Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_WidgetPointInput (QWidget *theParent, ModuleBase_IWorkshop *theWorkshop, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual | ~ModuleBase_WidgetPointInput () |
| Destructor. More... | |
| Fills the attribute with the value of the selected owner. More... | |
| virtual void | updateSelectionModesAndFilters (bool toActivate) |
| Activate or deactivate selection and selection filters. More... | |
| virtual bool | isValidSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks the widget validity. More... | |
| virtual bool | setSelectionCustom (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| The methiod called when widget is deactivated. More... | |
| virtual QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getAttributeSelection () const |
| Return the attribute values wrapped in a list of viewer presentations. More... | |
| virtual bool | isWholeResultAllowed () const |
| virtual bool | isValidSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue) |
| Checks all widget validator if the owner is valid. More... | |
| ObjectPtr | findPresentedObject (const AISObjectPtr &theAIS) const |
| Returns data object by AIS. More... | |
| void | clearValidatedCash () |
| Clear all validated cash in the widget. More... | |
| bool | isFilterActivated () const |
| Returns true if the workshop validator filter has been already activated. More... | |
| bool | reset () |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| Returns True if data of its attribute was modified. More... | |
| static void | blockFeatureAttribute (const AttributePtr &theAttribute, const FeaturePtr &theFeature, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| Block the model flush of update and initialization of attribute. More... | |
| static bool | isValidAttribute (const AttributePtr &theAttribute) |
| Checks the current attribute in all attribute validators. More... | |
Protected Slots | |
| virtual QIntList | shapeTypes () const |
| Returns a list of possible shape types. More... | |
| Returns true if the event is processed. More... | |
| Returns true if envent is processed. The default implementation is empty, returns false. More... | |
| virtual void | updateOnSelectionChanged (const bool theDone) |
| Emits model changed info, updates the current control by selection change. More... | |
| virtual void | updateFocus () |
| Update focus after the attribute value change. More... | |
| QIntList | getShapeTypes () const |
| virtual void | updateSelectionName () |
| Computes and updates name of selected object in the widget. More... | |
| The methiod called when widget is activated. More... | |
| bool | acceptSubShape (const GeomShapePtr &theShape, const std::shared_ptr< ModelAPI_Result > &theResult) const |
| Returns true if selected shape corresponds to requested shape types. More... | |
| virtual void | getGeomSelection (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs, ObjectPtr &theObject, GeomShapePtr &theShape) |
| Return an object and geom shape by the viewer presentation. More... | |
| virtual bool | isValidInFilters (const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs) |
| Checks whether all active viewer filters validate the presentation. More... | |
| bool | isValidSelectionForAttribute (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const AttributePtr &theAttribute) |
| Checks all attribute validators returns valid. More... | |
| virtual AttributePtr | attribute () const |
| Returns attribute, which should be validated. More... | |
| virtual void | storeAttributeValue (const AttributePtr &theAttribute) |
| Creates a backup of the current values of the attribute It should be realized in the specific widget because of different parameters of the current attribute. More... | |
| virtual void | restoreAttributeValue (const AttributePtr &theAttribute, const bool theValid) |
| QList< std::shared_ptr< ModuleBase_ViewerPrs > > | getFilteredSelected () |
| Returns a list of selected presentations in the viewer and object browser The presentations from the object browser are filtered by the AIS context filters. More... | |
| virtual void | blockAttribute (const AttributePtr &theAttribute, const bool &theToBlock, bool &isFlushesActived, bool &isAttributeSetInitializedBlocked, bool &isAttributeSendUpdatedBlocked) |
| bool | getValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, bool &theValid) |
| Gets the validity state of the presentation in an internal map. More... | |
| void | storeValidState (const std::shared_ptr< ModuleBase_ViewerPrs > &theValue, const bool theValid) |
| Store the validity state of the presentation in an internal map. More... | |
Protected Attributes | |
| ModuleBase_ParamSpinBox * | myXSpin |
| ModuleBase_ParamSpinBox * | myYSpin |
| ModuleBase_ParamSpinBox * | myZSpin |
| FeaturePtr | myXParam |
| FeaturePtr | myYParam |
| FeaturePtr | myZParam |
| double | myDefaultValue [3] |
| bool | myIsPointsFiltering |
| ModuleBase_IWorkshop * | myWorkshop |
| Reference to workshop. More... | |
| bool | myIsInValidate |
| The widget is in validation mode: store is performed, restore is not. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
| ModuleBase_WidgetPointInput::ModuleBase_WidgetPointInput | ( | QWidget * | theParent, |
| ModuleBase_IWorkshop * | theWorkshop, | ||
| const Config_WidgetAPI * | theData | ||
| theParent | the parent object |
| theWorkshop | a current workshop |
| theData | the widget configuration. The attribute of the model widget is obtained from |
inlinevirtual |
Reimplemented from ModuleBase_WidgetSelector.
