBase_WidgetMultiSelector::myIsNeutralPointClear
◆ myIsSetSelectionBlocked
bool ModuleBase_WidgetMultiSelector::myIsSetSelectionBlocked
◆ mySelectedHistoryValues
QList<QList<std::shared_ptr<ModuleBase_ViewerPrs> > > ModuleBase_WidgetMultiSelector::mySelectedHistoryValues
◆ myCurrentHistoryIndex
int ModuleBase_WidgetMultiSelector::myCurrentHistoryIndex
◆ myWorkshop
ModuleBase_IWorkshop* ModuleBase_WidgetValidated::myWorkshop
◆ myIsInValidate
bool ModuleBase_WidgetValidated::myIsInValidate
◆ myWidgetValidator
std::unique_ptr<ModuleBase_WidgetValidator> ModuleBase_ModelWidget::myWidgetValidator
◆ myAttributeID
std::string ModuleBase_ModelWidget::myAttributeID
◆ myFeature
FeaturePtr ModuleBase_ModelWidget::myFeature
◆ myFeatureId
std::string ModuleBase_ModelWidget::myFeatureId
A feature ID.
◆ myIsObligatory
bool ModuleBase_ModelWidget::myIsObligatory
◆ myIsValueEnabled
EnableState ModuleBase_ModelWidget::myIsValueEnabled
◆ myState
ValueState ModuleBase_ModelWidget::myState