| thePrs | a selected owner |
protectedvirtual |
Implements ModuleBase_WidgetSelector.
protectedvirtual |
By default, it returns true.
| thePrs | a selected presentation in the view |
Reimplemented from ModuleBase_WidgetValidated.
Reimplemented in ModuleBase_WidgetMultiSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, CollectionPlugin_WidgetField, and PartSet_WidgetSketchCreator.
Implements ModuleBase_WidgetValidated.
Reimplemented in PartSet_WidgetFeaturePointSelector.
clear temporary cash
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetFeaturePointSelector.
protectedvirtualinherited |
Reimplemented in ModuleBase_WidgetMultiSelector, and PartSet_WidgetSketchCreator.
| theDone | a state whether the selection is set |
Reimplemented in ModuleBase_WidgetMultiSelector, and ModuleBase_WidgetShapeSelector.
protectedinherited |
Reimplemented in ModuleBase_WidgetMultiSelector, and PartSet_WidgetFeaturePointSelector.
If the widget type of shapes contains the faces item, the result is converted to construction result and the method returns true if there is at least one face in the construction.
| theShape | a shape |
| theResult | a selected result |
| thePrs | a selection |
| theObject | an output object |
| theShape | a shape of the selection |
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, and PartSet_WidgetShapeSelector.
Firstly it checks custom widget validating, next, the attribute's validating. It trying on the give selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
Reimplemented in PartSet_WidgetFeaturePointSelector, and PartSet_WidgetSketchCreator.
| [out] | selection | filters |
Reimplemented in PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
staticinherited |
| theAttribute | an attribute of blocking |
| theFeature | a feature |
| theToBlock | flag whether the model is blocked or unblocked |
| isFlushesActived | out value if model is blocked, in value if model is unblocked to be used to restore flush state when unblocked |
| isAttributeSetInitializedBlocked | out value if model is blocked in value if model is unblocked to be used to restore previous state when unblocked |
| isAttributeSendUpdatedBlocked | out value if model signal is blocked |
staticinherited |
| theAttribute | an attribute to be validated |
after validation, the selection filters should be restored
Reimplemented in ModuleBase_WidgetFeatureSelector.
It tries on the given selection to current attribute by setting the value inside and calling validators. After this, the previous attribute value is restored.The valid/invalid value is cashed.
| theAttribute | the attribute |
NDS: The following rows are commented for issue #1452 (to be removed after debug) This is not correct to perform it here because it might cause update selection and the selection mechanizm will be circled: use the scenario of the bug with preselected point.
In default implementation, this is an attribute of ID
| theAttribute | an attribute to be stored |
| theAttribute | an attribute to be restored |
| theValid | a boolean flag, if restore happens for valid parameters |
Reimplemented in PartSet_WidgetFeaturePointSelector, PartSet_WidgetMultiSelector, PartSet_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
Returns true if the valid state of value is stored
| theValue | a viewer presentation |
| theValid | a valid state |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
inlineprotectedinherited |
| theState | a new state |
protectedslotinherited |
A feature ID.
